Old April 3rd, 2009, 04:09   #1
Fez
Default Audi A6 Avant 2.5 V6 TDI Quattro
hi, just bought this car, Its a 150bhp version.
wanted to know if anyone has had any experience with upgrading the performance of this car.
I'm not looking to change the turbo.
also it doesn't pull/move much, there's something wrong somewhere, is there something i could do to check it out? There is no smoke coming out from the back so i guess that's a good sign.
Any help appreciated.
Thank you
____________________________________________
Breaking for parts MK3 Golf 1.9 TDI GL AHU
R520, New SDI inlet Manifold, T25 360 bearings, IC, Koni sport, Eibach pro springs ++++ more
A6 Audi 2.5 TDI Quattro 150bhp
Fez is offline   Reply With Quote
Old April 3rd, 2009, 05:36   #2
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
I had one of these when they first came out but i never got into modding it!!.....and i've heard that they can be a pain.
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old April 3rd, 2009, 05:42   #3
diffas
diffas's Avatar
With original turbo u can get max. 190-195hp out of it. Morelikely
what u get out is about 185hp/420nm. With automatic transmission
i suggest u forget the torque.
Quattro + A6 + (maybe automatic trans?) = slow motion acceleration.
diffas is offline   Reply With Quote
Old April 3rd, 2009, 06:12   #4
Fez
mine is a manual, so 190hp with a remap, what about with upgraded injectors?
Hi steve, what kind of pain?
Old April 3rd, 2009, 06:34   #5
TDIfreak
If you are ready to upgrade the injectors you are ready to upgrade the turbo.
240 hp. +500 Nm.
TDIfreak is offline   Reply With Quote
Old April 3rd, 2009, 06:45   #6
Fez
Hi, so if i were to install upgraded nozzles and a remap i could reach 240bhp 500nm???
Which nozzles would that be?
Old April 3rd, 2009, 07:03   #7
TDIfreak
No no no. Read again.
Old April 3rd, 2009, 07:40   #8
Fez
ok, so which nozzles should i go for if i'm just going to do a remap?
thanks
Old April 3rd, 2009, 09:03   #9
diffas
diffas's Avatar
Remaping+nozzles+turbo brings you some powah, like TDIfreak said.
I'm doing that modification later on this year ... probably.
First you need to change the turbo imho.
I can recommend also the new exaust from turbo to the end.
Original is great for big backpressure...atleast on A4. :|
With original nozzles you can get out about 210hp with(!) bigger
turbo. I know.
Old April 3rd, 2009, 12:10   #10
mojogoes
Hi all the ones that i've seen done had problems with either the turbo or/and egr system....which provented them from having a good tune so make sure the car is in tip top condition first.
Old April 3rd, 2009, 12:38   #11
Alcaid
Alcaid's Avatar
Biggest problem with these engines is that the camshafts wear out early and you're looking at a bloody expensive repair!
It's not "if" it happens but "when".....
I had one, but sold it early enough
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old April 3rd, 2009, 15:38   #12
mojogoes
Twin timing belt change would have cost me £600+vat at the dealership ......but i got it done @ centralvwaudi for half the price!!
Old April 4th, 2009, 14:07   #13
Fez
anyone know which turbo is inside this engine?
Is there a direct replacement tubro i can drop in?
Twin timing belts never knew that.
Would centralaudivw do me a diagnostics and service? Looks like i might need to make the trip down to simon
Old April 4th, 2009, 15:17   #14
V6-TDI 4-Motion
V6-TDI 4-Motion's Avatar
It´s a GT2052V.
Use a Turbo from the 180hp V6 TDI like AKE or BDH.
A GT22 from T4 151hp AXG will also fit. This is my next Turbo for my V6 too.
Greets
Sven
96´Passat 35i TDI Syncro
96´Passat 35i TDI 4-Motion (under construction)
04´Passat 3BG V6 TDI 4-Motion
V6-TDI 4-Motion is offline   Reply With Quote
Old April 4th, 2009, 23:52   #15
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
The GT22 from Axg has almost the same 52mm compressor like GT2052V. So if you use it you will have no compressor upgrade in comparison to the stock V6 turbo.
Greets, Alex
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Page generated in 0.17300 seconds with 9 queries
[Output: 123.11 Kb. compressed to 101.77 Kb. by saving 21.34 Kb. (17.33%)]
