Old January 26th, 2009, 16:46   #1
ItsADiesel
ItsADiesel's Avatar
Question Fuel Pump Relay location???
i have a 2002 Jetta TDI that wont start and im pretty sure its because its not getting fuel. i want to check the fuel pump relay but i have no idea where it is and everywhere else ive looked online hasnt given me ANY help at all. i figure you guys are the experts when it comes to TDIs. PLEASE HELP! thanks!
ItsADiesel is offline   Reply With Quote
Old January 26th, 2009, 16:49   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
What makes you so sure it's the relay?Have you checked the filter,fuel lines for bubbles,pressure at the injectors?
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old January 26th, 2009, 16:51   #3
DanG144
There is no in tank fuel pump, or fuel pump relay on your engine. No electric fuel pump at all.
So listen to Jason's questions.
Dan
Old January 26th, 2009, 16:53   #4
JASONP
JASONP's Avatar
Given the year of your car and possibility of it have a C or D level fuel sender and the temperature there right now,you may be experiencing geling
Old January 26th, 2009, 17:00   #5
ItsADiesel
ItsADiesel's Avatar
it died on me while i was driving about 2 weeks ago. i assumed it just gelled up on me, its done it before. so i replaced the fuel filter and waiting for a "nice day" (about 50 degrees) to try and start it. it will crank all day but wont start.
Old January 26th, 2009, 17:02   #6
JASONP
JASONP's Avatar
Did you break the "O" ring around the Thermostatic Tee when re-installing it,it happens and you won't even know it,I'd start there
Old January 26th, 2009, 17:04   #7
ItsADiesel
ItsADiesel's Avatar
just checked and its still good.
Old January 26th, 2009, 17:07   #8
JASONP
JASONP's Avatar
Ok check this to see what version you have
http://forums.tdiclub.com/showthread.php?p=647602
Old January 26th, 2009, 17:15   #9
ItsADiesel
ItsADiesel's Avatar
well thats what the fuel sending unit looks like, but i thought u were talking about the fuel filter?
Old January 26th, 2009, 17:16   #10
JASONP
JASONP's Avatar
I was talking about the fuel filter first, you said it was fine right,this is the fuel level sender in the tank
Old January 26th, 2009, 17:22   #11
ItsADiesel
ItsADiesel's Avatar
what about the fuel level sender could prevent the car from starting?
Old January 26th, 2009, 17:24   #12
JASONP
JASONP's Avatar
Look closely at the sender,this unit not only transmits fuel level,it is also where the pick up is for the fuel filter,look close you'll see it
Old January 26th, 2009, 17:29   #13
ItsADiesel
ItsADiesel's Avatar
ok, but what exactly am i looking for? haha
Old January 26th, 2009, 17:30   #14
JASONP
JASONP's Avatar
The little triangle section and a check valve,that is what gels up and prevents flow
Old January 26th, 2009, 17:32   #15
ItsADiesel
ItsADiesel's Avatar
oh alright thanks. ill check that and get back to you haha
Page generated in 0.18220 seconds with 9 queries
[Output: 119.66 Kb. compressed to 98.45 Kb. by saving 21.21 Kb. (17.73%)]
