Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2009
TDIFest 2009 Discussion about TDIFest 2009 coming to Washington, DC (Dulles)on the Labour Day weekend (September 4-6th, 2009) .
Old September 2nd, 2009, 16:20   #46
TDIPOWERMAN
TDIPOWERMAN's Avatar
Fuel Economy: 50
Default Complete Sound System
I'm coming to the FEST and have a complete aftermarket sound system for sale including a sub amp components speakers and so on. Heres the link for pics and details. http://forums.tdiclub.com/showthread.php?t=255557
cheers! - Tim
Daytona Blue 2000 Jetta TDI
rocketchip 4 -- VNT 17 -- PP520's -- 11mm IP -- G60 flywheel SB stage 2 Endurance clutch -- 2.5" turbo back exhaust -- boost/egt gauges -- Ebay front mount intercooler -- 18" wheels -- Koni/elibach suspension -- -- rebuilt interior/exterior
TDIPOWERMAN is offline   Reply With Quote
Old September 2nd, 2009, 16:41   #47
Sprocket
Sprockette's hubby
Sprocket's Avatar
Default Need full size spare tire
I'm looking for the standard 14" 4 lug rim for a 96 Passat to use as a spare tire. My spare tire is almost toast and there is definitely room for a full size rim/tire. I'd rather go this route than replacing the tire on the existing spare. This way I can still go the speed limit without having to worry.
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old September 2nd, 2009, 18:42   #48
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
note that this is a wagon. the B4 sedan trunk floor is lower than the wagon floor. A full size (width) spare in the B4 sedan will create an even larger hump in the trunk carpet.
Svante Arrhenius 1896
Old September 3rd, 2009, 19:21   #49
Turbospool
Turbospool's Avatar
Fuel Economy: 57.0 mpg running average on the Jetta, and 41 mpg on the Passat
Would anyone be interested in a nice set of OEM steelies with good tire tread off my 2001 NB..... I could bring them to the fest ? $ 400.00 takes the complete set wheels/tires , set of 4.
DG racepipe, muffler/catectomy, 2.5 PP downpipe from Kerma, 3"exh., Sprint 520's, Rocketchip stage 2, Scanguage II w/ boost xguage,
2004 Passat unchained 180k on clock Rocketchip stage 2
Turbospool is offline   Reply With Quote
Old September 3rd, 2009, 20:02   #50
jettafock
jettafock's Avatar
Fuel Economy: 34.5 39 44
last call on the 04 jetta DP with Cat. you have until 930 tomorrow.
2004 Jetta TDI 17/22, RC3, 3bar, 2.5 DP no cat with magnaflow muffler after DP to 2.5 straight pipe, 17" Monte Carlo wheels, Eibach Pro-Kit Springs, Koni Yellow's, 337 front/rear brakes, GLI brushed alum. interior trim.
http://www.cardomain.com/ride/788097 2009 TDIFest Peoples Choice Winner
jettafock is offline   Reply With Quote
Old September 4th, 2009, 15:53   #51
VT_hawkeye
VT_hawkeye's Avatar
I will have some gear in the back of my car from my recent center console swap that can be had for reasonable cash offers:
  • OEM non-cupholder A4 center console, black, with ashtray; rubber armrest-blank insert not included (it's in my car still)
  • OEM black vinyl-covered A4 E-brake handle, pre-cupholder (straight front-to-back) mount pattern. No modding attempts made -- all original metal is on the mount, barring cosmetic rust. Chrome from knob has completely flaked off, but knob could be repainted easily. Vinyl cover is in good shape.
  • Black leather-topped A4 armrest, latch broken, out of an 04 GTI, with full chassis mount. No mounting bolts, cosmetic grade of C. Came from the junkyard with my console; I may still give it a try in my GL, but if you'd like it, make an offer.
I will be at TDIFest Saturday morning and afternoon only. Look for the Alaska Green 03 Jetta with Virginia Tech flags flying from both rear windows, or the 6'4" guy wearing a maroon VT shirt. It's football season.
VT_hawkeye is offline   Reply With Quote
Old September 8th, 2009, 17:12   #52
Good Ol' Boy
VeeDubTDI's Avatar
I hope you guys did pretty well with your swap meet... I saw lots of parts up for sale.
Old September 9th, 2009, 17:46   #53
SnowCub
SnowCub's Avatar
Fuel Economy: 25 mpg
I forgot to bring all my swap parts. Something about packing the car full to the gills.
I did see a few happy parts transactions, though.
2013 MB S350 Bluetec 50k miles, avg 25 mpg
2016 BMW X3 xDrive28d 52k miles, avg 34 mpg, wife's car
2010 Caterham SV 760 miles
2013 MB GL450, Big Blue, 72k miles, 17 mpg sure sounds nice tho.
...former TDI A4, B4V owner...
SnowCub is offline   Reply With Quote
Page generated in 0.16774 seconds with 9 queries
[Output: 87.68 Kb. compressed to 75.23 Kb. by saving 12.44 Kb. (14.19%)]
