I have a new 2009 Jetta TDI with the DSG transmission (1000 mi.). I have now had the transmission hit a 'false' neutral twice on me.
The first time I backed out of a warm garage onto the street, stopped, slid it into Drive, and it just reved and didn't engage when I pushed the throttle. I looked at the lever to check and it was in Drive. I shifted to neutral, then back into Drive and it then worked perfectly.
Yesterday, I was driving in the city, car warmed up, and I was sitting at a stop light. I slid the lever into the tiptronic mode in 1st gear. The light turned green and I pulled away at an easy clip, and as the tach hit 3000 RPM, the revs took off and headed for redline. I was not accelerating hard and have worked though the gears countless times in this manner. When the car reved, it slowed down like it was out of gear. I tapped it into second and it was fine.
Anyone else heard of this type of issue? I have not been able to duplicate the problem, so I'm sure the dealer won't be able to as well.
Pete
Pete
