Closed Thread
Old June 5th, 2009, 11:15   #1
hyperhyper
hyperhyper's Avatar
Default Xylene vs Acetone for TDI?
I've seen some posts on the use of acetone as a diesel fuel additive. Anyone with experiences or knowledge about using Xylene? I've heard it's used in a lot of gassers.
hyperhyper is offline
Old June 5th, 2009, 11:25   #2
dieseldorf
top post dawg
dieseldorf's Avatar
http://forums.tdiclub.com/showthread.php?t=121640
dieseldorf is offline
Old June 6th, 2009, 08:02   #3
TornadoRed
TornadoRed's Avatar
Fuel Economy: 52/41/36 (685k miles)
http://forums.tdiclub.com/showpost.p...6&postcount=42
'03 Golf with 685k miles: Bosio DLC 764, GT1749VB, Passenger Performance 2.5" DP, Malone tuning, VR6/G60 clutch/flywheel, Bilsteins, Recaros, Akebono pads/Zimmerman rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Nokian snows, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
TornadoRed is offline
Old June 6th, 2009, 16:07   #4
naturist
Why add racing gas to diesel fuel?
naturist is offline
Old June 8th, 2009, 10:06   #5
Dimitri16V
Dimitri16V's Avatar
it's also a good solvent. Diesel Purge contains Xylene
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline
Old June 9th, 2009, 01:17   #6
highender
highender's Avatar
Fuel Economy: max 51 mpg
yes, you can add a little bit of xylene or acetone to diesel...or even biodiesel....to improve combustion and clean out the nozzles and chamber. with low sulfur diesel....there is less or no need to add this in any frequency.
however, if one chooses to add other chemical additives, only a small amount is needed. I add no more than 4 oz to the whole tank...so only 4 oz to 12 gallons.
you are your own warranty in doing so.
2000 Jetta TDI, Vnt17, FMIC, Kerma full exhaust, tuned, .205,
2012 Jetta TDI- Premium Nav. My kids' car now..
2002 Jetta TDI -RIP 6/15/12.
2003 Jetta TDI wagon, 01M sold [/COLOR]
highender is offline
Old June 9th, 2009, 04:52   #7
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Unless you are using some kind of junk fuel, chances are you are getting all the additives you can use right now. Of course there are exceptions. Do you have any reason to believe you need something more?
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline
Old June 11th, 2009, 13:30   #8
hyperhyper
hyperhyper's Avatar
No specific reason. Just looking to run cleaner and have better MPG.
Old June 12th, 2009, 08:09   #9
naturist
Please understand that xylene has an octane rating of around 120. It is one of the aromatic compounds best removed from diesel fuel, and in fact removed from the best diesel fuel. Its addition is as bad an idea as adding racing gas. In fact, racing gas is likely to have elevated levels of xylene, since it has such a high octane rating.
naturist is offline
Old June 12th, 2009, 14:22   #10
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
Acetone is a banned subject.
Xylene has a very high octane rating and no lubricity, bad for diesel fuel. Xylene is highly toxic if one inhales any vapors and is also easily absorbed into the skin, bad for humans.
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline
Closed Thread
Page generated in 0.14682 seconds with 9 queries
[Output: 89.16 Kb. compressed to 74.88 Kb. by saving 14.28 Kb. (16.02%)]
