Orders TDI Club Cards TDI Fest 2009 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
User Name
Password
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Thread Tools Search this Thread
Old July 2nd, 2009, 16:46   #1
VLS_GUY
Default Prius Headlight Bulb Co$t$ at the Toyota dealer
All love affairs must come to an end and the one between Prius owners and Toyota is coming crashing down over HID Headlight bulbs burning out short of their anticipated lifespan. A burned out HID is not big deal right? A replacement HID bulb and pair of latex gloves-worth $15.00 fixes the problem-Wrong! The dealers are charging $350.00 for each bulb and $200 to install; freaking the owners out. The bigger issue now is when the HIDs continue to show premature failure the controller is being replaced for $1,100.00. Angering the owners that bought the car on Toyota reliability.
Yes the lawyers are talking about class action. The outcome should be interesting for those seeking balance shaft assembly replacement compensation.
Check out the issue in a Pruis chat room: http://priuschat.com/forums/gen-ii-p...t-problem.html
VLS_GUY is offline   Reply With Quote
Old July 2nd, 2009, 17:41   #2
RabbitGTI
RabbitGTI's Avatar
Having a microprocessor run the headlights is not progress.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5
RabbitGTI is offline   Reply With Quote
Old July 2nd, 2009, 18:04   #3
Joe_Meehan
Joe_Meehan's Avatar
And all this is because they need HID lamps? Why?
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old July 2nd, 2009, 19:31   #4
VLS_GUY
I read further down the thread and one dealer replaced a $1,100 controller before replacing the lamp! The magic price seems to be $1,100 since the head light assembly also costs $ 1,100. The owners are grasping at straws with theories blaming the PWB in the head lamp assembly and other wanting a heavier gauge wiring harness. To me this looks like a poorly through out lamp control strategy in an attempt to make the lights as bright as possible.
The sad part of this for Toyota is that Advertising Age ran the story before the automotive press. If Ad executives are running pieces like this then Toyota is in big trouble.
Old July 2nd, 2009, 19:50   #5
RabbitGTI
RabbitGTI's Avatar
They probably save energy and therefore are Green
Old July 3rd, 2009, 05:32   #6
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
If the Prius shares this part with other models I could see where the price is high. If this is a specialized Prius only part, it will be pricey to produce and supply, hence the cost. A good question would be whether there is a workaround to this problem, so one could use an aftermarket solution (doesn't the Prius chat have such technical info?).
Dealership service is not free: http://forums.tdiclub.com/showthread.php?t=259601
Free Bonus Service from VW http://www.youtube.com/watch?v=qdFLPn30dvQ
[quote=AN-UN-NAMED-WVO-GREASER] "In the future, please not be so ignorant....." <-----
MY A5 2009 Jetta (INTERIM RIDE) http://forums.tdiclub.com/showthread.php?t=256510
MY A4 Sold: http://forums.tdiclub.com/showthread...03#post2282603
Meet MuffY, my A3: http://forums.tdiclub.com/showthread.php?t=260253
thebigarniedog is online now   Reply With Quote
Old July 3rd, 2009, 05:38   #7
oilhammer
oilhammer's Avatar
Send a message via MSN to oilhammer
Nothing new, saw that at Lexus all the time. We also had the LED tail lamp assemblies on the RXs die frequently too.
The HID failures were why Lexus instituted a TSB/recall on installing these anti-theft brackets on the RX's headlights, since people were steeling them. Since the RX is made of thin metal and tinker-toy plastics, you can quite literally walk up to one and with little more than a medium sized screwdriver bust the headlight assemblies right out from the front of the car in just a few seconds.
But the frequent failures and stupid high prices dictated the high theft rate. I would imagine the same may happen with the Prius.
oilhammer
www.cardocautomotive.com
Has your B5 TDI gone chainless yet?
Old July 3rd, 2009, 05:43   #8
dieseldorf
top post dawg
dieseldorf's Avatar
The dealers, regardless of marque, charge huge money to replace an HID bulb.
It's unfortunate, but changing bulbs in some of these newest cars is no small feat of assembly/disassembly to access the darn bulb.
