Old July 19th, 2009, 19:51   #1
tdibeliever
tdibeliever's Avatar
Default radial shaft play in a new turbo
Anybody know what would be acceptable radial play in a K03/K04 Hybrid turbo? It's only got 1500mi. on it and the car is using oil to the tune of a half quart in 750mi. There is quite a bit of oil pooling in the boost pipes.
'14 Passat SE TSI
'86 Cadillac Coupe Deville
'73 and '68 BMW 2002s
'64 Porsche 356c
'55 IH R-122
tdibeliever is offline   Reply With Quote
Old July 19th, 2009, 19:54   #2
diesel-dave
diesel-dave's Avatar
there has got to be enough play to allow oil to surround shaft
some oil is common in intake tract
are you idling long?
2003 Bora Wagon TDI Bosio R520's,colt cam, VNT 17
q loader. no smoke and so on
2001 Beetle TDI GLS Bosio 764 7 hole's, qloader, VNT 15 and so on
2010 JSW wagon DSG loaded
2003 golf auto PP520's
diesel-dave is offline   Reply With Quote
Old July 19th, 2009, 20:01   #3
tdibeliever
Perhaps an hour off and on while sorting the car out in the garage. The 1500mi. were all highway. There's no in/out movement. The compressor wheel looks it's right on the verge of touching the housing if was pushed to one side.
'14 Passat SE TSI
'64 Porsche 356c
'55 IH R-122
Old July 19th, 2009, 20:18   #4
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
Radial shaft play of K03 or K03/K04 are big compare to another turbo because bushing have only one point bearing versus two point for most turbo.
Compressor wheel touch housing... normal for this small KKK turbo.
I have this hybrid on my car last 130,000km and work good.
Axial play for brand new Garrett turbo are aprox 8 mil. (KKK are similar)
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old July 19th, 2009, 20:29   #5
diesel-dave
time for a new turbo
Old July 19th, 2009, 21:37   #6
dieseleux
dieseleux's Avatar
http://pics.tdiclub.com/showphoto.ph...0&ppuser=52721
Video of radial play of my brand new K03/K04.
and photo...
Dieseleux
Old July 19th, 2009, 22:52   #7
tdibeliever
Here's a pic and a short quicktime of it. I can only fit a .0015" feeler gauge between the wheel and the housing.
Ok, I can't figure out how to post the video, but they are in my member gallery.
'14 Passat SE TSI
'64 Porsche 356c
'55 IH R-122
Old July 20th, 2009, 02:46   #8
Rub87
and photo...
Dieseleux
Seems plenty, the stock K03 I removed from my AHU at 480.000km had less play and didn't use a drop of oil
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old July 20th, 2009, 07:29   #9
dieseleux
dieseleux's Avatar
Just put link of video like me.
In this small turbo, compressor wheel center by centrifugal force.
Dieseleux
Old July 20th, 2009, 09:40   #10
tdibeliever
http://pics.tdiclub.com/showphoto.ph...2&ppuser=14478
'14 Passat SE TSI
'64 Porsche 356c
'55 IH R-122
Old July 20th, 2009, 10:51   #11
tdibeliever
I just got an Email back from Gpopshop. They say acceptable values are between .018"-.022" Mine measures up to .025" and with as little clearance as .0015".
'14 Passat SE TSI
'64 Porsche 356c
'55 IH R-122
Old July 20th, 2009, 11:06   #12
diesel-dave
oh i thought you said it was touching or hitting the housing
with oil pressure it will float straight.
Old July 20th, 2009, 11:16   #13
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
The Gt25bb i'm using gives similar play as the turbo in the video if not a tad more............the bigger the turbo the more play it will have.
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old July 21st, 2009, 08:36   #14
The Shootist
tdibeliever,
That spec should be bearing clearance. At the end of the shaft it will be more, so your .025" is probably ok with that taken into account.
My 2256 had the same sort of play and when taken apart had absolutely zero signs of wear in the bearings. High oil volume floats the shaft in the center of the bearing, and will keep it centered until shaft rotation stops.
2002 NB known as "Stitch" (small, round, blue, kinda cute...may bite if agitated). PP520s, RC3, EGR delete, turbo back 2.25" open exhaust, cat delete, Koni struts & springs Neuspeed bars, slotted rotors, 245-45-17 Sumitomo's. Things to do: H2O intercooler, VNT-2256, lift pump, bigger IP.
The Shootist is offline   Reply With Quote
Old July 21st, 2009, 10:50   #15
mojogoes
Originally Posted by The Shootist
tdibeliever,
Yeah can you say "tubo timer"
Page generated in 0.16096 seconds with 9 queries
[Output: 126.14 Kb. compressed to 103.81 Kb. by saving 22.33 Kb. (17.70%)]
