Old May 23rd, 2009, 21:41   #1
otm646
Fuel Economy: 54/48.5/43
Default PD 150 intake manifold on stock A3/AHU
I recently acquired a PD 150 intake manifold and an ALH race pipe from Peter at TDI parts.
Note I sawed a stock manifold in two. I will post photos of the flow restriction shortly.
Installation: fitment is a stock drop in with the EGR Deleted. I did not attempt installation with EGR installed.
The ALH race pipe will work with no modification but is not optimal. The race pipe is to long which moves the upper charge air pipe about 3/8ths of an inch towards the drives fender. This prevents the installation of the screw, nearest the fire wall, which secures the charge air pipes together.
Note Inability to insert screw.
I will have the revised race pipe fabricated within the week so peter can make the manifold completely drop in.
Performance gains: On a stock tune I was not expecting much. I was significantly surprised. A stock tune falls on its face with a rapid drop in power at 4k rpm.
With the only modification being the addition of the manifold the car pulls to 4400-4500rpm.
Economy: previously the car averaged 48.6. I am interested to see if the average changes with the new manifold installed.
Specifications:
1998 Jetta AHU 210k
EGR delete
Original injectors
Stock downpipe, stock flow replacement CAT, 2.5 stainless straight pipe from the CAT back
76 300d 475k
97 750IL V12 working SLS 187k!
98 Jetta AHU 330k! PD150 intake 2.5 SS straight pipe- Sold to Papa Validius
05 WRX 5 speed wagon 220k + flow mods ~270 HP
81 Lancia Beta Zagato
otm646 is offline   Reply With Quote
Old May 23rd, 2009, 22:19   #2
Whitbread
Whitbread's Avatar
TDI(s): Several
Hmmmm, that car looks familiar . Did you get the last hangar welded on?
Very nice to hear the gains! I'm sure they would be even more apparent with a tune.
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old May 24th, 2009, 14:57   #3
Stealth TDI
Pre-Forum Veteran Member
Stealth TDI's Avatar
Hello,
Can the screw misalignment be minimized by shoving the hose further on to the racepipe or perhaps cutting the hose? I'm expecting to have one of these intakes soon. I suspect I will need to get it beadblasted before I install it (looks like it has a good coating of soot/oil/goop). Given the gains you report on a stock tune, it'll be interesting to see if I find an improvement at the top end with my mods. It would be REALLY cool if smoke is reduced even a little. I'm a freight train at WOT!
Stealth TDI is online now   Reply With Quote
Old May 24th, 2009, 15:39   #4
Rub87
you don't need that bracket.. have cars running for years without, doens't hurt anything..
aside from that, I have the same manifold, also inlet to drivers side, and with mine the stud is at the top of the 90 bend, more like the oem location.. stange yours is different..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old May 24th, 2009, 17:32   #5
otm646
I'm looking to make the solution 100% drop in.
I'v measured the amount i need to turn off the race pipe to make it fit. No reason to go thru all the work to procure and install it to not finish the job and make it totally drop in.
I'v got a guy locally to weld that hanger.
76 300d 475k
Old May 25th, 2009, 17:07   #6
Jon Linn
With the PD150 intake, did you completely gut out the EGR cooler and all its hardware? Also, I have thought about using 2" Stainless Steel for the double intercooler piping that runs from the intake to the intercooler? That would fix the problem as well, but be a little more $$$. Also, what made choose to use that intake rather than the AFN style that the euro A3's used?
thanks,
1997 Jetta: sold
2002 NB (my car): 160,000 miles - AltiMAX HP's, Koni S.T.R.E.T. with 2" lift and TDITuning chip.
2002 Passat 1.8t Wagon (Wifes): 125,000 miles AltiMax RT's
Jon Linn is offline   Reply With Quote
Old May 26th, 2009, 05:57   #7
validius
Lacking in ZDDP
TDI(s): 1997 GTI TDI
thanks,
I'm working with Tom on this project so hopefully i can speak for him here.
the EGR cooler and all its hardware is gone, there is a blockoff place on tghe exhaust manifold.
Stainless would be nice for those pipes.
I got these manifolds because a rough visual inspection of pictures on the internet made them look better. Also, the PD150 manifolds support 150HP stock and the AFM manifold supports 110HP stock. It seemed like the logical thing to do...
