Old January 20th, 2009, 17:55   #1
Nitroholic
Nitroholic's Avatar
TDI(s): 01 Golf
Default Has anyone tried VAG-COM with Windows 7?
Specifically 409.1-S with Windows 7 x64
01 Golf 2dr | Malone Tuning | 1749vb | PP764 | PP Downpipe | 2.5" Exhaust | 93006D Cat | Mufflerectomy | CCV Filter | Boost/EGT Gauges | Sachs Clutch / Flywheel
Nitroholic is offline   Reply With Quote
Old January 20th, 2009, 18:02   #2
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Yes, works good.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old January 20th, 2009, 18:34   #3
Nitroholic
Nitroholic's Avatar
TDI(s): 01 Golf
Originally Posted by NB_TDi
Yes, works good.
thanks, going to install win7 tonight
Old January 21st, 2009, 06:40   #4
wolfsburg_de
Ross-Tech AssociateVendor
Fuel Economy: 33.5 mpg, mostly city
http://www.ross-tech.com/vcds/downlo...a/current.html
Release 409.1 came out in September of 2004 and we do not possess clairvoyance, so good luck running that with W7.
support@ross-tech.com
wolfsburg_de is offline   Reply With Quote
Old January 21st, 2009, 13:57   #5
Sebastian
Beta 812 works fine on Windows 7 running on an Asus EeePC 901.
Sebastian
Sebastian is offline   Reply With Quote
Old January 11th, 2010, 10:30   #6
JDub8
Yes, works good.
Would you mind elaborating on how you got 4.09 running in windows 7 64-bit?
I'm having a hell of a time.
JDub8 is offline   Reply With Quote
Old January 11th, 2010, 20:02   #7
wokwon
VCDS 9.08 works fine in Windows 7 x64 Ultimate
wokwon is offline   Reply With Quote
Old January 12th, 2010, 07:21   #8
NB_TDi
NB_TDi's Avatar
Although I didn't have to do this if you are having issues...
http://www.sevenforums.com/tutorials...lity-mode.html
Old April 18th, 2013, 09:03   #9
uaPtah
TDI(s): Jetta 03
Lightbulb
I now this is an old post, however it may help other people who are having same issues at a present time.
Please see this thread:
http://www.passatworld.com/forums/42...-7-64-bit.html
uaPtah is offline   Reply With Quote
Old April 18th, 2013, 11:37   #10
BeartheBruce
BeartheBruce's Avatar
Why don't you just download VCDS-Lite for free and run it? It was updated to run with Win 7 and replaced VAG-COM 409 - three or more years ago!
-Bruce-
Ross-Tech, LLC
Bruce@Ross-Tech.com
BeartheBruce is offline   Reply With Quote
Old October 7th, 2014, 20:28   #11
wfodave
TDI(s): n/a
I'm trying to get Vag-Com 409 to run because while I have been able to use VCDS-Lite to connect to many of the controllers in my car, it won't connect to the airbag controller, which is what I need. Someoe posted that they were able to connect to their airbag controller using the old vag-com software, so I want to try it.
wfodave is offline   Reply With Quote
Old October 8th, 2014, 11:23   #12
forcedfedbug
What is your car? 409 I believe may have had an issue with some cars and some AB controlers. If your car is old enough where that works looking at your AB controller may not be a good idea. That really depends are your car. My car is a 2000 beetle. That car was supposed to have the AB with problems however I scanned that module lots and lots of times with old outdated software with the old iso controller cable and my AB light never came one. With that said though it is a known issue that some AB controllers do no like that software so you may have issues with it if you scan it with old software and you have the controller that is known not to work with it.
Ron
forcedfedbug is offline   Reply With Quote
Page generated in 0.17188 seconds with 9 queries
[Output: 103.53 Kb. compressed to 86.36 Kb. by saving 17.17 Kb. (16.59%)]
