darrenf
Westfalia euro-style towbar on an '09 JSW [UPDATED w/ Bike Carrier Pics]
[UPDATE: post #36 contains photos and purchase details of a bike carrier made to mount to this hitch, along with pricing and where it can be sourced.]
As I've posted before, I was not too comfortable with the Curt hitch on my '09 Sportwagen. It wasn't connected to the car as solidly as I would like and it hung down very low on a car that already drags the ground from time to time.
I was intrigued by the factory hitch. It's not available in the US (and not, I am told, DOT approved) but has the advantage of being very solidly attached to the car frame and easy to hide when removed. It also starts in the bumper so there's nothing to drag the ground with.
I believe that the factory towbar is made by Westfalia, although some have mentioned Bosal as the OEM. BTW: "towbar" is the European name for a receiver hitch, not to be confused with a US towbar which is used to pull one vehicle behind another. Towbars come in three flavors: fixed (which are permanent and non-removable like a bumper-mounted truck towball), removable and swan-neck. I'm not real clear on the difference between removable and swan-neck, but Westfalia has by far the coolest removable I found. Check out this video of someone taking the removable part out and reinstalling it:
http://www.strimoo.com/video/12744090/Westfalia-Detachable-MySpaceVideos.html
It really is that easy.
Here's another video:
http://www.youtube.com/watch?v=8uP349JHXsw
although the shape of this one is a little different than the one supplied for the Jetta, the installation is exactly like that. To top it off, once installed, the tow ball is an extension of your car. Jump up and down on it and the whole car bounces with you. There is absolutely no slop, either up and down or side to side, as there is in a US receiver/hitch combo. This may be part of the reason that the hitch specs and the Euro Jetta specs list the pulling strength at two tons -- more than the weight of the car!
I purchased the Westfalia towbar model 321630 from TM Tuning for $340 + $13.35 "international order fee" and shipping (2-week "standard air") of $105 for a total of $458.35. I found the same towbar in the UK for far less (a product of the extraordinary GBPound to Dollar exchange rate) but I couldn't convince a single vendor to ship one to me. A US company offers them for over $650.
Here are the photos of the finished product:
The U-shaped part leading from the tow ball to the receiver has a lock integrated into the spring-loaded install/removal mechanism. You put in a key, turn it 90 degrees, then pull a knob and turn it 45 degrees and the tow ball part comes out:
The red cap you see is the top of the key. The black piece of plastic on the ground is the cover that goes over the key slot when the towball is installed and the key has been removed (presumably to keep water and road grit out).
With the tow ball removed, the remnants of the towbar are recessed inside the bumper:
Here are other angles. In the first, you will see the cover on the ground. I haven't decided how to make it installable and detachable yet so I've just left it off:
Next up -- installation photos