1987 BMW 325IC, 115K miles. OEM+ or bust
RIP 1997 Golf 'GT' TDI 201,000 miles. TDI Engine/trans from "Rustetta"
validius is offline   Reply With Quote
Old May 26th, 2009, 06:34   #8
Jon Linn
Support; as implying that just by switching out intakes to the PD150 a person could gain 50-60 hp? Could you explain a bit more, please? Aso, what is the cost comparison between the AFN and PD150 manifolds?
1997 Jetta: sold
Old May 26th, 2009, 07:16   #9
otm646
http://www.audi-sport.net/vb/showthread.php?t=66969
I'm assuming this is an AFN manifold. If I'm mistaken let me know.
The AFN manifold looks to be similar in design to the AHU. The AHU/AFN manifold has almost no runners.
The AHU manifold has a large restriction where it makes the 90 degree bend down into the plenum. The PD 150 manifold has no such restriction.
With the PD 150 manifold the EGR is removable eliminating the intake restriction of the EGR assembly.
TDIparts is looking at making a custom race pipe for this application. durring fabrication, or even after, it is simple to make the length adjustment.
The cost is likley similar for either manifold if you could source them used.
validius said that the PD manifold flows enough air for a 150 HP stock vs 110 hp for the AFN manifold. This would infer that the PD 150 manifold is better flowing to to support the higher hp output. I agree.
76 300d 475k
Old May 26th, 2009, 07:16   #10
Growler
Got Soot Vendor
Growler's Avatar
More like support, as in implying that the factory motors that these intakes are installed on are rated to 150hp. vs 110hp for the AFM unit.
Not implying that by just changing the manifold you are gaining any huge amount of power. but you are gaining the ABILITY to support the airflow to make 150hp.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Growler is online now   Reply With Quote
Old May 26th, 2009, 08:41   #11
validius
Lacking in ZDDP
Not sure about the cost. Every order of these i can get are going to cost a different amount of money as exchange rates change as well as the cost of the parts themselves.
Unless i can get one extremely cheap shipped with an order of other parts coming from .de i will not be getting an AFN manifold. I can tell just by looking at them they suffer much of the same restriction at the 90 degree bend that makes the stock AHU manifold so bad.
If anyone disagrees they are more then welcome to buy me some time with a flowbench and i'l find out for sure
Old May 26th, 2009, 09:52   #12
Jon Linn
Ok, I understand better now. Thanks. This only means as you said before, that the PD150 has better air flow than a normal 1z/AHU manifold. Got it.
Has anyone done a before and after dyno on a stock car or decently modified car with the PD150 vs the stock A3 intake?
1997 Jetta: sold
Old May 26th, 2009, 10:06   #13
validius
Lacking in ZDDP
Nope, other then the 5 that we (Otm646, Matt|98AHU and I) ordered i know of only one more of these in the USA and the owner did not do before and after runs.
I sent one to StealthTDI who had it on his doorstep this mornin. Hopefully he will post his experience.
I am working on getting more of these but right now i cannot put fourth any time line for when more will arrive. All 5 i have now are spoken for.
Old May 26th, 2009, 11:07   #14
Stealth TDI
Hello,
Yes, I received my PD150 manifold. It has some soot build-up from the EGR. I'm going to have it bead blasted before installing it. I may have it installed and running by the middle of next week. I'll be sure to report if I feel a difference.
On a side note, I'm looking to relocate my W/M nozzle to just above the intercooler (post IC). Then I may be able to see how the W/M affects IAT. I do not plan to tap into my race pipe.
Later,
Scott
Old May 26th, 2009, 11:13   #15
DbLog
DbLog's Avatar
TDI(s): 2011 335d
Scott,
Where's the nozzle going? Before or after the MAF?
335d
SOLD 11' Golf , OH DEER B5 S4
, SOLD O1' Golf--RC6 212k, SOLD 91' MKII Golf ALH Project---VR6, PSS9, Wilwood, SOLD 91' MKII Golf GTI--VR6
DbLog is offline   Reply With Quote
Page generated in 0.18800 seconds with 9 queries
[Output: 130.95 Kb. compressed to 109.29 Kb. by saving 21.66 Kb. (16.54%)]
