Old June 3rd, 2009, 10:06   #1
katoslowhand
Default Front end shutter 06 Jetta TDI
I have a 06 Jetta TDI. When I take off the front end shutters just at low speed. It has new tires on it, but it feels fine at high speed. Any body?
katoslowhand is offline   Reply With Quote
Old June 4th, 2009, 14:30   #2
Powder Hound
Powder Hound's Avatar
Does this happen just when you are letting out the clutch? Shudder when you hit the go-pedal? Does it quit when you let off the pedal?
If this is what is happening, I'd check your inner CV joints.
How many miles on the car?
There is a possibility that the torque mount (aka dogbone) could be causing this - a general vibration felt as shudder through the steering.
I just replace the dogbone on my Golf. The unit that was replaced seemed OK, but afterward, it was much smoother on initial takeoff.
And a different car I (temporarily) own, a 2001 Jetta, had a shudder when you pushed on the go-pedal that disappeared when the CV joints were swapped side to side.
I would be greatly surprised if your '06 has as many miles as either of the cars I just mentioned above, however, as one is at 180k miles and the other at 237k miles. And mileage would be the prime factor in either CV joints or dogbone giving up. Manufacturing defects do happen however, so it would be good to check these items.
Other possibilities aren't any fun either. The other ones I think of are DMF flywheel troubles and something loose in the front end gear such as a tie rod, ball joint, strut bearing, or other suspension components.
Old June 6th, 2009, 16:28   #3
katoslowhand
Today it is worse. When I am under power it shudders hard and loud till I let off. I will take it in to be looked at Monday i hope. It feels like a choppy road. But it is not.
Old June 6th, 2009, 20:24   #4
Cappy
Cappy's Avatar
TDI(s): 2006 Jetta
It feels like something is slipping right ? Its starting to happen to my 06 auto/DSG Jetta TDI as well. Just very slight as of now and doesn't happen every time i take off from a stop
05.5/06 Jetta TDI ,DSG.
Cappy is offline   Reply With Quote
Old June 6th, 2009, 20:56   #5
velociT
velociT's Avatar
I would guess failing DMF or broken axle.
TDT for PD Mafia Member #002
Then: 06 Jetta TDI 5M *sold*
Now: 17 Ram 3500 CTD, 87 M35A2C
velociT is offline   Reply With Quote
Old June 7th, 2009, 06:16   #6
katoslowhand
Cappy. Yes that's what it feels like. What can it be?
Old June 7th, 2009, 07:31   #7
Cappy
Cappy's Avatar
TDI(s): 2006 Jetta
I wish i knew buddy. im not thinking its a broken axle or it would sound and feel way worse then that more often
It could be a failing DMF like velociT says . Whatever DMF stand for .
Old June 7th, 2009, 10:13   #8
velociT
velociT's Avatar
Dual mass flywheel. Do a search, there have been many, many threads.
Old June 14th, 2009, 17:22   #9
katoslowhand
well turns out it was a outer CV joint $450 later.
Old June 14th, 2009, 20:02   #10
Cappy
Cappy's Avatar
TDI(s): 2006 Jetta
Glad to hear ya got her all fixed up. Was it making (clicking) noises as you turned sharp to one side ?
Old June 15th, 2009, 09:30   #11
katoslowhand
nope no clicking at all, thats what had me confused.
Old June 15th, 2009, 13:42   #12
Cappy
Cappy's Avatar
TDI(s): 2006 Jetta
Weird
Page generated in 0.14744 seconds with 9 queries
[Output: 100.97 Kb. compressed to 83.90 Kb. by saving 17.07 Kb. (16.91%)]
