Old April 10th, 2009, 07:52   #1
respond2us
Default Blew a fuse, car won't start
So I blew a fuse, I guess. Was replacing a tail light, then the car wouldn't start the next morning. I charged the battery, but that didn't fix it. The IP comes up, the headlights come on, but nothing from the engine bay.
I imagine this is an easy fix, just not sure which fuse to check/replace.
'10 JSW 6speed w/Sunroof 95k miles (Owned since 7-2-2016) -- TorkLift EcoHitch, Malone Stage II, DG Sigma Six shifter
'10 JSW DSG w/Sunroof and Nav 67k miles (Owned since 9-2016) Garage/Gate controller from Double Apex
respond2us is offline   Reply With Quote
Old April 10th, 2009, 07:59   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Does the engine turn over at all?
Check these to start
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old April 10th, 2009, 08:12   #3
paramedick
paramedick's Avatar
Pictures even, and printable.
http://pics.tdiclub.com/data/500/5771fuses.jpg
Old April 10th, 2009, 08:16   #4
JASONP
JASONP's Avatar
Nice!
Old April 10th, 2009, 15:57   #5
respond2us
Ok, this might seem crazy, but I don't even have a fuse in position 10 (ECM). I looked at my wife's beetle, and it doesn't look like she does either.
I checked the other engine fuses, and they all seem good.
When I turn the key, the lights go out and no noise. Nothing happens. No clicking, etc. Anyone have an idea?
Thanks for your help.
Old April 10th, 2009, 16:34   #6
Ski in NC
Fuel Economy: 48-52 typical
Could be as simple as a bad connection on your battery terminals. If lights such as interior go off when turning key to crank, then voltage in system is dropping to near zero. Typical of a dirty battery terminal.
Turn on interior lights and try cranking. If they go out your voltage is dropping out.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old April 11th, 2009, 08:52   #7
respond2us
Ok, update here. I just realized this morning that nothing electrical works in the car. Interior lights, power windows, etc. Nothing. The only thing electrical that comes on is the instrument cluster, and actually, the headlights work too.
I tried to start it while checking the battery voltage, and the voltage does not drop. It stays 12.7 or so no matter what. So, I think the circuit isn't even getting to the battery.
Another development: There is a clicking under the hood when we turn the key, maybe 3 or 4 clicks then it stops. It seems to be coming from the general area of the starter...any ideas? I'm guessing the problem is probably where that clicking is coming from.
How can I test the circuit all the way to the battery to figure out where the break is? I have a meter, just not real smart with electrical stuff.
Old April 11th, 2009, 09:32   #8
DanG144
I would suggest that you clean your battery terminals and grounds, as a first step.
To get to the main ground and starter connection you need to pull your battery and battery tray out. It is then pretty obvious.
I like to use a brass brush to clean the connectors, then put electrical contact grease (or vaseline, or silicone grease) on them to slow corrosion.
If you still have trouble after this, then it sounds as if your starter solenoid may be the issue.
Dan
Old April 11th, 2009, 10:21   #9
nocebl
nocebl's Avatar
Since your wife has a beetle why don't you try jump start. At least you will know if your battery is good.
And as DanG suggested check your starter solenoid. you may try to tap your starter with hammer (off course you don't have to use to much force). This will bring you fork back into to normal position.
nocebl is offline   Reply With Quote
Old April 11th, 2009, 10:26   #10
JASONP
JASONP's Avatar
Jump starting won't do any good, sounds like the ground to the starter is bad or the starter itself needs rebuld or replace, that clicking sound you hear is the solenoid engaging.
Old April 11th, 2009, 10:39   #11
CTDieselHead
Power drops out in the car yet the battery holds voltage. Clean those battery posts and clamps!
99.5 Jetta ALH w/130K miles, VagCom, EGR and EGR Cooler Delete, DG Race Pipe, Cage Mod, Ventectomy
CTDieselHead is offline   Reply With Quote
Old April 11th, 2009, 10:40   #12
JASONP
JASONP's Avatar
must be an ECHO echo echo in here here here
Old April 19th, 2009, 08:05   #13
respond2us
Just wanted to let everyone know what happened with this problem. There were two fuses burned out in my fuse box. I replaced them, everything works. The weird thing was they didn't even seem like "important" fuses. One was the cigarette lighter in the trunk. Maybe that affects the start circuit somehow, I don't know. Anyhow, all good. Thanks for everyone's suggestions.
Old April 19th, 2009, 08:49   #14
whitedog
One was the cigarette lighter fuse, but what was the other one? Fuse 6 for the Comfort Control Module?
Can fold paper in half eight times.
Old January 10th, 2018, 13:45   #15
Lilgirl12
TDI(s): Jetta
MKIV FUSE LIST
8. Open
17. Open.
42. Radio (25A).
S179. ABS (30A).
would this work for a 2011 jetta tdi
Lilgirl12 is offline   Reply With Quote
Page generated in 0.17991 seconds with 9 queries
[Output: 124.79 Kb. compressed to 103.77 Kb. by saving 21.02 Kb. (16.85%)]
