Old May 20th, 2009, 11:51   #16
mdfirefighter
TDI(s): 2003 Jetta
Originally Posted by oilhammer
Argh, why do people keep saying that? Many diesels, including VAG PDs, use a throttle plate.
Because you haven't told them yet
Noted!
Godfather of the TDT for PD Mafia
2003 Jetta TDI GLS - Platinum Grey Metallic - 176K Miles
mdfirefighter is offline   Reply With Quote
Old May 20th, 2009, 11:53   #17
Strack
Can the ASV/Throttle Plate be cleaned, repaired or must it be replaced when it throws a code????
Strack is offline   Reply With Quote
Old May 20th, 2009, 12:06   #18
oilhammer
oilhammer's Avatar
Try cleaning it first. Remove it to clean, being careful not to get any solvents in the electrical parts. The you will need to recalibrate it be resetting Group 00 in the adaptation of the engine ECU (it will recalibrate eventually, this way is just faster). There may also be something in basic settings, not sure off hand though.
And if cleaning won't work, then you will need to replace it.
oilhammer
www.cardocautomotive.com
Help out the TDI club raffle car! :http://forums.tdiclub.com/showthread.php?t=362827
Old May 20th, 2009, 12:29   #19
Strack
Ok thanks everyone fo the for the good advice and asistance!
Old May 23rd, 2009, 14:58   #20
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
OH, is that a stepper motor in the ASV? It looks as if it is homing when you first turn the key on..
Thanks..
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old May 25th, 2009, 18:06   #21
oilhammer
oilhammer's Avatar
It is not an anti-shudder-valve, that is merely one of its several functions, and a rather minor one at that.
Yes, there is a motor inside, just like the electronic throttles on the gassers.
oilhammer
Old May 25th, 2009, 23:11   #22
Mach1
Thanks..Mine homes when the key is activated and when the key is shutoff..
2004 6L 89000 19MPG
Old April 13th, 2010, 16:02   #23
shawnethan
TDI(s): 2006 Jetta
Default Same problem sort of....
First I am new to this forum but this has been fantastic with the pictures and the help. I had the dreaded gear strip in the flapper valve on the black half gear. Must have been stuck on start up then continued to strip it out. The electric motor still works, does anyone rebuild these flapper control valves or have a link to after market - I hate to go to the dealer for a 50 cent gear and have to buy the entire assembly for big $$$$$
shawnethan is offline   Reply With Quote
Old April 21st, 2010, 08:40   #24
McDiesel
I just found this thread and am thinking I have the same issue with our 2006 TDi. It throws the "Emissions Workshop" warning up and the ENGINE LIGHT shows up on the panel. It does not seem to affect power or mileage. I pulled the code with my OBD2 tester and got the P2112. My tester says this condition is "Generic Throttle Actuator Ctrl Sys - Stuck Closed"
Is the fix likely to be the gear that controls the ASV flapper?
I also read that there was a TSB for the intake flap motor but we never got any notice from the dealership so I am not certain it applies to our Jetta?
McDiesel is offline   Reply With Quote
Old April 21st, 2010, 10:12   #25
oilhammer
oilhammer's Avatar
You probably need a new intake control flappy thingy (throttle body).
oilhammer
Old April 21st, 2010, 13:22   #26
McDiesel
I'll open it up and see if I can see a broken gear or any obstruction and go from there- Thanks
Old April 22nd, 2010, 12:29   #27
McDiesel
Default part numbers for anyone who needs them
No time to tear it apart last night but I followed up with the local stealership today and explained the issue. The VW part number is 03G 131 501AD and they quoted me $346.95 for the part.
Rock Auto has two parts listed for this - it was a little clunky to navigate their site but for our 06 TDi I went under the year, then Jetta TDi and under EMISSION then EGR. They list :
STANDARD MOTOR PRODUCTS Part # EGV1081 $277.79
and then
AIRTEX Part # 4F1959 {#03G131501D, 03G131501N, EGR4409}
03G 131 501AD at $313.79
1stvwparts.com shows the following- BEST PRICE I COULD FIND
03G131501N $347.00 $0.00 $257.13 Emission system - Emission components - Egr valve
Egr valve - 1.9 liter 2005 - 2006
I have had excellent results from 1stVW and RockAuto in the past but if i end up having to order one I'll be on with 1stVW. I do wonder if the new number is a new part vs. the number 1stVW uses may be the old (crappy?) part.
Will post more once I can tell you the outcome
Old April 22nd, 2010, 12:37   #28
oilhammer
oilhammer's Avatar
The EGR valve is not the same as the intake manifold control flap, and the EGR valve is available two ways. One way it is $245, the other is $330 (VW list prices, approximate). Just depends on if you want the flange with it or not.
The throttle body, or 'regulating flap', part number 03G-128-063-G is $275 IIRC.
oilhammer
Old April 22nd, 2010, 13:03   #29
McDiesel
So to clarify, the part number I had is for the whole assembly WITH the EGR and your p/n is just the Throttle Body and ASV flapper w/o the EGR?
1stVW still has a better price
Item Number MSRP Core Price Price 03G128063G $283.90 $0.00 $210.37
Throttle body, jetta, 1.9l tdi
Old April 22nd, 2010, 13:33   #30
Lightflyer1
Lightflyer1's Avatar
Hmmm reminds me of my icemaker experience. Wanted to charge $127 for a new unit as the gear was not available by itself. I carved one myself using the broken pieces as a guide. Still going strong 5 years later. Same thing on my aircon controls on a 99 Tahoe. $400 and a new control panel later I test and find one blown resistor that RS gave me for free as a replacement. Kept it as a spare. Seems like that is the new trend. Can't buy parts, you must buy assemblies now.
Page generated in 0.15396 seconds with 9 queries
[Output: 124.02 Kb. compressed to 103.08 Kb. by saving 20.94 Kb. (16.89%)]
