Old February 14th, 2009, 07:15   #1
TheKid7
Default Jetta Driver's Door Lock Problem
2003 Jetta TDI - For about the last year I have been periodically having door lock problems with the driver's door. The problem has been getting worse recently.
Problem: The Remote sometimes does not unlock/lock the driver's door. The other door locks work fine. The key always works. This problem is not related to the Remote's battery. Also, there is the same problem when using the lock/unlock switch in the car and the auto lock when the car accelerates to the preset speed. Starting a few days ago this problem is almost continuous.
What is causing this problem and how can I fix it?
Thank you.
TheKid7 is offline   Reply With Quote
Old February 14th, 2009, 07:51   #2
yatzee
yatzee's Avatar
TDI(s): see sig
Does the light stay on in the dash?
2005 C230 6 spd, 2001 GMC LB7 w/ZF6, 1994 E280 5 spd, 1990 500SL and some euro 16v stuff. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
Old February 14th, 2009, 14:46   #3
Ol'Rattler
Ol'Rattler's Avatar
On A4s there are 2 micro switches inside the drivers door latch mechanism that wear out over time and cause the symptoms you describe.
There is a thread, either here or on VWVORTEX, were someone had taken the latch mechanism apart and replaced the switches for cheap. Otherwise, the latch mechanism is available at the dealers or from a vendor. For my 99 A4, it was about $ 185 if I remember correctly.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Ol'Rattler is online now   Reply With Quote
Old February 17th, 2009, 21:06   #4
Powder Hound
Powder Hound's Avatar
V4NS-UL switch from allied electronics is supposed to be the exact replacement switch. (Got this from some other thread, possibly from VWVortex).
Old February 19th, 2009, 14:18   #5
DannyRay
Fuel Economy: 38
yeah, had to have my mechanism replaced on my 02 so I have turned off the auto-lock with VAGCOM so it doesn't keep wearing out. If it was just my wife driving the car I probably would have kept the feature, but I figure I can lock the doors while I am driving if I need to. I also turned off that annoying audio warning when the windshield fluid runs out (true emergency). I just bent over and had the dealer fix it. Good luck.
02 J GLS TDI Auto (GBlue) - Mods: Nozzles (.184), Upsolute Chip, Epsilonian, Cheezed Air box, Hidden Glass Pack, Koni Yellows, Megan Racing Springs, 16" GTI Montreal II Wheels, Bridgestone Potenzas, 35% tint.
DannyRay is offline   Reply With Quote
Old February 19th, 2009, 17:16   #6
puter
Fuel Economy: 57 mpg
Um, Danny, you do realize that turning off the autolock will not resolve the microswitch problem right?
That microswitch just senses if the door is closed or not....
puter is offline   Reply With Quote
Old February 22nd, 2009, 23:43   #7
Ol'Rattler
Ol'Rattler's Avatar
That micro switch just senses if the door is closed or not....
Very true statement. However, if you disable auto lock, the system will lock the system a lot less causing the micro-switches to last longer...................I may go and disable the auto lock on my A5 for the same reason..............
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old February 23rd, 2009, 06:14   #8
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
The switches 'wear' out from the door being open and closed. Not from the doors being locked.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old February 23rd, 2009, 06:46   #9
puter
Exactly.
I think he believes that the microswitch determines if the door is locked, but that is the job of several other microswitches within the locking mechanism itself...and those don't tend to wear out.
Danny:: take your door apart one more time and take a look, you will see that the only time that microswitch is triggered is when the door is opened or closed, locking it does not change the state of the microswitch at all. Turning off autolock is pointless if the goal is to make that switch last longer.
Old February 23rd, 2009, 10:12   #10
Johhny04
Do you have the link to the thread? I am having the same problem, driver door when open doesn't turn on the cabin lights or register on the dash that the door is open.
2003 Jetta TDi skid plate, GLI suspension, VR6 brakes, Fat 5 TT rims
2002 Ford E350 7.3L Powerstroke. Weekend workhorse that pulls like a freight train!....sold
2004 Jetta TDI ..... sold
Johhny04 is offline   Reply With Quote
Old February 23rd, 2009, 10:25   #11
puter
There is a link in my sig about that thread.
it uses a radio shack part instead, but works fine.
Old February 23rd, 2009, 10:28   #12
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Hey john,I have a dismantled door lock assembly if you want you can have a switch from it
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old June 25th, 2012, 07:18   #13
GeofH
Location: Florida's Treasure Coast: Tradition, Port St Lucie, Stuart, Jensen Beach and Ft Pierce
Fuel Economy: 35 City/ 42 Hwy (Quick starts and Lead foot)
Here I am at the dealership. The replacement lock assembly is over $185. With labor, the cost shoots to over $400! Reading this, it is only a switch? I will go to an independent mechanic with this information and see if the passenger rear door lock can be fixed. If it is as simple as using the key-like the old days, that will work for me until I can get the door secured. Thanks for the posts!
GeofH is offline   Reply With Quote
Page generated in 0.19278 seconds with 9 queries
[Output: 113.69 Kb. compressed to 95.02 Kb. by saving 18.67 Kb. (16.42%)]
