Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old January 25th, 2009, 05:05   #1
blaz
TDI(s): 05 Passat
Default Ontario 04-05 Passat Balance Shaft Repairs
The TDICLub B5 (B5.5) Passat forum is full up with threads about balance shaft chain failures. The oil pump then stops pumping, and you have to shut down the engine fast.
Here's the sticky thread outlining the problem, the fix (upgrade to a geardriven balance shaft) and other info:
http://forums.tdiclub.com/showthread.php?t=233651
Any Ontario members planning to do this upgrade? I was thinking Brandon (VDubTech) would be a good candidate to ask about it. There are some special tools required ...
Since I've got the extended warranty to 160km, we'll probably wait until then and do the belt and conversion at the same time. Unless it blows under warranty, it is not a cheap repair.
2005 VW Passat Wagen TDI dechained, 39mpgUS non-Winter
2011 Chev Cruze Eco (Turbo) 41mpgUS non-Winter
2011 Ford F150 V6 Ecoboost (Bi-Turbo), 20mpgUS non-Winter-Towing
blaz is offline   Reply With Quote
Old January 25th, 2009, 06:45   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
That's a lot of readin right there.
I have been hearing more and more of this issue lately.
I have always lusted after the B5 wagons, andalmost bought one a while back.
I think I will continue my search for an ALH jetta wagon or B4 wagon (variant).
I hope for all B5 TDI owners that VWOC/OA steps to the plate and covers this repair, given that it happens to every car.
'spensive repair...
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old January 25th, 2009, 11:47   #3
blaz
TDI(s): 05 Passat
At least the problem is well documented and a good fix is available. MOGolf, Oilhammer and others in the Passat B5 forum put a lot of effort into this. It's just that you need a competent mechanic and the $$$ to do it. I'd hate to have to go to St. Louis, Missouri and get Oilhammer to do it.
Our old Pontiac Transport had lots of problems after 100k km (engine gaskets, air conditioner, ABS sensors), and we spent $1000's on it to keep it running to 200K km. It was cheaper than buying new, and it was easy to get fixed as there were mechanics familiar with the car just about everywhere. But eventually it just fell apart.
I'm willing to spend even more $$ on this Passat as it's a better car and I love the diesel. It's over 100K km now and I'm hoping it will go to 300K km over the next five years (or better) before it gets too unreliable. I think the main problem will be the availability of good mechanics who know these cars as they are pretty rare. But with these TDIClub forums and "proactive" repairs, we may get there. We'll see.
Old March 25th, 2009, 02:16   #4
cos
cos's Avatar
I just bought a 2004 Passat TDI, now I have 132,000Km on it and I will have to spend some money on it. Good think the car was cheaper than most ones available in Ontario and in very good shape, so I can spend about 3K to get it done the right way.
So I am asking if anyone in Ontario has done the BS modification and where.
I have a good mechanic, german guy (Heindrich) who works only on VW and Audi and I will bring the procedure to him to see what he says. I think a good mechanic who can change a timing belt, with such good info it would not be too hard to change the BS Module. Bad thing is that the parts cost about US$1300 plus shipping to Canada and probably some customs fees.
PS What about the glow plugs mod?
Addicted to Passat
2004 Passat TDI Chainless, Glow plugs mod.
1992 Passat GL (2.0L 16V) since new untill Jan. 2009.
1996 Chevrolet 3500 HD 6.5 Diesel since new untill 2002.
cos is offline   Reply With Quote
Old March 25th, 2009, 04:45   #5
owr084
COS -
Time to take a vacation http://maps.google.com/maps?f=d&sour...775391&t=h&z=6
Actually, there is one guy in New York that is reasonably close to you. Check the threads.
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old March 25th, 2009, 04:47   #6
yatzee
yatzee's Avatar
TDI(s): see sig
cos - you should be able to get the parts from the dealer - they are VW parts afterall. As for who does the job, I would only trust that job with a recognized guru, such as Brandon or maybe Gerry if he's interested. I'm sure your mechanic is good, but we've all read too many horror stories of repairs getting botched
2015 Passat TDi 6 spd, 2008 WK CRD, 1991 405 mi16, 1992 300D, 1986 and 1987 190e 2.3-16, and a couple 2 wheeled things
yatzee is offline   Reply With Quote
Old March 25th, 2009, 04:51   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Come on down! I'll even open the shop up for another weekend! So long as you guys bring some of that nice cool Canadian air down here with you.
oilhammer
www.cardocautomotive.com
Old March 25th, 2009, 07:28   #8
blaz
TDI(s): 05 Passat
We know Orangeville VW has done "a few". In fact Scott, one of their mechanics, contributed a bit to the write-up.
However, being a dealer, you may not get the best price. I'd give Brandon a call; you may be his first though. Or if you go through Heindrich, and it works out, we would all like to know who he is and how to contact him.
As for the steel glowplugs, by all accounts it's worth the switch, but up here you pretty much have to have the dealer reflash your ecu I think. See the thread about them in the B5 forum.
Old March 25th, 2009, 07:45   #9
blaz
TDI(s): 05 Passat
If you want to try a place closer to home, contact H2Sport in Georgetown. By all accounts they are good (search on them in this Forum) but are more experienced with gassers than diesels.
Old March 25th, 2009, 13:41   #10
xctdi
How many people in Ontario need the BS Upgrade???? 2005 - 145,000KM on our Passat.
xctdi is offline   Reply With Quote
Old March 25th, 2009, 16:25   #11
blaz
TDI(s): 05 Passat
How many 04-05 passat TDIs in Ontario?
Oilhammer says they will all need it eventually.
Some have failed early (and it can be disastrous) but at least then you should be under warranty. Others are still going at 150,000KM and above. I plan to do mine at 160K along with the timing belt, assuming it doesn't blow earlier. But then I have an extended warrant until then.
Old March 25th, 2009, 16:36   #12
wolfsburg
TDI(s): 06 Golf
I am planning on having these repairs done in the next week along with the timing belt. I have been speaking to Brandon about it and he is going to do the work for me on my passat.
I will let you all know how it goes once its done.
2006 Golf TDI
2001 Jetta TDI
wolfsburg is offline   Reply With Quote
Old March 25th, 2009, 18:09   #13
blaz
TDI(s): 05 Passat
This is great news. I wasn't sure if he was willing to make the investment in special tools and so on. I'll definitely be asking him as well when the time comes.
Are you purchasing the parts yourself or will he supply them?
Old March 26th, 2009, 03:36   #14
cos
cos's Avatar
Hi Oilhammer. Could you please send me a mess how much you charge to replace the TB, BS module and water pump? Parts and labor. Any taxes? Canadian $ is low now and it would cost us a lot of money to do it down south. He, He, I wish we had now last year's exchange rates.
As for the weekend no need to open, I could come down there any day of the week.
Addicted to Passat
Old March 26th, 2009, 03:58   #15
xctdi
Hey fellow Passat owners....thinking of bringing Oilhammer up to Ontario for a weekend to work on our vehicles instead of us all traveling to St. Louis. Any thoughts on this??? Brandon looks like he might be doing the BS installs at his shop so this might be an option as well.
Page generated in 0.17304 seconds with 9 queries
[Output: 124.42 Kb. compressed to 102.71 Kb. by saving 21.71 Kb. (17.45%)]
