Old February 2nd, 2009, 15:21   #1
vwjettadsl
vwjettadsl's Avatar
Question Car starts for 2 seconds then dies
Working on a 1999.5 Jetta 5-speed (not the one in my sig). Car starts for up for about 1-2 seconds then dies, but it doesn't always start. Usually it only starts up for 1-2 seconds if has been left sitting for awhile. If you try starting it repeatedly it gets to the point where it won't start up, it will just turn over.
Any ideas?
So far I've checked the 109 Relay, found that it wasn't sending power to fuse #32, #34 or #43. Fixed that problem, but still no start.
Installed new fuel filter, and cracked open injector lines to bleed any of the air out. Still no start.
Any ideas? Bad fuel pump?
Trusted TDI Mechanic traveling to: MO, KS, IA, NE, OK, AR, IL & TN (Plus more if requested)
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer, I offer mobile tuning service for ALL TDI's + CDI's
www.vwtdisales.com
vwjettadsl is offline   Reply With Quote
Old February 2nd, 2009, 15:22   #2
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
Sounds like an immobilizer problem.
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old February 2nd, 2009, 15:29   #3
vwjettadsl
vwjettadsl's Avatar
I wish it were that easy, I've experienced immobilizer problems before. But this is a 99.5 model, no immobilizer installed, so it has to be something else.
www.vwtdisales.com
Old February 2nd, 2009, 15:32   #4
whitedog
Anti shudder valve. Check my signature.
Can fold paper in half eight times.
Old February 2nd, 2009, 15:42   #5
vwjettadsl
vwjettadsl's Avatar
I've read section 5 of your thread already. EGR valve is clean no gunk in it. Its definitely open.
Any other ideas?
www.vwtdisales.com
Old February 2nd, 2009, 15:44   #6
whitedog
Check for voltage to the shut off solenoid on the pump. See if it goes away when the car dies.
Old February 2nd, 2009, 15:53   #7
vwjettadsl
vwjettadsl's Avatar
Nope, still has around 11.5 volts after it dies.
www.vwtdisales.com
Old February 2nd, 2009, 16:00   #8
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Any codes stored in the computer?
Trusted TDI Mechanics Map || TDIClub Chat
Old February 2nd, 2009, 16:21   #9
vwjettadsl
vwjettadsl's Avatar
There were some codes stored, but after I fixed the bad connections that was causing the 109 relay not to work, I cleared them and they haven't come back. I think the codes were related to the bad connections.
But the codes were:
17552 / P1144 - Mass Air Flow (MAF) Sensor G70, open circuit/short to ground
17849 / P1441 - EGR Vacuum Regulator Solenoid Valve N18, open circuit/short to ground
18025 / P1617 - Glow Plug Indicator Lamp K29, open circuit/short to ground
18027 / P1619 - Glow Plug Relay J52, open circuit/short to ground
18047 / P1639 - Throttle Position (TP) Sensor 1/2 G79 + sensor 2 G185, implausible signal
None of these codes should prevent the car from starting.
www.vwtdisales.com
Old February 2nd, 2009, 16:30   #10
joetdi
What does the airfilter and snow screen look like?
joetdi is offline   Reply With Quote
Old February 2nd, 2009, 16:34   #11
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Throttle position sensor?
What throttle?
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old February 2nd, 2009, 16:42   #12
vwjettadsl
vwjettadsl's Avatar
Air filter is clean, snow screen only had a minimal amount of debris, nothing to worry about.
www.vwtdisales.com
Old February 2nd, 2009, 16:43   #13
whitedog
How about that Anti shudder valve? You can unplug it and see if it still shuts down.
Did you just do an auto-to five speed swap by chance?
Old February 2nd, 2009, 16:59   #14
vwjettadsl
vwjettadsl's Avatar
WOW! I unplugged to vacuum hose and the car ran! It ran really rough with lots of white smoke, but it ran. Strange because whenever I looked at the EGR lever it was always open, but I guess whenever I tried starting it it would close up.
Now is the EGR bad or what? Theres only a light oily film inside of it, no carbon build up.
THANKS!
www.vwtdisales.com
Old February 2nd, 2009, 17:13   #15
whitedog
Did you happen to swap that wire wire with the one that goes to the CCV heater on the intake hose? I've heard of this happening. I won't mention who did this, because I hate to embarrass myself that way.
Page generated in 0.15505 seconds with 9 queries
[Output: 131.13 Kb. compressed to 109.32 Kb. by saving 21.81 Kb. (16.64%)]
