Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old May 22nd, 2009, 02:15   #1
vwmikel
vwmikel's Avatar
Default My own spring clean out - MAFs, turbo manifold, etc...
Alright, I'm finally starting to clear out some of these boxes of stuff I have sorted out and set aside. So, I'll post up some stuff and probably add more as I go.
This is a 3" ATP MAF housing that I had on my car for a while. The current version of this goes for $125. I'm asking $75 obo. It comes with the MAF element but the plug is kind of broken and I'm not sure how good it is. You could just swap your MAF element in.
This is a new PD150 MAF. I have my doubts that it's actually a Bosch unit, but you can always swap in your MAF element. The housing looks pretty nice. I'm asking $60 obo.
I got this manifold a while back hoping it would fit my car, but it won't clear the mk3 motor mount. Another option became available though that fit my particular car better. This is designed for a top-mounted turbo and I think it should fit either a MK1 or a MK4 just fine. I also noticed that it would need a spacer to work with my GT2359V because the compressor housing interfered with one of the tubes, but if you're using a smaller turbo then it might not be an issue. There's two NPT bungs for EGT/EMP probes. I'm asking $650 obo.
This is a turbo city turbo "repair kit" which has all of the seals and bearing stuff that you're supposed to replace in a turbo. The application list thing shows this fits "Volkswagen Golf, Jetta, Rabbit, Quantum '82-'85 1.6L Diesel" and a few other vehicles with T3 turbos. The box is still unopened. Turbo City currently wants $90.29 for this kit, I'm asking $50 obo.
This is a TDI cam plate from a 1Z/AHU engine. I was going to use it to make an M-TDI pump but never got around to it. $25 obo.
Next post....
vwmikel is online now   Reply With Quote
Old May 22nd, 2009, 02:21   #2
vwmikel
vwmikel's Avatar
I replaced my shifter with a BMP one so I don't need this but I figured someone else might want to use it as a base for a custom short shifter....or maybe a super long rat stylze skull shifter... $10 obo.
This is the shifter cable bracket that bolts to the top of a 5 speed trans. I had to replace it to use the 5 speed shifter/box/cables with the 6 speed. $10 obo.
2 MK3 passenger side airbag covers - $20 each (I have airbags too if someone needs them).
Misc pump spocket. I think this is from an AHU, but I'll have to double check. The part number stamped on it is 028 130 111 A. $20 obo.
Old May 22nd, 2009, 13:17   #3
AndyBees
AndyBees's Avatar
Fuel Economy: life time average above 50 MPG
PM sent!.... turbo kit
2000 Jetta TDI, 50+ overall average (no tune)
300k mile mark on 12/28/11
427 fill-ups, in Excel spreadsheet, 323k miles...
'84 Vanagon ALH TDI engine (32 mpg), Polaris Diesel ATV, Allegro Bay RV 5.9 cummins
VWs 40 years, VW diesels 33 years, ALH TDIs 11 years
Old May 22nd, 2009, 18:26   #4
vwmikel
vwmikel's Avatar
Ok, the turbo kit is sold pending payment.
Old May 23rd, 2009, 04:51   #5
keggo
keggo's Avatar
TDI(s): 2003 TDI
Fuel Economy: 39 avg
Wish I had the money for that turbo mani...
Kevin : Engineering Student/Photographer
Surgeries: Vent, Muffler, and Screenectomies
HID retrofit with Porsche Cayman Projectors..............16" O.Z Ultraleggeras with Michelin Hydroedges
Evolution Skid Plate............................................. .Bosio PP764
TT Short Shifter........................................... .........TT Front Brakes (312x25mm)
keggo is offline   Reply With Quote
Old May 24th, 2009, 22:49   #6
vwmikel
vwmikel's Avatar
Bump because I know someone needs some of this stuff....
Old May 26th, 2009, 17:55   #7
Scott02
Scott02's Avatar
TDI(s): Too Many
Fuel Economy: 51/45/41
Mike,
For the sake of me not having to do any research, what's the difference between that MAF housing and a ALH stocker?
What the difference in diameters, and do one need a different airbox top to use it?
02 Jetta TDI - Blk/Blk leather, 140k miles, gt2256v, 26psi, 10mm, 0.260 holes, 31x12x3 FMIC w/ 3" piping, 3" downpipe, 1.8T gearing w/ .681 5th, peloquin, 3.156 final, VR6 axles, South Bend OFE clutch and SS pressure plate, 80duro mounts, custom dogbone, Shine springs/rear bar, Bilstein HD's, 312mm front brakes.
97 B4V GLX-TDI - Silver/Blk leather, 81k miles, RC3+, T4 inj/nozzles.
Scott02 is offline   Reply With Quote
Old May 26th, 2009, 18:34   #8
vwmikel
vwmikel's Avatar
Originally Posted by Scott02
Mike,
Which one? The PD150 MAF is about a 3" OD, but a smaller ID and fits with the VR6 airbox top (I think)...the aluminum MAF housing is just thin wall aluminum tube but a little larger ID. It's probably better if you have a custom inlet tube and filter setup.
Old May 28th, 2009, 08:43   #9
Scott02
Scott02's Avatar
TDI(s): Too Many
I initally menat the PD150 MAF/housing, but now i guess i'm also curious about the alum one...
Do you have any opinion of the MAF's functionality when the plastic grid is not used to "straighten" the flow through the MAF housing?
Ever tuned one like this and had any issues with wierd MAF values? Or did everything work out just fine?
Old May 28th, 2009, 10:49   #10
vwmikel
vwmikel's Avatar
The flow straighteners are probably a good thing for MAF accuracy, but it seemed to work fine on my car.
Old June 1st, 2009, 23:40   #11
vwmikel
vwmikel's Avatar
to the top....
Old June 3rd, 2009, 21:17   #12
AndyBees
AndyBees's Avatar
Free bump!
Old June 3rd, 2009, 22:57   #13
vwmikel
vwmikel's Avatar
Originally Posted by AndyBees
Free bump!
Thanks, and your turbo kit should be there any day now.
Page generated in 0.15906 seconds with 9 queries
[Output: 117.01 Kb. compressed to 97.63 Kb. by saving 19.38 Kb. (16.57%)]
