Old June 2nd, 2009, 17:07   #1
Sprocket
Sprockette's hubby
Sprocket's Avatar
Default PD130 / PD150 Intake Manifolds
Does anybody have a list of engine codes for the European VW/Audi vehicles that would have PD130 or PD150 manifolds? I may have a source of getting some manifolds from Germany if I can give said person the engine codes. All I have at the moment are:
AFN
ASZ
ARL
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old June 2nd, 2009, 17:39   #2
Rub87
afn is wrong.. BXE BKC, BLT, AWX AVF, BLT etc all use them too.. to many to sum up..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old June 10th, 2009, 04:51   #3
struikie
struikie's Avatar
TDI(s): BMW 335d E91
check if you need a left or right facing one
JW
struikie is offline   Reply With Quote
Old June 14th, 2009, 14:01   #4
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
which engine codes used the left facing one?
02 Jetta, 17:1 CR 81mm ASV, Colt cam, Peloquin LSD, Raxles, FueLab pump, 12mm/DE143, Gibonta 5 x 0.018, NX nitrous, 6+6 turbo, Bilstein coilovers
MKVII GTI 6MT, full build, 525hp
MKVII GLI DQ381, 93 tune only, daily driver
loudspl is offline   Reply With Quote
Old June 15th, 2009, 04:05   #5
Rub87
AWX AVF abd some others
Old June 15th, 2009, 06:42   #6
devonutopia
devonutopia's Avatar
The UK pd130 & pd150 all have the manifolds pointing to the left (as you look at the engine from the front) See mine for comparison. This is an ASZ manifold, although no longer "stock"
Jason - Skoda Fabia TDI project
http://www.youtube.com/watch?v=TOE4nbT5NGY 315bhp dyno run video of my car.
http://www.youtube.com/watch?v=8R5c496IG1Q Skoda Fabia GTB2260vk in-car acceleration video!
http://www.devoncardetailing.gb.net/
devonutopia is offline   Reply With Quote
Old June 15th, 2009, 08:58   #7
fenwick458
fenwick458's Avatar
TDI(s): '12 T5 Van
AWX and AVF are longditudnally mounted and the intake manifold part numbers are 038 129 713 AJ or 038 129 713 AG pictured below.......
and ARL, ASZ, BPX are the normal style intake manifolds that go to the left, p/n 038 129 713 AF pictured below
and the others mentioned BXE, BKC, BLS & BLT are from the mk5 "105" and the AXR engine
P/N 038 129 713 BC, pictured below
note that the "BC" intake has a different stud pattern to the EGR. the other ones i mentioned above all have the same stud pattern and will accept the large bore EGR(of which theres 2 versions, one from a long engine and one from a transverse, difference is the side which the actuator is mounted on)
but if you get a "BC" intake you will have to specify this when buying your racepipe, street toys sells a BC racepipe
and then there are 2 more intake manifolds which i have recently found, i have no idea where they came from but the part numbers are 03G 129 713 B and C
03G 129 713 B has the same EGR bolt pattern as the regular pd150/pd130 intake 038 129 713 AF
03G 129 713 C has the same EGR bolt pattern as the AXR manifold 038 129 713 BC
fenwick458 is offline   Reply With Quote
Old September 27th, 2010, 12:45   #8
G60ING
G60ING's Avatar
Is it feasible that a BC's EGR valve could fit on a Passat PD 130 intake manifold (038-129-713-AJ or 038-129-713-AG) with only minor modification of the holes on the EGR? Maybe I could slot them or would the o-ring on seat on the intake manifold's flange?
The reason why I ask is because I want to use an EGR valve without the shutdown flap on my mk3 AHU. here is the EGR that I want to use: http://cgi.ebay.co.uk/VOLKSWAGEN-GOL...item4152221e42
G60ING is offline   Reply With Quote
Old September 28th, 2010, 06:32   #9
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
Great info fenwick... I've got the ARL (038 129 713 AF) version and am having a time finding a proper EGR and upper charge hose for it. You don't have any good leads or part numbers I can pursue do you??
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old September 28th, 2010, 07:20   #10
RomSL
RomSL's Avatar
You need EGR with this part-number 038131501AT. But you also will need new elbow hose 1J0145838AF
Skoda Octavia 2007 1.9TDI AGR / VNT17 / R520 / 3 bar MAP / EGR deleted / cat deleted / 10mm / ASV software / PD130 Intake / PD130 Oil cooler / G60/VR6 Clutch
RomSL is offline   Reply With Quote
Old September 28th, 2010, 07:56   #11
FlyTDI Guy
FlyTDI Guy's Avatar
Awesome, thanks...
Old September 28th, 2010, 08:48   #12
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Great pics Fenwick. I've noticed you seem to have pics of all those hard to find parts for some odd reason!
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old September 28th, 2010, 16:07   #13
fenwick458
fenwick458's Avatar
TDI(s): '12 T5 Van
yes, minor modding of the holes on the EGR would work no problem, one of the holes will need ovalling 1-2mm.
are you sure that EGR in the picture on the ad is what you will get? it looks to me like they have loads of different EGR's, you give them your engine code and they send you an EGR.
Old September 28th, 2010, 19:09   #14
G60ING
G60ING's Avatar
I don't think I'm going to use that ebay auction. slow-moe posted that the part number is 038-131-501-AN I think that I'll buy it through worldimpex.com when I order some other parts for my turbo conversion.
Old February 21st, 2011, 23:53   #15
dawooda3
Fuel Economy: 43-46
what one would i want for my 03 tdi....
2003 TDI Jetta Charcoal Gray, T4 Injectors. 5 Light Brake Mod. 205/65/R15 tires, Scan Gauge II, EGR delete caddy and muffler delete, cold air box, kerma tdi tuner, 223k miles
2000 TDI Jetta Royal Blue all original with 350,000miles, 205/65/R15 tires
dawooda3 is offline   Reply With Quote
Page generated in 0.18386 seconds with 9 queries
[Output: 127.67 Kb. compressed to 105.88 Kb. by saving 21.79 Kb. (17.07%)]
