T_D_I_POWER
- Joined
- Jun 7, 2007
- TDI
- '04 VW PASSAT GLS TDI '06 Audi A4 q Avant 6-Spd Sport Pkg
AF Gauge Installation
Parts Req'd:
1. AF Gauge by
ENGINEERED PRODUCTS CO.
www.filterminder.com
2. PVC Elbow. This is a temporary part used to complete project. This can be purchased from any automotive supply store i.e. Autozone, Advanced Auto Parts etc. This part will be replaced once similar OE/OEM part is available
L/O:
Place a strip of painters low tack tape on the back of the AFB. Then mark for the hole center location using a t-square as shown. The 4th rib from the left is a sink mark, and beside the scale is the 5th rib (or 2nd from the right). Hole center dims are as follows. Dim. from the left of sink mark to hole center is .531 in. Dim. between sink mark and 5th rib (or between sink marks) is approximately 1.125 in. Dim. from the bottom of AFB to hole center is 4.750 in. Hole size is 1.0 in. dia.
Apparatus:
Mount AFB squarely, center, level, and securely on a drill press as shown.
1.0 in. wood boring spade used for easy hole centering. Use wooden block for levelling and support as req'd.
AFB with hole provision for AFG
AFB Assy
Assemble AFG to PVC Elbow. Then assemble ASG Assy to AFB as shown
As Installed in Engine Compartment:
Note: AFG not reset
Very good visibility for easy observation.
Sufficient clearance between the inside edge of AFB top cover and edge of AFG
Sufficient clearance between the bottom inside of AFB top cover and AFG reset button. There is about .500-.625 in. from bottom inside of AFB top cover to bottom of AFG reset button.
Note: AFG shown in reset position. To reset AFG simply push yellow button.
Designed & Engineered by:
//SJAHSPEED DESIGN
Disclaimer: The author is not responsible for any injuries to anybody who is performing this modifications. The person who is performing this modifications is fully responsible for his or her own actions. If in doubt, ask questions or have a professional complete the modification.
Cheers,
Parts Req'd:
1. AF Gauge by
L/O:
Apparatus:
AFB Assy
Note: AFG not reset
//SJAHSPEED DESIGN
Cheers,
