NO! You're not. You have an expectation of quality work so you have a right to know what they'll do and what kind of parts they do it with.b5r said:AM I being to anal bout this or what?
Brian, Thanks! I have not seen that new bottle! I'll have to change my pic when I can get one of the new container!oilhammer said:I should note to anyone reading that Tony's pic is of the old style Pentosin bottle. The new one is taller and more squarish, and has a pic of an autobox gear selector on the front. Same fluid inside however.
The OEM VW filter kits are quite a bit higher in price. Even at places like World Impex they were only discounted by maybe 10% from list when I looked them up using the VW part #'s.SUNRG said:The ATF filter kits for B5.5 are available from lots of places for ~$40.
there are items where OEM = significant quality difference, and there are lots of items where aftermarket offerings are as good if not better than OEM.blaz said:The OEM VW filter kits are quite a bit higher in price. Even at places like World Impex they were only discounted by maybe 10% from list when I looked them up using the VW part #'s.
So the question becomes do you want OEM VW parts and fluids? I asked that in this forum earlier, and most people said to stick to VW parts.
But I'm not sure if that's because the cheaper filters are known to be bad, or just that nobody is willing to risk trying them because they're almost certainly Chinese.
4 or 5 years and 150k on a ATF filter is a lot. when i pulled mine i thought of all the people that're just getting flushes. running all that expensive new fluid through a dirty old filter... while i'm sure it's better than doing nothing, doesn't seem ideal.Lug_Nut said:My suggestion: If the transmission is still working properly, shifting properly and you are interested in prolonging the "lifetime" of it, is to drop the pan, replace the filter, and do a partial fluid exchange.
If you are having issues such as no longer shifting as it used to, then have a complete flush and also a filter change.
Do as I say, not as I do.
I had a flush but not a filter. My cold fluid related MIL (occurs on the 2-3 shift) has again returned. I'm suspecting that at 150k miles it is dirty and restrictive enough to reduce the flow capacity with cold (<100F) fluid.
i know it's a great AT and i'm not expecting the filter to be loaded down with anything.oilhammer said:Have you ever cut open a filter on the 01V? There is nothing in there. Even after 200k miles, they are clean as a whistle inside. The teeny bit of particles in them is only about 5% of the flow. Those filters are WAY oversized. This ZF unit is also used (in a modified form of course) in many BMWs as well.
b5r said:the tranny is shifting nice to me. before we dropped the pan we took for a test drive and he stop the car several times and then accelarated at a normal fuel saving rate. then just once he got on it up to 3rd gear.. then slowed down with tiptronic down shift. then sped up with tip. concluded that it was very normal with no problems.
2 reasons i had this done and was going to have a PARTIAL fluid change per what was advised at shop was that
1. from what I had heard here and
2. I have noticed in the morning when pulling out and still cold that 1 to 2 is a harder than normal shift and almost same can be said for 2 to 3 but not as much at all.
So there was concern for me since i had seen here that people were actually change fluids back at 40000 miles... wow i dont know where I stand on that now but i wish i had more of a sense to follow this forum rather than the owners manual...
If I had a gernade launcher and money didnt matter i would blow this car to shreds and go buy a new one..... with a warrenty at least
Yes I just got it off my chest
now what
HA HA!!!
The 1-2 shift is hydraulic, just like the 'good old days' before electronics took over much of the chore. The harder (I call it 'crisper' shift) into 2nd is more viscerally pleasing to me. I wish all the gear changes were like that...b5r said:I have noticed in the morning when pulling out and still cold that 1 to 2 is a harder than normal shift and almost same can be said for 2 to 3 but not as much at all.
