need4speed
- Joined
- May 4, 2004
I've actually got TWO problems that just won't go away.
They're both long-standing problems, and I've just let them go for several months due to lack of funds and time.
First problem was a bad glow plug. I tested them with an ohmmeter - found #2 was bad, and I replaced that - and I'm still getting bad glow plug codes:
17056 - Cylinder 2 Glow Plug Circuit (Q11) Electrical Fault
P0672 - 35-10 - - - Intermittent
If I clear the code, next time, it comes back as #4 bad, or #1. Different each time. I tested them with the ohmmeter, and they're fine. I tested the harness, per the Glow Plugs 101 article - and I got 12+v from each socket. I had checked my relay in the past, and it was good - I'm going to check it again tomorrow, but I assume it's good.
The other problem is, limp mode.
Drives fine; then up around 3000 rpm in 3rd gear, it varies - the power cuts out. If I switch-off the ignition, and switch it back on, power's back.
I replaced all the vacuum lines.
I swapped the EGR solenoid for the N75, and that seemed to work. So I got a new N75, and I tested the VNT; seems to actuate across the full range, all the way to the stop - and it operates freely.
After I put the N75 in, it seemed to go away for a while. But it came back. Some days, it happens ANY time I demand any power from the car. Other days, it doesn't pop out at all. I feel like if I could just keep the dang glow-plug code clear, I could at least see the CEL come on for the limp mode - but that CEL is on all the time.
But here's the code I get on limp mode:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 35-10 - - - Intermittent
I cleaned out the MAF - the screen was kind of dirty. I performed the Cage mod. Didn't make any difference in performance at all; nor limp mode.
Is there a better way to diagnose if it's the MAF without unplugging? Unplugging the MAF causes limp mode immediately when I start it up. So there is obviously a difference - it's doing something.
But it seems with both this limp mode problem, and the glow plug problem, I've got a couple of gremlins partying it up under my hood. I'd really like to evict them.
