Old April 9th, 2009, 18:48   #1
BeaverBanker
BeaverBanker's Avatar
TDI(s): 03 golf
Default Bad radio reception
Since we bought our 03 golf tdi used in 05. The radio reception has sucked.. its like a 1/8 distance of all the other vehicles i own. It has the factory radio and antenna. Is there a spot where the cord from the antenna to the radio could be cut or unplugged?
BeaverBanker is offline   Reply With Quote
Old April 9th, 2009, 19:02   #2
AndyBees
AndyBees's Avatar
My '00 Jetta has always had good reception on FM. But, about 4 years ago, the AM went all but south. Prior to that, the AM was really awesome.
Let us know what you learn!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old April 9th, 2009, 19:13   #3
mctdi
TDI(s): 2010 Jetta
What radio do you have, as some can do a test mode check of the antenna. I think that all mk4 have a power boost antenna. If water gets in to the antenna base, it can take out the amp.
Ben / mctdi
10/24/2015 => 300,262 miles
5/29/2010 Jetta 12 miles [new],
R.I.P. 2004 Golf 362,993 miles,
mctdi is offline   Reply With Quote
Old April 9th, 2009, 19:42   #4
BeaverBanker
TDI(s): 03 golf
looks like this
Old April 9th, 2009, 19:55   #5
mctdi
TDI(s): 2010 Jetta
With radio "on" push and hold "MIX"button for about six sec. Should go into test mode. Push "MIX" button to then step through.
Ben / mctdi
Old April 9th, 2009, 21:30   #6
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
__. Yeah, radio is bad especially on '03's. There are a couple of long threads on this - a search will pull up a lot of info.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Old April 9th, 2009, 21:38   #7
Sip'n Diesel
Veteran Newbie
Sip'n Diesel's Avatar
Fuel Economy: 900 miles on 16.9 gallons - Personal Endurance Record
Exclamation O rly?!
all MKIVs?! I don't have any complaints about the radio (as usual) but this is something I might do out of curiosity
2003 Jetta GL - 5 Speed Manual - Alaska Green - Dieselgeek Panzer Plate & Full Metal Jacket - DGRP - ScanGaugeII - WeatherTech Deflectors - Vent Delete - DRL Delete - Muffler Delete - KONI STR.T - Redneck Armrest - 5 Brake Lights - Otherwise all stock, for now
Sip'n Diesel is offline   Reply With Quote
Old April 9th, 2009, 22:08   #8
Herm TDI
Herm TDI's Avatar
The signal amplifier in the antenna base is shot. You need need to replace the amplifier.
P/N: 1J0-035-501-F $37.00
https://www.1stvwparts.com/part_number.html
What your antenna amp looks line now:
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old April 11th, 2009, 06:24   #9
mctdi
TDI(s): 2010 Jetta
As far as I know, just the radio shown in post #4.
Ben / mctdi
Old April 13th, 2009, 08:14   #10
TDI-Newbie
TDI-Newbie's Avatar
TDI(s): VW Golf 2003
Are there any write up on how to take this out... ?
TDI-Newbie is offline   Reply With Quote
Old April 13th, 2009, 10:14   #11
mrGutWrench
__. Yes, with pictures. I posted it.
Old April 13th, 2009, 14:15   #12
Sip'n Diesel
Veteran Newbie
Thumbs up
cool, thanks. I will add this to my list of "tinkering to-do"
Old April 13th, 2009, 14:33   #13
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Easy to do,
-open hatch
-remove headliner trim on the body of car
-pull headliner down to gain access
-wire is fairly short there as it is not one cable that goes to front of car.
20-30 mins tops to re/re
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old April 13th, 2009, 20:42   #14
npdimonte
Fuel Economy: 62.3mpg @ 65 mph highway
I see "TEST1", "Antenna: ON", does this mean its OK?
2003 Jetta TDI 5-spd
1988 Fiero GT 5-spd
npdimonte is offline   Reply With Quote
Old April 14th, 2009, 10:22   #15
mrGutWrench
__. Scroll through the other items too. The antenna gets power down the cable for the amplifier; the "Antenna ON" means the radio sees that it's sending power down the cable, it doesn't mean that the amplifier is actually working and if it isn't working, the radio reception will be either sucky or non-existent. So, it doesn't necessarily mean that it's "OK".
Page generated in 0.18280 seconds with 9 queries
[Output: 123.78 Kb. compressed to 102.10 Kb. by saving 21.68 Kb. (17.52%)]
