Old January 19th, 2009, 15:01   #1
Mr.Bob
TDI(s): 04 jetta
Question bew maf
I tried all the fixes on maf including replacement with no results. What next?
Tried: Disconected runs better, cleaned sensor and connections, tried the grease, had VW read the codes(127508 air flow too high} replaced the maf. Still limp mode with uphill acceleration. I've tried the test with the egr vlave. Ignition on doesn't move the valve. This is the electric egr valve. No significant carbon buildup on egr valve or intake. 150,000 miles. Egr cooler has been replaced. A reading from Autozone indicated insufficient egr flow. Vw found no egr codes. What next
Mr.Bob is offline   Reply With Quote
Old January 20th, 2009, 10:26   #2
d2305
Replace the vacuum lines.
d2305 is offline   Reply With Quote
Old January 20th, 2009, 10:52   #3
puter
Fuel Economy: 57 mpg
vac lines are a good bet
my sig has a writeup on troubleshooting limp mode, look at the write up.
puter is offline   Reply With Quote
Old January 20th, 2009, 11:00   #4
JB05
Fuel Economy: 43/41/40
Who replaced the EGR cooler? Dealerships have been known to botch the job. I'm thinking a cracked pipe, bit I'm no Guru.
JB05 is offline   Reply With Quote
Old January 23rd, 2009, 15:34   #5
mctdi
TDI(s): 2010 Jetta
Is there a boost leak?
Ben / mctdi
10/24/2015 => 300,262 miles
5/29/2010 Jetta 12 miles [new],
R.I.P. 2004 Golf 362,993 miles,
mctdi is offline   Reply With Quote
Old January 23rd, 2009, 16:36   #6
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Maintenance
What kind of maintenance have you done? Replace air filter? Replace fuel filter? Checked to see that nothing is blocking air flow to engine?
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Page generated in 0.12894 seconds with 9 queries
[Output: 69.95 Kb. compressed to 60.91 Kb. by saving 9.04 Kb. (12.93%)]
