Old April 22nd, 2009, 13:58   #1
careylongscbc
Default 2006 jetta door switches not working properly
It seems that my door switches (locks,trunk and fuel door) stopped working when the car is off. All work fine when the car is running. Any suggestions?
careylongscbc is offline   Reply With Quote
Old April 22nd, 2009, 19:35   #2
careylongscbc
So I just got home from driving for the first time in the dark since the problem developed. I noticed that the door lights didn't come on until the door was all the way opened. Everything seemed to work with the door all the way opened (when the lights were on), but did not work when the lights were off.
Does this point to a harness of some sort? Any suggestions appreciated.
Old April 22nd, 2009, 21:14   #3
Ol'Rattler
Ol'Rattler's Avatar
Probably some chafed/worn wires between the drivers door and the body.
The harness in question runs inside the acordian boot between the hinges.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old April 23rd, 2009, 08:06   #4
rgravesjr
I'm not certain, but you may have a problem with your car's "wiring harness" that's inside your door. As O'lRattler said, I believe it's in the accordion section of the door. Mine went to crap on me on a trip away from home. I couldn't open my fuel door or open any of the windows from the driver's side switches (I could open them from their individual switches, however). Also, my MFD showed my driver's door ajar--it wasn't (the "door open" chime kept chiming because of this--about made me nuts!) and the interior lights wouldn't go off. Supposedly, several wires had broken or were damaged at the harness--and I've never messed with anything in the door. It wasn't under warranty (78K miles), so it cost me about $440 at a dealer in Cary, NC.
Ron
rgravesjr is offline   Reply With Quote
Old April 23rd, 2009, 09:19   #5
careylongscbc
Thanks for confirming my thoughts on the harness. I'll look at it this weekend and let you guys know if that is the problem.
Old August 22nd, 2010, 17:12   #6
careylongscbc
The culprit was two severed wires. I was able to push the boot back and repair the wire with an inline wire connector. What a stupid problem to have.
Old August 22nd, 2010, 17:57   #7
Mr. Timewise
Mr. Timewise's Avatar
Originally Posted by careylongscbc View Post
The culprit was two severed wires. ...What a stupid problem to have.
Agreed.
Just in case someone finds this post and needs help removing the rubber boot between the door and the A pillar, here's a post I made in another thread to help you...
http://forums.tdiclub.com/showpost.p...4&postcount=54
2010 Jetta SE 2.5L Tiptronic Salsa Red | 9W7 Bluetooth | RNS-510 | Homelink sun visor | Extendable passenger's sun visor | MFSW w/ paddle shifters | Hi-line SWCM | Hi-Line MFD+ cluster | Auto-dimming mirror w/ compass | Trunk release switch in grab handle | Silver lens tail lights | Front & Rear door warning/puddle lights | Walnut interior trim
Mr. Timewise is offline   Reply With Quote
Old August 22nd, 2010, 19:51   #8
chittychittybangbang
Nice pics of the boot. Can I add them to my writeup on how to remove the door skin and remove the wiring harness: http://www.myturbodiesel.com/1000q/a...tta-repair.htm ?
chittychittybangbang is offline   Reply With Quote
Old August 22nd, 2010, 22:33   #9
Mr. Timewise
Yes, use the photos as you wish. Mention they are used with permission of Mr. Timewise
I need to take the door skin off so I can remove the boot I damaged and replace it with the one I photographed. I'll use your DIY for that work!
Page generated in 0.23667 seconds with 9 queries
[Output: 86.07 Kb. compressed to 72.96 Kb. by saving 13.11 Kb. (15.23%)]
