Old May 9th, 2009, 11:22   #1
ndamico
ndamico's Avatar
Default My Injector Project and What I’ve Learned
I was planning on releasing everything I’ve learned at a later date but due to some mud-slinging I’m being forced to do this sooner rather than later. Please take this as you would anything else. It is not a secret that after this testing I decided to try and make a better nozzle, especially for higher horsepower applications. Some of you will probably argue that I’m biased or perhaps even made this up and that’s up to you. Anyone who knows what Bosio vs. Bosch nozzles cost plus paying for machine work will see that I’m not in this to get rich.
To give you guys a little background- I’ve been into diesels since 2002. I’ve owned 3 Duramaxes and currently own two as well as 2 A4 Jetta TDI’s. I’ve been into competition since 2003 and currently have one Duramax with a fully-built race motor that is basically dedicated to drag racing and sled pulling. My other Duramax is a dually which I use to tow the race truck around. I’ve had a lot of experience with different diesel performance parts- turbos, injectors, cams, heads, studs, transmissions, etc. I’ve broken quite a few things during the development of many of the parts that are sold today for the Duramax. I’ve even manufactured a couple different things and still sell a few products for the Duramax. Up until last year I owned and operated dieselplace.com, the largest Chevrolet & GMC diesel truck forum in the world.
If you would like to know more about my truck and what I’ve accomplished with it please see:
http://www.wackywack.com/dmax.htm
When I bought my TDI’s my goal was to find the best parts I could for my two cars. If I found something I didn’t like my plan was to utilize my experience and industry connections to improve upon what is currently available. Last year I decided I wanted to put bigger nozzles in my cars. I looked at what was readily available and found Bosch, Bosio, and some Chinese nozzles sold on eBay. I also found DSS nozzles but they didn’t seem to be readily available over here so I didn’t include them in my testing. Based on what I had read on the club (which I’m sure comes to no surprise) it seemed that Bosio was by far the most popular choice. I procured the following different nozzles, each set being brand new in the original packaging (I even tested several sets of the same type of certain models):
Bosch 706
Bosio PP357
Bosio Sprint 520
Bosio PP520
Bosio PP502
Bosio PP764
Bosio Race 520 5-hole
Bosio Race 520 7-hole
Chinese eBay nozzles
Here is a picture of one of the Bosio boxes I received. They all looked identical and had the same distributor’s sticker on them. I hope this is the best way to assume they are all genuine. I also purchased them from several different vendors on the forum so they wouldn’t come from just one source.
I then sent them off to have them tested. My initial hope was that they would say the Bosio’s were superior and I would then pick the size I wanted and move on to my next project. However that was not what I found.
To give a little background of what type of testing I had performed- Each nozzle was internally inspected for surface finish (inside the nozzle, not outside), potential EDM manufacturing damage, spray pattern, and consistency of flow. To make this simple I’ll use a Bosch 706 nozzle as my baseline. We tested several sets of these nozzles and every one of them flow tested exactly the same. The spray patterns were perfect and there was no sign of manufacturing defects. Bosch EDM’s their nozzles initially then briefly hones them to remove any small imperfections from the EDM process.
Bosch 706 nozzle pictured below:
The Chinese nozzle was not surprisingly the least-desirable of those tested. We found the holes were actually drilled and not EDM’d. There was no evidence of EDM damage as that process was not utilized. The spray pattern was not as uniform as the baseline nozzle but surprisingly not horrible either. The major downside was the variance in the flow from nozzle to nozzle. I only tested one set of these and they flowed 35.714%, 78.571%, 43.264%, and 61.119% over stock for a set average of 57.143% over stock. One of the big things that make a great truck nozzle is to have each of them flow as close together as possible so you get an even distribution of fuel for each cylinder. It’s easier on the motor, especially when you are trying to make a lot of horsepower.
All of the Bosio nozzles were EDM’d so I won’t cover that aspect for each one.
The PP357’s showed no internal manufacturing defects from the EDM process. The spray pattern was good as was the surface finish. They flowed 21.429%, 28.571%, 35.714%, and 42.857% over stock for a set average of 32.143% over stock.
Two of the 8 Sprint 520’s tested showed burn marks from the EDM wire over penetrating the hole and residual slag material from the EDM process. The spray pattern was good and other than the EDM damage the surface finish was fine. The first set flowed 28.571, 35.714, 42.857%, and 42.857% over stock for a set average of 37.5% over stock. The second set flowed 35.714, 39.286%, 41.429%, and 42.857% over stock for a set average of 39.821% over stock.
