Old February 4th, 2009, 18:30   #1
massey860
TDI(s): 2000 Jetta
Fuel Economy: 5o miles per Imperial gallon
Default oil pan removal and replacement
I hit a bump in the road and cracked my oil pan. It was not too bad and I did not damage the engine............I have it jacked up and it looked pretty straight forwrd for removal, until I ran into 2 10mm bolts that are hidden just behind the flywheel. I have a manual transmission, in a 2000 Jetta TDI with a 1.9l engine. Do I have to remove the engine to get at these? Is there some special trick or tool? I looked for a "how to" on this, lot's of people have had trouble with hitting something, but no one except me seems to have trouble getting the pan off.
massey860 is offline   Reply With Quote
Old February 4th, 2009, 18:46   #2
MOGolf
MOGolf's Avatar
Use a long ball end 5mm hex bit, or a 1/4 inch drive 10mm socket on a u-joint with extension to reach them.
MOGolf is offline   Reply With Quote
Old February 4th, 2009, 18:58   #3
TopherDI
TopherDI's Avatar
Fuel Economy: ~47mpg
In other words you get to go buy new tools. Not a bad day all things considered.
255,000 mi., RC3, PP502s, 2.5" DP, DC Stage I Clutch, STR.Ts and Koni Sport Springs, O-Bar Torsion Bar.
TopherDI is offline   Reply With Quote
Old February 4th, 2009, 19:28   #4
Keith_J
Keith_J's Avatar
Fuel Economy: 38 MPG @ 80 MPH with 2 bikes on top. 52 MPG @ 60 MPH slick
I used my Bondhaus Ball Driver L-wrench. And a small goosneck LED penlight.
Now, when you go to install these two screws, it will be fun. But not if you put a little of the sealant for the oilpan into the socket head of those two screws. This holds the screw on the end of the Ball Driver end just enough to make it easy but not enough to interfere. Just a tiny bit, like half a grain of rice worth.
Then go get a massage on your neck and take some NSAID pain relievers.
2k Jetta manual. PP520s. Ventectomy, Panzer Plate, DT hitch, 16"s w/ 205 55s. Short shifter. Boost gauge with blue LED backlight, same intensity as dash. Blistein struts and shocks. 0.658:1 5th gear swap and LOVING IT.
Keith_J is offline   Reply With Quote
Old February 16th, 2009, 08:53   #5
massey860
TDI(s): 2000 Jetta
All went according to plan. Well, almost. I did not realize that there is a groove in the flywheel, which makes it far easier to get the bolts. That said, I removed the pan, and put it back together. I still had a leak though...........so I redid it, and put some form a gasket on it............still leaked. Upon taking it apart again, I see that my rear seal is cracked. Not sure how I managed to do that but it must be replaced.
Old February 16th, 2009, 09:40   #6
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Cracked oil pan
After you replace oil pan buy & install an Evolution skid plate! Evolution Auto Accessories - Specializing in Volkswagen and Audi preformance p
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old February 16th, 2009, 09:47   #7
joetdi
Or just stop driving over stuff.
joetdi is offline   Reply With Quote
Old February 16th, 2009, 11:10   #8
billo14
Fuel Economy: 40 -45
I have been considering an aluminum skid plate and went to your link. Evolution Import specifies 2005.5 and up for product fit specs. I have a 2005 Jetta TDI Tiptronic transmission.
How do I assure that this unit will fit? Is there something in my VIN number that will confirm if I have a 2005.5?
billo14 is offline   Reply With Quote
Old February 16th, 2009, 11:29   #9
paramedick
paramedick's Avatar
You need the skidplate for the A4 cars. Fits very nicely. So does the dieselgeek and the galvanized skidplate by tdiwagonguy.
Old February 16th, 2009, 15:26   #10
billo14
Can't seem to find the tdiwagonguy's information about the galvanized unit he sells. And, my question really pertained to the Evolution Auto's spec on the 2005.5 unit ............ if it would fit my car. Anyone have an idea on that question?
Old February 16th, 2009, 15:58   #11
LurkerMike
LurkerMike's Avatar
Fuel Economy: -Whitey: 38-40 mpg Hwy @ 80 mph / -Red 46 mpg Hwy @ 80 mph
I have Dieselgeek aluminum skid plates on my 2000 TDI's and they are scraped and gouged from striking parking blocks, running over ladders in middle of the interstate, jumping speed breakers and slamming the bottom hard onto the pavement when bottoming out at speed... never any problems, no worries...
LurkerMike is offline   Reply With Quote
Old February 16th, 2009, 18:43   #12
paramedick
paramedick's Avatar
2005 Jetta is an old body A4. Same as any other Jetta made since 1999.5
2005.5 Jetta is the new body A5 cars.
It's important that you differentiate when you post or order parts online.
Old February 18th, 2009, 05:57   #13
billo14
Yes, and that was my question ...... how do I differentiate which it is.??
I already knew I wanted to order one. But I didn't want the wrong one.
Dieselgeek was understanding the question, answered it, and received the order for the A4 skid plate. Thanks, Dieselgeek.
Old April 1st, 2009, 20:39   #14
Keven
Any more tips for oil pan removal on these cars? Does anything have to be removed or is pretty much a straight shot? Should anything else be replaced while I am down there or just the actual oil pan and gasket?
2000 Jetta TDI - 5pd with 190k miles
2002 Jetta TDI Wagon - Auto with 149k miles - Mom's
2004 Jetta TDI - 5 spd with 140k miles - Sister's
Keven is offline   Reply With Quote
Old April 2nd, 2009, 13:06   #15
Powder Hound
Powder Hound's Avatar
Well, you could do the main & con-rod bearings and the oil pump. But if they don't need it, then why?
Or the real main seal. But that one requires pulling the transaxle and flywheel, so it's not one you would do "while I am down there."
So yeah, guess the oil pan itself will have to do.
Page generated in 0.16181 seconds with 9 queries
[Output: 124.17 Kb. compressed to 103.09 Kb. by saving 21.08 Kb. (16.98%)]
