Old June 29th, 2009, 07:15   #1
brianewman
Default '02 Jetta won't start when hot
I have a stock 2002 Jetta TDI 5-speed manual with 157K miles. All was well until about a week ago, when it refused to start when it was hot. After cooling down, it started right up. I took a couple of short (~ 1 mile) trips and all was well, but after driving a significant distance it would not start again.
When it's hot, it cranks and cranks but will not fire. (The glow plug light comes on, so it's not relay 109.) Since this initial trouble I have also noticed a loss of power, especially when climbing hills, and increased difficulty starting even when cold or warm. Also, once after a long drive it died when I slowed down exiting the freeway. I had to leave it there for a couple of hours until it cooled down and then it started right up.
The clear fuel line gets quite a few bubbles after trying to start it, but it's never empty.
I have 73K miles on the timing belt. Could that be it? My mechanical ability is limited and I'm short on funds right now so I don't want to replace the timing belt yet if that's not going to fix it. I can only afford one repair at a time. BTW, I could also use the name of a trusted TDI mechanic in Houston (preferably on the south-east side). Anybody know one?
brianewman is offline   Reply With Quote
Old June 29th, 2009, 08:23   #2
sisyphus
sisyphus's Avatar
Wellll...
The hot starting problem woulnd't be your timing belt. But since you mention it I might as well be the first to point out that if you don't want to do the timing belt if it won't fix your current issues, you will rue that decision when the belt or related component fails, usually with catastrophic and predictable results.
That being said, the hot start issue can be solved by doing what I believe is called the Hamman mod; it puts a 10,000 Ohm resistor in a switch connected in series to the coolant temp sensor. You could do that, it wouldn't hurt certainly, its easy and costs about five bucks and takes probably about an hour tops. That may solve the hot start issue, but seeing as your problem is much more pervasive you could have other issues at work. Clogged fuel filter? Bad MAF? Getting any codes? CEL on? Faulty cap vent?
sisyphus is offline   Reply With Quote
Old June 29th, 2009, 08:55   #3
brianewman
I'm going to get the timing belt replaced soon. I just can't do that and fix something else this month, unless this turns out to be a cheap fix.
I forgot to mention that I tried to start it with the coolant temperature sensor disconnected and had the same results. The only codes I get are for the glow plugs and they have been on for years.
I'll check the MAF and cap vent tonight. Thanks for those suggestions.
Old June 29th, 2009, 09:09   #4
oldpoopie
oldpoopie's Avatar
When you are cranking, trying to start the car, does it sputter or try to fire at all? Do you get smoke out the tailpipe?
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old June 29th, 2009, 09:36   #5
brianewman
No sputtering, no firing, just crank crank crank. didn't notice any smoke.
Old June 29th, 2009, 09:47   #6
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
When it's hot, and won't start, disconnect the wire and check the resistance across the solenoid on top of the cast iron piece on the injection pump.
It should be fairly low, but I forgot the precise good value. Then check that battery or near battery voltage appears at that wire when starting.
Sisyphus, the ECT bypass is not appropriate for a 2002 since the starting bug was corrected after 1999.
jcrews is offline   Reply With Quote
Old June 29th, 2009, 12:19   #7
oldpoopie
oldpoopie's Avatar
ditto. I'm suspecting fuel shutoff solenoid is getting stuck when hot and releasing when things cool off.
Old June 29th, 2009, 14:22   #8
sisyphus
sisyphus's Avatar
Originally Posted by jcrews
...the ECT bypass is not appropriate for a 2002 since the starting bug was corrected after 1999.
I stand corrected.
Old June 29th, 2009, 20:38   #9
Funguy
Fuel Economy: 47 mpg
I had this same problem last year. Clean the ASV. No problem with a cold engine but Mine would get sticky when the "goop" got warm and would fail to reset after engine shut off. I cleaned it, CAREFULLY and haven't had a lick of trouble since.
Guy
Funguy is offline   Reply With Quote
Old June 29th, 2009, 20:45   #10
brianewman
I learned two things today.
1) I learned what a MAF sensor is and where to find it
and 2) I learned that I am an idiot and should have checked the fuel cap before posting on here.
Thanks everybody for the suggestions. I guess sisyphus gets credit for this one for mentioning the cap vent.
Old June 29th, 2009, 21:47   #11
Funguy
Glad you solved the trouble but if it happens again you might play with the Anti-Shudder Valve and see if it feels sticky.
Old June 30th, 2009, 21:38   #12
TornadoRed
TornadoRed's Avatar
www.dieselgeek.com , when you are ready for that timing belt. The "recommended mechanics" thread has one or two suggestions for Houston.
Since you know about coolant temp sensors and the main engine power supply relay 109, you are not an idiot.
'03 Golf with 693k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilsteins, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Nokian snows, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Page generated in 0.18174 seconds with 9 queries
[Output: 103.96 Kb. compressed to 87.18 Kb. by saving 16.78 Kb. (16.14%)]
