Old February 28th, 2009, 13:53   #1
Michael_Akamatsu
Michael_Akamatsu's Avatar
Default headliner sagging. How to fix?
99.5 Jetta, no sunroof. The thin cloth is sagging. Is there a recommended fix? Thanks.
1999.5 Jetta, 5-speed, www.dieselgeek.com short shift kit and bypass oil filter, E-code headlights, Bilstein HDs, otherwise stock. Michelin Primacy MXV4 tires.
Michael_Akamatsu is offline   Reply With Quote
Old February 28th, 2009, 14:11   #2
VWWV
Fuel Economy: 48hw/36town
Three thoughts:
1. Headliner install by pro. Should be about $100
2. Thumbtacks or staples?
3. Move out of the sun belt once you get it fixed.
Mine drooped here in Fl. Once bought a '90 that the PO sprayed with bedliner. Worked great.
96 Passat TDi Candy White 100 K. mi, ventectomy, cat injector disabled.
WV - where relativity is more than just a theory.
TERM LIMITS NOW
VWWV is offline   Reply With Quote
Old February 28th, 2009, 16:47   #3
Michael_Akamatsu
I was thinking about making a small hole in the fabric, and spraying adhesive in between the fabric and backer board. Does this sound reasonable, or have I been huffing too much of that adhesive? I really don't want to spend $100 to fix a problem that I could handle with a few staples. Thanks for the feedback.
Old February 28th, 2009, 17:04   #4
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Wrong adhesive will bleed through the fabric and end up as a stain,not recommended
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old March 5th, 2009, 05:25   #5
J double R
Fail Train Conductor
J double R's Avatar
Fuel Economy: 45-50 mpg
perhaps you could recommend the CORRECT adhesive then...??
Originally Posted by meganuke
Trogdor! Burninating the TDI, burninating the peasants...
J double R is offline   Reply With Quote
Old March 5th, 2009, 05:48   #6
puter
Fuel Economy: 57 mpg
I think if he sprayed in some elmers spray adhesive and waited at least 10 minutes (maybe closer to 15) it should still be tacky but wouldn't bleed through.
never done it before though, so take that with a grain of salt.
puter is offline   Reply With Quote
Old March 5th, 2009, 07:50   #7
Powder Hound
Powder Hound's Avatar
...not recommended
By the same committee that creates the 'trusted mechanics' list or even, bestows the coveted 'guru' designation?
Old March 5th, 2009, 13:10   #8
JB05
Fuel Economy: 43/41/40
I once tried some head liner adhesive from an areosol can, but it wouldn't work because the headliner had foam backing which was coming loose and created a big mess. In other words there was no firm backing for the adhesive. This was on an old Chrysler, Laser. IMO, the $100 professional sounds like a much better option, and would be less tacky.
Pun intended.
JB05 is offline   Reply With Quote
Old March 9th, 2009, 13:48   #9
Michael_Akamatsu
I think the foam from my headliner is coming out of my heater vents.
Old March 9th, 2009, 13:52   #10
Michael_Akamatsu
But seriously folks, JB05 makes a good point. The adhesive needs something to adhere to. Loose foam rubber mixed with spray adhesive would be quite the mess. I finally get it.
Old March 9th, 2009, 14:00   #11
davebugs
Never had a good remedy for VW or GM that didn't involve replacement.
I do have some nifty - hard to find headliner clips that are glorified clear thumbtacks that I used to use in Saturns.
But as someone said - for less than 100 bucks you can probably have it done correctly? How much money do you wanna spend for a ghetto look?
After that foam deteriorates you're kidding yourself about anything that includes glue.
davebugs is offline   Reply With Quote
Old March 10th, 2009, 18:06   #12
PnutButrJelytime
PnutButrJelytime's Avatar
TDI(s): 02 jetta
Fuel Economy: 42mpg is the best so far
just rip it all down and do a nice foe finish
15% window tint, kamei grill, evolution atlas skid plate, mufflerectamy, wingnut stealth pipe, 3" intake, rc2 chip, powerplus 357 nozzles. 11mmIP, vnt 17 turbo
PnutButrJelytime is offline   Reply With Quote
Old March 13th, 2010, 18:14   #13
TexLabo
I'm having the same issue with my '00 Golf. I bought some headliner spray adhesive, but haven't really gotten into it yet to see if it'll work.
My question is, do I have to pull the pillar covers off to get the headliner out? The rest just looks like taking all the little dome lights and visors off.
If I have to take the pillar covers off, do they just pop outward at the top, then slide upward to release the bottoms?
~Tex
TexLabo is offline   Reply With Quote
Old March 13th, 2010, 18:38   #14
compu_85
Gadget Guy
compu_85's Avatar
You have to remove the pillar trims to get the headliner down. But getting those off isn't that hard.
My headliner is starting to fall around the sun visor indents. It looks like the fabric was stretched too thin and after 10 years the glue finally failed.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old March 18th, 2010, 10:36   #15
Tom W.
Tom W.'s Avatar
Fuel Economy: Getta 49MPG IDI 60MPG Passat 34mpg
Default Headliner repair
Had the same problem in a chevy truck. Pulled out the headliner, scraped off the crapped out foam. Bought some headliner fabric off of Ebay- it comes with a new foam backing. $15. Sprayed the headliner w 3m headliner adhesive, laid down the fabric, re-installed. Looks brand new.
Chemically cleaning your turbo: http://forums.tdiclub.com/showpost.p...8&postcount=48
canadiangrizzly's Diagnosing limp mode: http://forums.tdiclub.com/showthread.php?t=179589
GoFaster on loss of power:
http://forums.tdiclub.com/showthread.php?t=75959
Tom W. is offline   Reply With Quote
Page generated in 0.16512 seconds with 9 queries
[Output: 125.96 Kb. compressed to 104.47 Kb. by saving 21.48 Kb. (17.06%)]
