Old March 13th, 2009, 06:58   #1
Dieselsmoke
Dieselsmoke's Avatar
Unhappy 3000rpm rev at hot start
Ok I feel that my baby is dying!
98 jetta 225,000 miles way overdue on timing belt
One day I got in the car and it revved up when I started it (car was warm), I thought nothing of it but immediatly noticed she was down on power.
It like throttle from 25% to 100% makes no more power, it's really a dog now.
If the car is fully up to temp. and I shut it off for 5 min., when i restart it it revs up to like 3000rpm and blows a big cloud of black smoke.
She desperately needs a TB and I am getting ready to do it, i have all of the parts.
My concern is that I also now have other issues like a faulty injector or the IP is going bad.
Has anyone heard of a 98 TDI doing this rev at start?
could it be that an injector is like hanging open and filling a cylinder with fuel when its hot, making it rev when i first start it?
Dieselsmoke is offline   Reply With Quote
Old March 13th, 2009, 10:45   #2
Dieselsmoke
no thoughts??
Old March 13th, 2009, 15:23   #3
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default reving to 3000
Sounds like you are sucking oil into intake! Beware of a runaway! Check to see if turbo is leaking oil. Also clean the egr valve & remove intake & clean it while you are doing timing belt. Check your oil level.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old March 13th, 2009, 16:29   #4
heykw
heykw's Avatar
TDI(s): fleet
sound like a good tip. sound like we need to check the intercooler as well
01 VW Golf TDI new south gauges 5spd RC5 EGR gone w/ ventectomy, Evo skid plate, south bend stage 3 with 17lb flywheel pp764 17/22 turbo.
2012 TDI SEL P.O.S.
120k miles timing belt replaced at 100K
heykw is offline   Reply With Quote
Old March 14th, 2009, 13:39   #5
heykw
heykw's Avatar
TDI(s): fleet
bump.........
2012 TDI SEL P.O.S.
Old March 14th, 2009, 16:35   #6
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
check the coolant temp reading with vag-com/vcds.. if the computer thinks the engine is VERY cold it'll flare up like that when it's hot and have no power..
Good idea to check the turbo as well.. I would suggest pulling off the hose that goes from the upper intercooler pipe to the intake before you start it and look for a bunch of oil to come out when you fire it up..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old March 14th, 2009, 21:08   #7
Drivbiwire
Zehntes Jahr der Veteran
Fuel shut-off selenoid!
Symptoms:
-Reduced power (Boost deviation code - Low)
-Revs up on start-up
You may only need a new selenoid o-ring, either way the selenoid needs to come out, replace the o-ring and this should fix your issue. If not you may have a bad valve/plunger, cost is around $113 for a new selenoid
O-Ring Part number: 068 130 139
Cost $1.92
http://www.worldimpex.com/parts/genu...eal_44154.html
Fuel shut-off selenoid part number: 028 130 135 F
Cost $113
http://www.worldimpex.com/parts/genu...di_177697.html
O-ring is under #3 in the diagram:
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old March 16th, 2009, 05:29   #8
Dieselsmoke
Thanks for the input, sorry I was away from the scope for the weekend. I was suspecting something with the IP. I will look into the fuel shutoff solenoid and report back. I would like to fix this issue before tearing it down becasue it was running perfect. I will also be cleaning my intake and IC when I tear it down.
Old March 17th, 2009, 19:13   #9
Dieselsmoke
Default Update
First I have to thank Drivbiwire, not only for the explanation, but also the PN's and a fix!
I bought the new Cut-off solenoid and replaced it. The old one looked fine mechanically and the o-ring was not split.
As soon as I finished I started the car , it turned over for a few seconds as it primed. I checked for leaks and took her for a ride, immediately I noticed it was still down on power. So I drove it about 2-3 miles around the block and back to my garage.
I pulled out the generic scan tool I have (yeah I know Vag-com on the way), and checked for codes. None. I also tried to restart the car to see if it did the 3000 rpm rev at start, and it seemed like it started to but caught itself. I turned it off and restarted it about 3 times and hooked up my scan tool reading real time data (painfully slow sampling).
Before I even got out of the driveway I could tell the power was back!!!
So... I found it interesting that it did not immediately fix it until a few restarts. Is there some sort of calibration that occurs after a few start cycles?
Seems like it is just and electromagnetic solenoid, I didn't think it had any kind of feedback control.
Old March 17th, 2009, 19:42   #10
whitedog
I am very confused on how a sticky shut-off solenoid can cause the engine to over rev. All the solenoid does is stop the flow of fuel from the case into the fill port of the pump plunger. If it sticks closed it doesn't start and if it sticks open, it doesn't shut off the fuel. So what happens when it sticks part way that causes the rev at start-up?
Old March 17th, 2009, 19:51   #11
jcrews
jcrews's Avatar
TDI(s): All gone
My first thought is that if the fuel shutoff stays open, a little extra fuel can be injected during shutdown. It must be just the tiniest bit as the engine loses speed and can't inject in the ignition window.
Since there is a fuel shut-off valve it is reasonable to conjecture the control collar does not move (fast enough, or all the way to zero) during shut-down, relying on the cut-off to stop the flow.
jcrews is offline   Reply With Quote
Old March 17th, 2009, 19:53   #12
Dieselsmoke
You beat me to it ^^ essentially it leaks some fuel into the cylinders that does not get burned until restart.
In fact if you let it sit long enough it wouldn't do it. The fuel eventually vaporizes
Old March 17th, 2009, 19:57   #13
Dieselsmoke
That part I understood but... I assumed that the loss of power was due to it not completely opening.
This also confuses me, why then did it not work on the first test drive if it was fully open??
Maybe a fluke?
Also I just remembered my scan tool found "enhanced code" p1144, has anyone seen this (I will search it)
Old March 17th, 2009, 20:04   #14
jcrews
jcrews's Avatar
TDI(s): All gone
Do a search
just kidding - MAF open/short to ground.
Here's a thread for your enjoyment.
Old March 17th, 2009, 20:32   #15
whitedog
That's a reasonable explaination and I'll run with that for now.
Page generated in 0.16566 seconds with 9 queries
[Output: 123.72 Kb. compressed to 102.04 Kb. by saving 21.68 Kb. (17.52%)]
