Old March 4th, 2009, 06:14   #1
sohccammer427
sohccammer427's Avatar
Fuel Economy: ?~45~?
Default Power Assistance Steering Warning Light
Probably the coldest day of the year (around 17F) and I'm driving to work and the Power Steering Assistance indicator light come on. At first it's yellow (reduced) and then red (lost completly).
At first I did not know what the indicator light was. It looked like a steering wheel, but had four spokes and my Jetta only has a three spoke steering wheel. But I did notice it was more difficult to steer, so I figured it must be a steering related issue.
Made it to work ok and went back out at lunch and the issue had self corrected. Today it was just as cold and no isues at all. I guess I'll see if it happens again, before I bring it in for a look-see. Manual says that if it stays off after restarting, no immediate need for steering service is required.
Can cold weather affect the electro-mechanical steering system?
On a side note I did not have my owners manual in the car. No problem (I thought). I'll just navigate to the VW site and download it in .PDF form like I can for the F150. No such luck, VW wants $60.00 for the owners manual, and it's only available in hard copy. I hope they read these posts.
2015 Passat TDi SE 6 Speed Manual
06.5 Jetta TDi Special Edition-Sold
1999F150 XLT Extended Cab
sohccammer427 is offline   Reply With Quote
Old March 4th, 2009, 12:16   #2
Ol'Rattler
Ol'Rattler's Avatar
Clearly, you need to do an adaption for a 3 spoke steering wheel. Just kidding.
There is a steering torque sensor down on the rack. maybe slush or ice got into an electrical connection.
There also is a steering angle sensor and the steering controller at the steering wheel. Being that the problem is not emission related, a DTC could have been set even though the MIL light is off. Do you know anyone that can do a VCDS scan for you?
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old March 4th, 2009, 13:12   #3
sohccammer427
Not right off hand, but the Company where I work has graciously let me have an older HP laptop. It runs Windows XP Pro and has USB ports. I have been thinking of buying a VCDS (VAG-COM Diagnostic System) Micro-Can Interface/dongle. I guess now is time to jump on one.
Seeing as I plan on keeping the car for a long time, (probably will be my son's first car, he's 11 now) I guess it would be a good tool to have.
So you're saying a scan could possibly point to a specific componant that could be failing?
I'll follow up down the road with what the VCDS reports.
Old March 4th, 2009, 15:07   #4
2footbraker
2footbraker's Avatar
It's normal for the light to come on if the battery voltage is low. I've had it come on in very cold weather on start-up. Let the car idle from a few minutes and restart. The PS should be normal after the restart.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old March 4th, 2009, 19:30   #5
Ol'Rattler
Ol'Rattler's Avatar
Ya, there could be a code set when the computer sees something it doesn't like and if the problem was intermittant, the light would go out but the code could still be set.
What 2footbtaker says sounds plausable, especially if your battery is getting old...................
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old March 15th, 2009, 10:04   #6
MPLSTDI
MPLSTDI's Avatar
TDI(s): 06 Jetta DSG
Fuel Economy: Max 54, 44 avg
I had mine replaced under warranty, $1400. Mine would stay on and go out randomly. It had done it as soon as a bought my car. Normally it was only the yellow warning and other than a windy day it didn't bother me too much.
Member of the TDT for PD Mafia
2006 Jetta TDI DSG base 0 - heated seats Shadow Blue 194K ScangaugeII Hidden hitch GDE HOT/ECO Tune
MPLSTDI is offline   Reply With Quote
Old March 15th, 2009, 10:28   #7
2footbraker
I had a PS failure again this winter where it would not come back on-line despite numerous restarts. I even fully charged the battery and no luck. Took it to the dealer and he cleared a code and PS came back. Kind of stupid it didn't reset itself. The code was "PS open circuit".
Page generated in 0.13053 seconds with 9 queries
[Output: 79.55 Kb. compressed to 68.58 Kb. by saving 10.97 Kb. (13.79%)]
