Louis_TDI
Hi i got really fed up of having such crapy fm and no am in my car in the past 2 week. So today I figured I'd look at the antenna base turns out it was definitively the problem! knowing my way around circuit boards I figured I could fix it but when I saw this I knew it was gone.
Look even de component weren't even on the circuit board any more.
I really don't have the money right know to spend on a new base but my favorite scrap yard doesn't have any and since I have nothing else to do I figured I'll just fix the dam thing.
This is such an easy fix all you need is extra wire and some solder.
Cut off the wire on the base and gently strip the wire in two steps like you would any coax cable. Peel back the outer copper wire and solder it to a new regular wire. Next pass both wire through the base I made a hole with my drill.
Solder the tiny wire to the metal plate in the top of the antenna base.
Then close it all up and put it back on the car plug it in and the extra wire that was installed goes to ground.
Now I get all the am and fm channels super clear and it cost me 0$
Note do this at your own risk I didn't find any curent coming from the HU so I did it like this but if you do have curent and you do this mod you might short circuit some small electronics.
Thanks for looking
Thanks for looking
