Old March 30th, 2009, 12:10   #1
bmwM5power
bmwM5power's Avatar
Default Quaker State 507.00 Oil?
Is there a Quaker State Oil that meets 507 spec? Asking because I recently purchased a brand new 2009 TDI and this is what my dealer uses. Just want to verify if this is true, because they are also not servicing the DSG at 40K mi , saying NOT NEEDED
bmwM5power is offline   Reply With Quote
Old March 30th, 2009, 12:27   #2
yatzee
yatzee's Avatar
TDI(s): see sig
whoa.... they should be using the castrol oil....
They do not know what they are doing. Run, do not Walk, but Run to another dealer for your servicing!
2015 Passat TDi 6 spd, 2005 C230 6 spd, 1991 405 mi16, 1986 and 1987 190e 2.3-16
yatzee is offline   Reply With Quote
Old March 30th, 2009, 13:58   #3
tdidieselbobny
tdidieselbobny's Avatar
Which dealer,Vincent or Dorschel???
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 30k miles....'16 Kubota BX1870 MMM/FEL, 178hrs!And now an '03 Jetta TDI 5spd w/ 427k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old March 30th, 2009, 14:18   #4
mparker326
Don't run so fast
http://www.pennzoil-quakerstate.com/...odsheet_fs.htm
Put in diesel plus in the product and click submit to read about their 507 oil.
2002 Golf GLS TDI
mparker326 is offline   Reply With Quote
Old March 30th, 2009, 14:48   #5
FL2AK-tdi
FL2AK-tdi's Avatar
Fuel Economy: best: 49.91 hwy w/ ULSD worst: 28.xx city with Jet-A/D1 mix
That's pretty cool. Too bad they don't have it in a 5-40 weight.
Originally Posted by butter nuts
I'm used to reliable cars that rarely break (Toyotas) so owning a VW will be a new territory for me.
Originally Posted by JASONP
...you [are] a loyal VW owner, wether you like it or not
Originally Posted by NB_TDi
I'm just not buying the whole, 01M sucks...end of story bit.
2001 Jetta Sedan GLS. 01M trans. Koni Reds. Evo Skidplate. Otherwise stock.
I <3 my automatic transmission. =)
They say that if you play a Windows CD backwards, it plays satanic music; that's nothing, if you play it forward, it installs Windows!
FL2AK-tdi is offline   Reply With Quote
Old March 30th, 2009, 15:37   #6
bmwM5power
bmwM5power's Avatar
dorschel
Old March 30th, 2009, 15:37   #7
bmwM5power
bmwM5power's Avatar
Originally Posted by mparker326
Don't run so fast
cant find 507, where is it?
update
ok, found it Q Diesel Plus SAE 5W-30, but not sure if this is what they use, they said quaker state
Old March 30th, 2009, 15:39   #8
FL2AK-tdi
FL2AK-tdi's Avatar
It's the sheet that says diesel plus and it talks about use with VW 507 and diesel using DPF. It's in there.
Old March 30th, 2009, 17:20   #9
yatzee
yatzee's Avatar
TDI(s): see sig
and it is certified 507.00 by VW - my mistake.
It's nowhere to be found on quakerstate.com
Old March 30th, 2009, 18:00   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
What are the chances that oil would need to be imported?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old March 30th, 2009, 18:11   #11
FL2AK-tdi
FL2AK-tdi's Avatar
I saw it at Wal mart two days ago. $5.25/ quart. Interestingly, the Pennzoil Platinum version did not list any VW Spec on the bottle. (So of course I scoffed and walked away.) But it did list the whole "for use on 2007 and later model diesels blablabla" It was also a 5W30 oil.
Old March 30th, 2009, 18:16   #12
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
That's what I mean FLAK. The 507.00 version won't be sold in the US on store shelves.
If it meets CJ-4 though I'll add it to my list.
Old March 30th, 2009, 18:20   #13
dieseldorf
top post dawg
dieseldorf's Avatar
Is this the oil that was to be available ONLY in bulk supply?
Old March 30th, 2009, 18:21   #14
FL2AK-tdi
FL2AK-tdi's Avatar
Do you really think that it's NOT 507 certified? I made the assumption that it WAS certified (based on the data sheets from the link posted above) but the labeling just omitted it for some reason.
By comparison, there was also a Castrol Syntec Full Synthetic in the black bottle 5W30 weight-the IDENTICAL bottle to what is purchased at the dealership but it does NOT say "VW 505.00 505.01 etc.) Do you assert that THAT bottle is NOT VW cert oil as well?
It was also the exact same price as the dealership too.
Old March 30th, 2009, 18:36   #15
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Castrol Syntec 5w30 has never met any VW specs, it's not suitable for ANY VW. Castrol Sytec 5w40 does meet 505.00 though. Castrol TXT 5w40 is 505.01, as is Castrol SLX 5w30. SLX LL03 is a 507.00 oil. You probably won't find TXT or SLX in a traditional store.
There are clues that lead me to believe it's not a 507.00 oil. (1) It's not listed on the bottle (2) Says it's for 2007 and later diesels. That sounds like an API CJ-4 oil.
It's not unusual for European/International and American versions of the same oil to meet different specs.
/EDIT: Added SLX LL03
Page generated in 0.18655 seconds with 9 queries
[Output: 134.78 Kb. compressed to 112.17 Kb. by saving 22.62 Kb. (16.78%)]
