Old May 3rd, 2009, 21:14   #1
MOGolf
MOGolf's Avatar
Default How to: Eliminate Headlight Shake
The headlights on the B5.5 stick out away from the lock carrier so much that they are poorly supported. This leads to headlight shake syndrome. The more the engine shakes the car, the more this is evident. Possible causes are bad motor mount(s), out of sync balance shafts due to chain stretch (see the threads about replacing the balance shaft module with newer gear driven design), and other factors that cause normal diesel engine shake.
The front bumper is supposed to support the headlights as well as the grille support. These need to be adjusted. Even after the adjustments there may be headlight shake. Here are a couple of tips for getting the best results of bumper adjustment to fix the headlight shake.
Remove the front bumper cover (see thread on lock carrier service position).
Loosen the grille support T30 torx bolts (two on each side) and adjust the support upward so that the headlight support touches the headlight assembly (see the three arrows in the picture).
If there is still a gap between headlight and support, fit a piece of weather resistant foam (e.g. home door/window weather stripping) into that gap.
Finally, cut a length of the weather stripping and apply along the bumper cover in the area where it will contact the headlight assembly. Leave the paper covering the side that will contact the headlight as shown. This will prevent the weather stripping from sticking to the headlight as the bumper cover is reinstalled.
I suggest buying a dark color weather stripping for dark color bumper covers and light for light colored bumper covers (as I did). When installed, you won't be able to see the foam head-on but looking down from above you'll be able to see a bit of the weather stripping through the front edges of the headlamp lens. It may not matter much to most people since you don't see it from the driver's seat.
Unchained motoring
MOGolf is offline   Reply With Quote
Old May 3rd, 2009, 21:29   #2
vw4life
vw4life's Avatar
Fuel Economy: 7.4 L/100km 75% city (~32 MPG US)
Fantastic. Thumbs up on this. I will try this when I have my headlights out to install the leveler motors.
Until then I have a thick piece of plastic wedged in there.
\\\ David /// 2005 B5.5V TDI Stonehenge Grey - Manual Headlamp Leveling - Aspherical Mirrors - Ventectomy trouble? - Fuel Economy - Euro trailer hitch: towing, install, safety chains, towing, wiring, euro bike rack! +Factory de-tooef's, Airlift
vw4life is offline   Reply With Quote
Page generated in 0.14609 seconds with 9 queries
[Output: 51.73 Kb. compressed to 47.63 Kb. by saving 4.10 Kb. (7.92%)]
