You have to start by removing the little plate that surrounds the 110v plug. There's a slot at the top to pry it off. Behind the plate are two screws that have to be removed. When they're out, pull the back of the console (the part with the vents on it) off and disconnect the the inverter wiring harness. You've now exposed four more screws to be removed, two on the sides and two on the bottom.
Once all the screws on the back of the console are removed, we now go to the inside. Pull the lid up to access the aux plug. Pry the aux plug out and disconnect the harness. Now pry out the square plastic plug above it and remove the screw it covers. Pull up the parking brake lever and you can now remove the console compartment.
When the console frame is exposed, you'll see the duct for the rear a/c. Pull it up until it snaps out of it's retainer. It doesn't have to be removed. There are two screws on the bottom that have to be removed. Move the duct to the side and remove the screw underneath it. Push the duct back and remove the screw on the other side.
You can now raise the console frame enough to adjust the p/b cable. I use a socket to keep the frame propped high enough to reach the adjustment nut. I tried adjusting the cable per the Bentley, but it didn't work with my '09, so I just loosened the cable 'til I got 6-7 clicks on the p/b lever.