Bosio sprint 520 pictured below:
The PP520’s showed no internal manufacturing defects from the EDM process. The spray pattern was good as was the surface finish. The first set flowed 50%, 46.429%, 57.143%, and 57.143% over stock for a set average of 52.679% over stock. The second set flowed 50%, 46.429%, 53.571%, and 57.143% over stock for a set average of 51.786% over stock.
Bosio PP520 pictured in both photos below:
The PP502’s showed no internal manufacturing defects from the EDM process. The spray pattern was good as was the surface finish. They flowed 64.286%, 67.857%, 71.429%, and 71.429% over stock for a set average of 68.75% over stock.
The PP764’s showed no internal manufacturing defects from the EDM process. The spray pattern was good as was the surface finish. They flowed 92.857%, 89.286%, 85.714%, and 71.429% over stock for a set average of 84.821% over stock.
The Race520 5-hole nozzles showed no internal manufacturing defects from the EDM process. The spray pattern was good as was the surface finish. They flowed 128.571%, 125%, 135.714%, and 128.571% over stock for a set average of 129.464% over stock.
The Race520 7-hole nozzles showed no internal manufacturing defects from the EDM process. The spray pattern was poor in that it would load too much fuel to one side of the cylinder. See photo below. Since the nozzle sits at an angle in the head the holes are staggered differently as you move around the circumference of the nozzle. The extra holes are staggered incorrectly which also negatively affects the spray pattern. It was recommended that I not put these nozzles in my car. They flowed 164.286%, 157.143%, 207.143%, and 164.286% over stock for a set average of 173.214% over stock.
Bosio race520 7-hole pictured below:
Another piece of interesting information was that the while the Bosch and Chinese nozzles were clean inside about 40% of the Bosio nozzles had to be cleaned before they could be properly evaluated. They suggested this was due to the way in which they were packaged. Both the Bosch and Chinese nozzles came sealed in individual plastic tubes. I would also like to point out to date I have never installed or ran any Bosio nozzle in my car. I’ve driven plenty of cars with them but have never run a set myself. I want to be clear that all of the data I have is from the testing which was not done from a vehicle.
After getting all the results back I noticed 2 things. The first is that all of the nozzles except the OEM Bosch units weren’t matched well for consistency within a given set. Some were better than others but none were close to the OEM Bosch. I then decided to try and create some nozzles of my own. I had 3 choices for a starting point and I looked into what I could buy them for near dealer pricing. From least to most expensive they were 1) Chinese nozzles at approx $15 each, Bosio nozzles at approx $30 each, and Bosch nozzles at approx $60 each. I then have processing fees to cover the EDM and Micro Extrude Hone work which for the most part price me out of the current market. I was told the best nozzle to start with was the Bosch as it had a slightly better surface finish and they felt the seat area was also slightly better.
Next I purchased several sets of brand new OEM Bosch nozzles from a Bosch dealer in Wisconsin (was the best price I could find. My dealer here was $80 each). I have since made several sets of varying sizes which have been put into several people’s cars, some of which are club members. So far we have had great results. We have been able to hold the flow numbers very tight. The last step is they get extrude honed to remove imperfections, polish the inside of the nozzle, and radius the inside of the holes where the fuel flows. That is what makes the pictures of them looks so nice and shiny on the inside. My nozzles are reworked in the USA and they are done one at a time and each one is flow tested as well as cleaned. Given the price point some mass-produced nozzles are designed to meet I feel there is room for improvement when price is not such a main consideration. I include Bosch copper sealing washers as well as clear plastic tubes so you can submerge your old nozzles in WD-40, biodiesel, etc. I’m not making these nozzles to try and make a fortune. I’m doing it because I think I can make a better product that may appeal to some people. I can also make custom sizes for non-standard applications. Essentially I’m not limited to a pre-set number of configurations.
One of my nozzles pictured below:
Before the testing I had collected information as to where each Bosio nozzle fell with respect to size. I was a little surprised by the PP357 vs. the Sprint 520 as well as the PP502 vs. the PP764. Since these did not come out as I had expected I have decided to post a recap of the Bosio’s tested from smallest to largest.
Bosio PP357 ------------ 32.143% over stock
Bosio Sprint520 --------- 37.5% over stock
Bosio PP520 ------------ 52.679% over stock
Bosio PP502 ------------ 68.75% over stock
Bosio PP764 ------------ 84.821% over stock
Bosio Race 520 5-hole ---129.464% over stock
Bosio Race 520 7-hole ---173.214% over stock
As I said during my introduction I wasn’t planning on posting any of this information yet. However I am being publically accused of selling, “crudely re-worked bossch 706 nozzles”. I also had someone call me and say the same individual is telling people I’m using drill bits to enlarge stock Bosch nozzles. All of this is coming from a vendor who has never touched with his own hands or seen with his own eyes a set of Bosch nozzles I’ve had reworked. It’s after these comments that I decided to write this thread.
