Old April 21st, 2009, 11:17   #1
volksman1950
Fuel Economy: 42-47
Default Correct Jack Stand Placement
Hi,
Just want to confirm. I jack up my 2000 Jetta TDI at the notched jacking points with a floor jack on the outer side body points and place the jack stands directly behind the jack opposite the notched points on the frame rails. Is this correct? Don't want the car to fall. It seems solid.
Thanks,
Larry (Volksman1950)
volksman1950 is offline   Reply With Quote
Old April 21st, 2009, 11:25   #2
Variant TDI
Fuel Economy: 36.4min/44average/56.4max. Recently improved commuting from 42mpg to 50mpg with 'new' driving habits and Scangauge.
You'll get conflicting opinions, but I've never lifted my car by the pinch welds. And it's easy to tell... because my pinch welds are still intact, and not bent, crushed, or raped of their paint. You can still use the widowmaker in emergencies too.
This is how I lift.
If I'm lifting quick, I'll use the floor jack to lift the subframe bolt.
--Tim (member: 900 Club... x4, best: 56.4mpg)
2002 Golf Wagon TDI - - 1996 GTI VR6 - - Flickr
Variant TDI is offline   Reply With Quote
Old April 21st, 2009, 11:33   #3
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
//deleted the image//
X1
Subframe bolts in the front and in the rear I place the jack where the axle pivots, at the bushing.
nokivasara is offline   Reply With Quote
Old April 21st, 2009, 11:40   #4
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
Originally Posted by volksman1950
Hi,
Thanks,
Actually there are a lot of unofficial ways. However the official ways are the 4 point pinch welds (marked with the indented "arrows") . To avoid bending them you can either buy or fabricate dado or u shaped adapters or notch a dado deep enough in a wood block/2 x 4 to cradle the pinch welds.
You can also use the plastic covered cut outs (you can get puck converters from the holes) to put the jack stands.
ruking is offline   Reply With Quote
Old April 21st, 2009, 11:49   #5
Keith_J
Keith_J's Avatar
Fuel Economy: 38 MPG @ 80 MPH with 2 bikes on top. 52 MPG @ 60 MPH slick
Be careful with dadoed wood as it likes to split. Especially a 2x4.
2k Jetta manual. PP520s. Ventectomy, Panzer Plate, DT hitch, 16"s w/ 205 55s. Short shifter. Boost gauge with blue LED backlight, same intensity as dash. Blistein struts and shocks. 0.658:1 5th gear swap and LOVING IT.
Keith_J is offline   Reply With Quote
Old April 21st, 2009, 11:55   #6
ruking
My fav's are the plastic formed adapters, but the ones I used that are the cheapest (free actually) and works just as well are: hard rubber cut outs. Indeed you can use cut out sections of old hard rubber or of old tires for all that matters. After 11 or so years of use, not a bent weld (or even scratched) in the lot.
Old April 21st, 2009, 16:18   #7
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
Hi,
Thanks,
Here you go:
http://forums.vwvortex.com/zerothread?id=2951609
Please, no wood or concrete blocks.
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old April 21st, 2009, 17:17   #8
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
I use two floor jacks at the same time - one on each of the large subframe bolts. They fit in the center of the jack cup.
I also use 2 jackstands in the location shown above (no wood), but leave the jacks in place too.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old April 22nd, 2009, 14:36   #9
Curious Chris
Fuel Economy: 47/42/38
Grooved hockey puck is the best DYI solution for using floor jack on pinch weld.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old April 22nd, 2009, 14:58   #10
Variant TDI
Yeah. The wood isn't necessary if you're just jackstanding the car in that area... but it's very necessary if you lift from the center of the subframe. It's a lot weaker then the Mk3 subframe, which you can jack from directly.
Old June 15th, 2009, 16:53   #11
vflflyer
vflflyer's Avatar
Fuel Economy: 45-48
Default Jack Pads Set
I purchased this kit
http://http://www.tdiparts.com/catal...e.php?pID=1104
from TDIParts but do not know where to install them.
Can anyone give me some clues or pics
2003 Jetta TDI 1.9L manual 5 speed
170,000 miles
Learn from the mistakes of others. You won't live long enough to make all of them yourself.
vflflyer is offline   Reply With Quote
Old June 15th, 2009, 17:09   #12
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
Search...and ye shall find:
http://pics.tdiclub.com/members/tongsli/PDF/install.pdf
2012 BMW X5 35D 2000 NB with 3 pedal mod, RC3, PP520's, Eurojet SMIC, SBC 3, 2.5" side exit straight pipe, 2" lift.
TDICADDGUY is offline   Reply With Quote
Old March 28th, 2011, 20:22   #13
B100
B100's Avatar
TDI(s): 2003 Golf
I would jack from the rear of my DieselGeek skid plate, if it were always in place, but it's not...
Is there a definitive thread on best jacking-up locations, front and rear, as well as best placements of jack stands, front and rear? I thought I knew this, but now not so sure... I have a single 2-ton hydraulic floor jack, two 2-ton jack stands, and that thing in the trunk (which I use successfully on the seam welds when changing one tire at a time).
2003 Golf 5-spd with ESP, DLC 1019 injectors, Koni Sports, CAT fuel filter, Panzer Plate, DieselGeek's bypass oil filter kit, Stage 4 Malone tune, South Bend SMF clutch, BV39 Turbo...
B100 is offline   Reply With Quote
Old March 29th, 2011, 20:04   #14
B100
B100's Avatar
TDI(s): 2003 Golf
Ah... this is what I was looking for:
http://www.myturbodiesel.com/1000q/a4/jackpoints.htm
:thumb
Old March 29th, 2011, 20:59   #15
Keebler145
Keebler145's Avatar
Fuel Economy: ~45
This is how I lift.
works great until you need to drop the subframe
424,000 miles and counting, On the frame that is (as of sold date)
Gt2256v 3 in downpipe and vibrant resonator, 3in OMI and FMIC all by Whitbread, Titan 520's, Port & Polished Head courtesy Franko6, RC 6, 11mm IP, PD LiftPump. Rosten Rods, PD150 Pistons, Oil Cooler, Fuel Cooler, Diablo W/M Kit,DC III clutch, Built 5 speed with LSD
Keebler145 is offline   Reply With Quote
Page generated in 0.16963 seconds with 9 queries
[Output: 129.24 Kb. compressed to 107.38 Kb. by saving 21.85 Kb. (16.91%)]
