Old July 14th, 2009, 10:36   #1
CSM Jetta
Default New way to change transmission fluid?
Well I'm going to get my transmission fluid changed today (maybe) but when I called the shop they said that they don't take the bellypan off and change the filter, gaskets etc. but rather they just flush the entire transmission. I thought the filter and gaskets was supposed to be changed but has anyone else heard of it being done this way?
2002 Jetta GLS TDI-SOLD
2003 BMW 330i ZHP-SOLD
2007 BMW 335i-Current, 3 pedals, FBO, e40 tuned.
Looking for another ALH Jetta to buy!
CSM Jetta is offline   Reply With Quote
Old July 14th, 2009, 10:58   #2
rackaracka
I'd be very concerned with getting a transmission flush on your 01M transmission from some shop. I am assuming you're going to some transmission shop and not a VW guru. Who knows what type of fluid they'll be putting in. The trans is described as a "Sealed System" and does not have a dipstick for checking fluid level. The fluid is a special mineral oil based product and is not compatible with other ATFs. You need the VagCom to properly monitor interal transmission temperature in order to proprely fill the transmission, and you definately want to change the filter. Do yourself a big favor and find a guru to properly service your transmission if you want it to last.
2002 Jetta Wagon TDI Auto- Reflex Silver/Leather/Monsoon
95 Dodge 2500 w/Cummins TD - Straight piped 4 "
98 Beetle TDI 5spd - Herbie/11MM/VNT17/pp520/RC3/Mcnally Gauges/SBC2 Endurance/Bilstein HD's/Dieselgeek Panzer FMJ/3" Kerma turbo back
rackaracka is offline   Reply With Quote
Old July 14th, 2009, 11:20   #3
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
^^ what he said.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old July 14th, 2009, 11:28   #4
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
ditto
Trusted TDI Mechanics Map || TDIClub Chat
Old July 14th, 2009, 11:44   #5
compu_85
Gadget Guy
compu_85's Avatar
Valvoline Dexron/Mecron fluid says on the bottle it works in VWs prior to 2006
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old July 14th, 2009, 12:27   #6
spleecho
I don't kill trees Vendor
spleecho's Avatar
Fuel Economy: Lowest 36.1, Highest 53.7, AVG 44.4
-Jason
Yea it does but it voids third party extended warranties
'99.5 Golf, 4 door, mufflerectomy, ventectomy, Inmotion Tuning Stage 2, chip and nozzles, VDO Boost Gauge, Boostvalve, Dieselgeek oil bypass kit, Scangauge II
AMSOIL Dealer
My VIDEO on how to install the Boostvalve
spleecho is offline   Reply With Quote
Old July 14th, 2009, 12:30   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I flush them all the time, but use the correct VW ATF, Pentosin branded. We have adapters for the banjo bolts on the cooler.
However, with the 01M it is always best (IMHO) to drop the pan and see if any large chunks are looming.
oilhammer
www.cardocautomotive.com
Old July 14th, 2009, 13:58   #8
CSM Jetta
well after having the shop look at the transmission they are going to hook it up to the vagcom tomorrow and check for codes.
No fluid was changed today as they thought they could fix the problem without doing so and the fluid looked good according to them.
I'm going to take the car in tomorrow and see what they find out then post here
thanks for the info and advice!
Rackaracka- I was looking for a guru in my area but the place i checked in raleigh wanted $300+ to do a fluid swap. Which to me seemed really high but I didnt get any feedback here when I asked what a transmission fluid change normally costs so i have nothing to compare it to.
Old July 14th, 2009, 19:46   #9
CSM Jetta
Okay so after asking what it would costctlchook up the vagcom I decided to find someone in th area who has one that I can hook upto for a few minutes to see If any codes are showing. Anyone know or a vagcom in th triangle that I could go visit?
Old July 14th, 2009, 19:47   #10
rackaracka
CSM - Sorry you don't live in NJ or I'd tell you to head over to my place. This job is not that difficult, but it is a bit time consuming (probably 2 hours) which might be why that shop is charging so much. Besides cleaning everything well and re-assembling, it is time consuming to pump fluid into the trans, run the vehicle and cycle thru the gears, and then wait for the transmission temperature (on vagcom) to get to specific range... Then, you put a plug in to stop the overflow pipe from draining.
Here is an awesome post from Drivbiwire that details this whole process so that you can get a better education and at least know what you're potentially hiring someone to do.
http://pics.tdiclub.com/members/driv...0Procedure.pdf
Page generated in 0.17178 seconds with 9 queries
[Output: 98.13 Kb. compressed to 83.12 Kb. by saving 15.00 Kb. (15.29%)]