I’ve been around forums for years and especially from having owned one I know the politics run deep; much deeper than most people ever know. One is forced to learn the hard way whom you really can and cannot trust. I for one don’t appreciate my efforts being belittled as I'm sure none of you do either. If you don’t like what I’m doing you’re entitled to that opinion but don’t be childish and make up lies in an attempt to discredit me.
So for the record I’m not telling all of you to go buy my nozzles. I haven’t even advertised them on the club, in my signature, etc. I’m just laying out everything I’ve done and learned and hopefully some of you will learn something from it too.
Thank you
On Edit- I forgot to add that I have tested Bosch PD100 and PD150 nozzles as well as Bosio Race783 PD nozzles. It wasn't the focus of this thread but I have done the testing on them. To summarize the results briefly:
A PD150 nozzle flows 23.077% more than a PD100 nozzle. A Bosio Race783 flows 178.846% more than a PD100 nozzle.
The set of PD100 and PD150 nozzles I tested all flowed exactly the same within their respective sets. The Race783's showed no internal manufacturing defects from the EDM process. The spray pattern was good as was the surface finish. They flowed 184.615%, 184.615%, 176.923%, and 169.231% over a stock PD100 nozzle for a set average of 178.846% over a stock PD100 nozzle.
03 Golf 1 Micron Fuel Filter Kit and Nozzles, , DC Stage 4 Clutch, 6-Speed, Peloquin
02 Chevy Duramax Nicktane 1 Micron Fuel Filter Kit 800+HP #2 only, TTS, II, J&H
ARP Head Stud TDICLUB Special - $150 Shipped
ndamico is offline   Reply With Quote
Old May 9th, 2009, 11:36   #2
Growler
Got Soot Vendor
Growler's Avatar
Who was that Masked man..
Glad to see this thread come out. I've been hearing exciting news of someone coming out with some new nozzles. And the guy I recommend to people for balancing has been telling me about some of the things you mentioned in this thread.
One thing I am unclear on.. is the Bosch706 the Stock 5 speed nozzle? or where does it land in the comparison compared to the Stock 5 speed nozzle?
Looking forward to the future. It's gonna be exciting.
~Aaron~ Click Here for 2nd Annual GTG 6/29/13 At my place
TDI Service Calendar link.Click Here.
Check~Info and feedback Thread first post.
"Knurren"03 Golf Variant 5 speed,"Schnurren"01 golf 2 door
Growler is online now   Reply With Quote
Old May 9th, 2009, 13:06   #3
KROUT
persona non grata
So this is interesting because the pp502's are supposed to flow more than the pp764's. So if your test are accurate and unbiased that's not the case.
KROUT is offline   Reply With Quote
Old May 9th, 2009, 13:15   #4
Sip'n Diesel
Veteran Newbie
Sip'n Diesel's Avatar
Fuel Economy: 900 miles on 16.9 gallons - Personal Endurance Record
Thumbs up
very interesting, thanks for putting this together! it's unfortunate that a ridiculous accusation is what motivated you to put this together early. either way, thanks again this is a great read!
2003 Jetta GL - 5 Speed Manual - Alaska Green - Dieselgeek Panzer Plate & Full Metal Jacket - DGRP - ScanGaugeII - WeatherTech Deflectors - Vent Delete - DRL Delete - Muffler Delete - KONI STR.T - Redneck Armrest - 5 Brake Lights - Otherwise all stock, for now
Sip'n Diesel is offline   Reply With Quote
Old May 9th, 2009, 13:23   #5
caloony
caloony's Avatar
Wow...I wish I could afford every single set of nozzles! Im joking, thank you for all that info, very well done and well written (with detail)
caloony is offline   Reply With Quote
Old May 9th, 2009, 13:33   #6
vwmikel
vwmikel's Avatar
I can confirm that when tuning a car with either of these nozzles, the pp764's always smoke more (so fuel has to be reduced) when used with a stock turbo. The PP502's can remain fairly smoke free with full fuel requested, but the PP764's would clear intersections.
vwmikel is offline   Reply With Quote
Old May 9th, 2009, 14:26   #7
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: Tdi avg 48.6mpg. BMW avg 10 CPM and practically NO MAINTENANCE!
Default Great data!
http://pics.tdiclub.com/data/500/Tdi...omparisons.pdf
Notes:
I'd like to shrink down the PDF so that it is centered on text but don't know how (still learning the mac).