I think only the upscale Prius has HID lights, the base models don't.
dieseldorf is online now   Reply With Quote
Old July 3rd, 2009, 07:34   #9
VLS_GUY
Bryan is correct in that a lucrative market in parts warm to the touch has developed for all Toyota hybrids. This forced the addition of anti-theft brackets and more time to R&R.
The real solution to this problem is going to come from the owners themselves by taking responsibility for understanding how to repair their cars and then doing those repairs they can do themselves.
Old July 3rd, 2009, 10:09   #10
oilhammer
oilhammer's Avatar
Lexus owner's doing anything themselves? Hybrid owners? Hybrid Lexus owners? No way!
You'd be floored how many Lexus owners would drive 40 minutes just because the TPMS light was on, just because the tires were a wee bit low from a rapid temp change.
Or all the RX owners that would complain that the power rear door would not close, yet the carpet mat stuck in the floor latch pin (plain as day, right out in the open) needed to be shoved back in place.
Or the "CD changer not detected" error message on the radio, only to find the door to the CD changer magazine holder was not shut .
Or the 'my cupholder is broken' because they spilled their morning Starbuck's Latte in the console.
Or my personal favorite, 'the air conditioner won't work' and you get in the car and the climate control temp is set to 85 F on a 75 F day.... DURRRRR.....
Yeah, I would not want nor expect anyone with a Lexus to change their own light bulb. But they typically have earned the income necessary to pay someone else to do pretty much every menial plebian task in their lives so we all have our place.
oilhammer
Old July 3rd, 2009, 14:17   #11
VLS_GUY
Well I was not thinking of Lexus owners... One of my wife's pal has an RX330 and if the guy doing the regular service can not see a problem then hey man, no worries! She thought tires were part of the maintenance package you get when you buy the car. When I was called out due to a flat I pointed out the racing slicks she was using. She bought new rubber but afterward said the car should personally email you every time it needs something. How about having HAL from 2001 speak interactively to the driver that would work even better...
Old July 3rd, 2009, 21:27   #12
lovemybug
I'm sorry, Dave, I can't do that.
2002 Red New Beetle TDI, auto tranny.
Mods so far:
Coolant migration mod, Ventectomy, Kerma line pressure mod, Euro headlight switch, Modded relay DRL disable
Nokian I3 205/55/16 tires for summer
I can't believe how much crap I can fit in this thing.
The US government doubled the national debt in less than a year and my arse is even more sore.
lovemybug is offline   Reply With Quote
Old July 4th, 2009, 08:02   #13
Powder Hound
Powder Hound's Avatar
More likely a mucky-muck at Advertising Age got stuck with one of these high bills and got p.o.'d.
'00 Golf, '01 Jetta - now fortified with ASR, both 5sp, very few mods.
Powder Hound is online now   Reply With Quote
Old July 5th, 2009, 14:15   #14
phazersonstun
Dude! I can't believe people want something else to take responsibility for their possessions and actions. An email? Really?
phazersonstun is offline   Reply With Quote
Old July 5th, 2009, 16:29   #15
TurbinePower
Send a message via AIM to TurbinePower
Things like this are why I'm seriously all in favor of there being a "Basic skills and maintenance" section of the driver's license exam. Change a tire, pop the hood and go over some basics like checking the oil and the transmission fluid, be able to answer questions about the basic function of the vehicle and more common failures (blowouts and similar, not "running out of oil and engine seizes up" or "what to do when you a knock on piston #4"), things of this nature to prove to your examining officer you have a flipping clue.
Originally Posted by FL2AK-tdi
I just wish that it would stop breaking. If I could go one OCI without something breaking, I would be a huge VW fan lol.
Small stable of VWs (projects)...
'80 Dasher Diesel, full restoration in the slow burner works
'82 Quantum "Coupe" 1.6 CIS gas power, daily driver
'89 Fox wagon (Korva!), the new back porch project. Suspension and interior work in progress!
TurbinePower is online now   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 1996 - 2007, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.09007 seconds with 10 queries
[Output: 98.43 Kb. compressed to 91.20 Kb. by saving 7.24 Kb. (7.35%)]
