Old July 19th, 2009, 09:26   #1
Turbine Suburban
Default Window roll down/up from key fob
Can the dealer enable this feature?
I gather someone with a vag com can?
Thanks.
Turbine Suburban is offline   Reply With Quote
Old July 19th, 2009, 09:34   #2
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
I'm not sure about the 2009s, but with the earlier cars, you need someone with the VDS Pro software (which the dealers do not have).
compu_85 has it and will be available at TDI Fest. Consider stopping by for the weekend!
Trusted TDI Mechanics Map || VCDS Locator || TDIClub Chat
Intercooler Icing MAP - SURVEY || DC/MD/VA - Impex GTG
Advancing the homosexual agenda, one post at a time!
Old July 19th, 2009, 09:41   #3
Turbine Suburban
Hmmm.
Thanks. Long drive, but hey, it's only 6 gallons each way.....
Old July 19th, 2009, 10:11   #4
Good Ol' Boy
VeeDubTDI's Avatar
LOL. Good point. It will be a great time... check out the Fest forum for more information.
Old July 19th, 2009, 12:25   #5
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default VagCom
Check my signature for Vag tool locator. You might find someone closer to you.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2011
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old July 19th, 2009, 17:14   #6
HeAvYfUeL
HeAvYfUeL's Avatar
Fuel Economy: Fuelly signature --->
I did it yesterday on my 2009 with a Micro-CAN USB cable. Latest software from Ross-Tech. No problem. Only the windows don't close by themselves when I lock the car. I have to keep the button pressed. Not like the Golf with the KVW mod I installed.
2009 Jetta Wagon Comfortline DSG ESP build 03/09 Graphite Blue
History:
2006 Golf TDI GLS/1992 Jetta 2.slow GL
HeAvYfUeL is offline   Reply With Quote
Old July 19th, 2009, 17:27   #7
Hurst89
That's how my 05.5 is, you have to hold the lock to close the windows.
Hurst
2005.5 Graphite Blue Jetta TDI, SpeedTuning Stg2 w/EGR delete, cam timing adjustment. 5spd, 81,000, Colt STG1 Billet BEW cam, CAT fuel filter, Rotella T6
Hurst89 is offline   Reply With Quote
Old July 19th, 2009, 18:25   #8
dzcad90
Rolex & gin
dzcad90's Avatar
Easy mod with VCDS. 4 or 5 checkboxes and you're in business.
Much easier and cheaper than the previous generation's Alientech solution.
Alientech was cool though because it was two clicks and you're up. No holding of the button.
- Don
'97 Jetta TDI - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Blue Graphite / Black Pleather, DSG, Sunroof, LED Tails - RNS-510, Prem Bluetooth.
VAG-COM available (Chicagoland)
dzcad90@mchsi.com
dzcad90 is offline   Reply With Quote
Old July 19th, 2009, 19:59   #9
Pelican18TQA4
You can get the windows to auto-close with the remote. I programmed it on my car, my mom's '09 Jetta, my previous '08 R32, a friend's '07 GTI, my aunt's '07 Jetta, my mom's previous '06 Passat, and various other '05.5 and '06 cars. You hold the lock button until the windows start to roll up and then you can let go and they will continue to close. When all the windows are up the hazards will flash once to confirm and then the sunroof will begin to close.
"I interviewed the late Steve Yokich, then UAW president, almost ten years ago. When I suggested that Detriot might be putting too many eggs in one basket with its utter devotion to SUVs at the expense of passenger car development and asked if the union might take a position in favor of more economical cars, he started screaming at me." -Jamie Kitman, Automobile
Pelican18TQA4 is offline   Reply With Quote
Old July 20th, 2009, 10:09   #10
J-Bob
J-Bob's Avatar
TDI(s): '09 JSW TDI
Fuel Economy: 32-36 MPG
Talking VAG-COM Help
I'm in Delaware County. Is there any chance we could get together and do mine too??? Please? I'd be more than happy to travel to you.
2009 Jetta Sportwagen TDI, Build Date 03.09
Reflex Silver, Anthracite
Pano Roof, 6M, Navi, Avignons
Took delivery on 4/21/09
Former Vehicle:
2002 Blue Jetta Sedan GS
J-Bob is offline   Reply With Quote
Old July 20th, 2009, 11:58   #11
Midnight Rider
Do you remember off by heart where the auto up group is located in long coding helper??
Midnight Rider is offline   Reply With Quote
Old July 20th, 2009, 14:13   #12
Pelican18TQA4
Send me a PM and we can work out the details.
Old July 20th, 2009, 14:15   #13
Pelican18TQA4
Not sure off-hand, but I can look later.
Old July 20th, 2009, 17:26   #14
Pelican18TQA4
Here are screenshots of my coding (click for larger pics):
Old July 20th, 2009, 19:24   #15
Midnight Rider
Thanks for that; found it in seconds! Like it too!
Page generated in 0.16619 seconds with 9 queries
[Output: 126.69 Kb. compressed to 105.47 Kb. by saving 21.22 Kb. (16.75%)]