One of the Sprint 520's passed with a good rank but the other set failed to deliver spray uniformity. I've arbitrarily said that 10% coefficient of variation is the limit of acceptability (marked in red text with conditional format rule), but I really don't know. More experienced tuners/users hot rod people can speak with more authority. Based on what VWMikel and others are saying, it seems like a reasonable line in the sand to me.
Coefficient of variation is just the standard deviation (spread) over mean. It's a measure of precision.
Thanks very much to ndamico. Now we have a means of ranking/comparing your new nozzles too. It's a great day for performance Tdi peeps.
.. Awesome Club Vendors ...Buyer/Seller Feedback.. Fundraiser-buckwheatDiesel..Fundraiser-OilHammer..EnviroFit..Edmund's TCO..NIST applet..Slow Fueling Warning!..Vendor Feedback..Vendor FAQ's..What tire psi?
<--To report spammers, trolling, stealth vendors, or any problem post, click the report post icon under THEIR user name info panel
nicklockard is offline   Reply With Quote
Old May 9th, 2009, 14:27   #8
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
First off, thanks for the wonderful effort you've gone in a quest for nozzles. That's a lot of work. As per this quote below, I had a question:
Which injectors were the PD150 and Bosio Race783 nozzles mounted on? When will you have flow data of your "reworked" nozzles? I'm sure a lot of people will be quite interested.
That being said. Kudo's to you for standing up and doing something to stop the mud slinging process (doing what you can at least).
212whp/354 ft-lbs14.862@96.677-Way faster than Chris
Farfromovin is offline   Reply With Quote
Old May 9th, 2009, 14:48   #9
volucris
TDI(s): 1.9 Golf CL
wow. those reworked nozzles look beautiful man. Nice.
volucris is offline   Reply With Quote
Old May 9th, 2009, 14:52   #10
KROUT
persona non grata
Well shoot I need to see if Paul will trade out my new pp502s for pp764's. I was under the impression they were slightly larger.
Old May 9th, 2009, 15:14   #11
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Awesome thread!
2003 TDI Mafia Member, modified with 17/22. Mobil 1 0w40
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old May 9th, 2009, 15:19   #12
BioChoppers
BioChoppers's Avatar
Fuel Economy: 53
We have tuned many sets of PP502's & I always wondered why they didn't smoke more & seemed so much slower than the PP764's.
The other interesting finding is that the sprint520's flow more than the PP357's.
S520 SPRINT 520 $240.00 $240.00
PP357 POWERPLUS 357 $357.00 $357.00
That's $117.00 everyone could have saved over the years!
"Put Down The Purse and Drive!" (VWmikel)
"A Great Pleasure In Life Is Doing What Others Say You Can't"
BioChoppers is offline   Reply With Quote
Old May 9th, 2009, 15:43   #13
nicklockard
Torque Dorque
One thing that stands out to me is how I can see a cottage industry springing up to simply buy ten of each nozzle type and create matched sets for a nominal fee No joke. I bet a guy could make a nice supplemental income just testing and creating matched sets.
ndamico, can you test a few sets of Sprint 764 nozzles too? Please post up your nozzle results as soon as you can.
Thanks.
Old May 9th, 2009, 15:55   #14
nicklockard
Torque Dorque
Peter, look at post #7
Old May 9th, 2009, 15:59   #15
danielhf
danielhf's Avatar
Fuel Economy: 32/42/49
Hats off to ndamico! It's about time that the mud slinging and conjecture in regard to nozzles has finally amounted in something useful and dare I say it, scientific.
There is obviously a great deal of work that he has put into this project to not only possibly provide this community with an extremely high quality new product, but also provide us with stringent factual data on nozzles that we have been using in our cars without much question (until recently) for years. Just look how PP502s have been regarded in comparison to PP764s, and that's only the most obvious thing to consider at first glance.
Rather than basing our ideas about TDI performance on gossip and questionable vendor allegiances, let the science and facts speak for themselves! Reading this post was like finally seeing the fog surrounding the elusive nozzle "debate" clear and turn in a logical direction.
04 .:R TDI - Conversion Thread 246 AWHP 343 AWTQ
PD150 w/4motion TDI 02M & LSD, TD Tuning Full Race Tune, GTB2260VK, Darkside stainless tubular exhaust manifold & downpipe, R783 nozzles, Colt Stg. II cam, and lots more...
02 Reflex Silver Golf Variant TDI - TOTALLED!
danielhf is offline   Reply With Quote
Page generated in 0.17229 seconds with 9 queries
[Output: 151.99 Kb. compressed to 129.55 Kb. by saving 22.44 Kb. (14.77%)]
