Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old June 22nd, 2009, 17:39   #1
Tim_Mackinlay
Fuel Economy: 57 mpg
Default Where is the headlight relay MkIV
The wife's 2004 Golf headlights (Low beam) quit.
The is no voltage at the light socket.
Does anyone know where the relay is located?
I see that 173 is the DRL relay, But swapping it did not make a differance.
Tim
2005 Golf Tdi Gls Blue
2004 Golf Tdi Gls Black
1994 Mazda 323
1977 Honda Goldwing
1967 Piper Cherokee (deceased)
1977 Grampian Sailboat
Tim_Mackinlay is offline   Reply With Quote
Old June 22nd, 2009, 17:45   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.9-5.5 l/100
Tim, did you check the fuses?
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).__________________
jason
2010 Tiguan 6M wifes commuter
2010 Golf Wagen Comfortline 6MT
JASONP is offline   Reply With Quote
Old June 22nd, 2009, 17:50   #3
Tim_Mackinlay
yes, checked the fuses. Both ok. There is full battery voltage to the fuses.
1994 Mazda 323
1977 Honda Goldwing
Old June 22nd, 2009, 18:09   #4
JASONP
JASONP's Avatar
I knew you would, have but had to ask.
Did some searching and found also maybe the Turn/Flash/Cruise Combo switch, but no luck on the location of the relay
jason
Old June 22nd, 2009, 18:18   #5
Tim_Mackinlay
False alarm, It was the bulbs. Sheesh!!! Both at once!
First time for everything I guess.
Tim
1994 Mazda 323
1977 Honda Goldwing
Old June 22nd, 2009, 18:19   #6
JASONP
JASONP's Avatar
Tim
I did see a thread on that as well, weird
Oh well
jason
Old June 22nd, 2009, 19:08   #7
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
Nothing chews up headlights faster than a mk4 golf.
I've had a pair of bulbs go in a couple of months... out of the package to landfill far too fast for my liking.
They tend to most often go pop when they're full off, and you turn on the headlights without dropping the parking brake first. Fully cold to full voltage is not so good with h7 bulbs.
johnnloki is offline   Reply With Quote
Old June 23rd, 2009, 11:31   #8
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. in Mexico Nov 2012 to April 2013
Fuel Economy: About 45 Mpg combined
That's one of the nice things about having a Euro switch. I am using an aftermarket HID kit and to extend the life of the bulbs, I only use my parking lights in the daytime. It has become an instinctive habit for me to turn the switch to the 12 o'clock position before starting the engine. Also when I shut the engine off I return the switch to 12 o'clock if I have been driving at night and then when the key is in the off position turn the switch to the off position.
The reason I follow this procedure, I have noticed the lights go off and momentarily come on again before shutting down altogether. Not too good for the bulbs.
02 Jetta TDI auto,Unitronic, .205's,ARP studs,CCV,Ventectomy,Altezza Tails,M3 type spoiler,Euroswitch,Chrome grill,Dashtrim wood,Backup sensors,PhatBox,Evo Skidplate.
Jetta_Pilot is online now   Reply With Quote
Old June 24th, 2009, 09:10   #9
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
Euroswitch + rewire. I never use the headlights for DRLs anymore.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old June 24th, 2009, 09:27   #10
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
For the record there is no relay for the headlights on any VW up to the mk5, all the power goes through the headlight switch.
-Jason
Present:
2012 Passat SE TDI DSG. 24,000 miles. Factory Alarm & LED tails 38/48 MPG.
99.5 Jetta "GLX" TDI. 289,000 miles. Half way there!!! Power Memory Seats, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 222,222 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
compu_85 is online now   Reply With Quote
Page generated in 0.13904 seconds with 9 queries
[Output: 97.59 Kb. compressed to 82.46 Kb. by saving 15.13 Kb. (15.51%)]
