| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
January 3rd, 2009, 14:50
#1
Location: near youngstown, oh-- halfway between cleveland and pittsburgh
code P0811 -- clutch slippage excessive (03 jetta automatic) -- what are my options?
What else can go wrong with my wonderful 03 jetta tdi wagon (198,000 miles)? ((just replaced water pump, TB, brakes, tires, thermostat, cooling fan regulator))
It appears my automatic transmission is on it's way out.
I've been noticing what feels like "slippage" especially going up hills at lower speeds and on on-ramps.
Now my CEL is on and the code is P0811 (clutch slippage excessive).
I found 3 other posts on this topic, but no definite resolutions to the problem.
1) if i drive it till it literally dies on the side of the road, can i hurt anything besides the dying transmission?
2) anything i can do to slow transmission death or is it too late? any idea how much longer till it'll completely die on me?
3) what should i replace transmission with? I've seen some posts about converting to manual. Not ideal for me, but I'd do it if there was a huge cost difference.
January 3rd, 2009, 15:01
#2
200K? You did good! Better than average!
All I can say is check the ATF level (it is probably fine) and then get your money out.
Oh, and you can read here:
http://forums.tdiclub.com/showthread.php?t=189029
And of course, Freddie says hi:
January 3rd, 2009, 15:02
#3
Auto
Try changing transmission fluid & filter.
January 3rd, 2009, 16:24
#4
do you think it's too late for that? i don't want to waste more time/money if i'm going to have to convert to a manual or something real soon.
January 3rd, 2009, 16:29
#5
teh stallionz!!1
won't do a thing...
i'm sorry, but changing the fluid won't do squat
January 3rd, 2009, 17:39
#7
Fuel Economy: 4.9-5.5 l/100
Total cost $150
New tranny from dealer $5200
you choice
jason
2010 Tiguan 6M wifes commuter
2010 Golf Wagen Comfortline 6MT
January 4th, 2009, 15:38
#8
Originally Posted by JASONP
Total cost $150
you choice
yeah, good point. i'll try the fluid change and see what happens. i think i'd convert to manual transmission if/when i need a new tranny, or i might junk the thing. car's definitely not worth putting $5,000 into it. i'd rather start from scratch.
January 5th, 2009, 04:08
#9
Geez, what on earth did you do to a baby like a 2003 Jetta that you feel it is not worth putting a transmission in????
January 5th, 2009, 07:39
#10
Fuel Economy: avg 38-40mpg
My auto is going out too. Reverse is totally gone. I had fluid and filter and since a 5 speed conversion wouldnt ever use this filter and fluid, I figured I'd try it. Well, it didnt really do anything that I noticed. It goes forward a bit smoother, but it still doesnt go backwards.
I've been speaking with Ben, aka Alphasenior, who luckily for me is in Dallas, and my bill is going to be about $5K. But that gets me Stage IV clutch, Peloquin LSD, VR6 axels, and a DG shifter (tranny etc too of course). Or, I can spend the same and get another crappy 01M.
The conversion can be done for about $3500, but the clutch and LSD put me over 5K.
Ben said the conversion takes a very full day, ~16 hours.
Just letting you know that it can be done for less than 5K.
Oh, and I got 147,000 miles out of my 01M.
2002 Jetta Wagon GLS 193K/mi - PP357 - VNT17VB - KERMA tune - Carbonio CAI - DG Race Pipe - IDParts OMI/Up'r/Low'r pipes - 01M-ectomy by Dr Alphaseinor - APTuning Race Gear Set - .340 1st - .658 5th - Peloquin LSD - DC Stage III - 18lbs flywheel - DG Sigma Shifter - KONI FSD - Shine Springs - Shine Bar - BFI Stage I all'round - TT CA/Subframe Bushings - Polk MM - JL 450/4 & 250/1 - (2)JL 10W6 - Eclipse 5303R
January 5th, 2009, 09:07
#11
Fuel Economy: 750 miles/tank
+1 a slipping 01m auto is a terminal condition, My experience was fluid, filter and line pressure mod got my a couple 1000k until symptoms returned and transmission required a transplant from a doner 5 speed. Fluid, filter and a tweak on the line pressure might buy you a little time toget parts together for a swap or another paycheck in the bank to help offset the cost to replace the auto..
All parts in with used manual transmission, new clutch and flywheel and the swap is less than half the price of a remanufactured auto tranny. Cost me about $1950 taxes and fluid changes, rear main engine seal included. About a 3 day weekend job first time round including ods and ends like cleaning the intake, fixing exhaust leak, Think I could do it in a weekend if had all the parts together and did not mess with other issues, I'd bet some of the gurues here could get it done in a long day.
http://forums.tdiclub.com/showthread...=kill+the+auto
January 5th, 2009, 14:27
#12
doesn't make sense to me to put another $5,000 into a car that's paid off w/200,000 miles on it. that's 1/4 the price of a realtively new one.
I talked to bob scofield in warren, oh, today, who i was referred to by someone on this forum. He basically said I'm playing Russian roulette if i mess around with my transmission fluid now that the car has so many miles and the fluid's never been changed. He said he can change the fluid and we can see what happens, but it could dislodge "gunk" and mess up the tranny even more. It'll be close to $300 to service it if i want to try. He said he's never flushed a tranny for the first time with so many miles or when the tranny is already producing symptoms of failure, so he said it's up to me if i want to try my luck with the flush. any suggestions?
I also chatted briefly with him about swapping out the automatic for a manual, and he more or less ruled that out. i'm surprised he doesn't do that if he's been working on VWs for so long, but it looks like i'll have to look to a guru on here if i want to swap to a manual tranny.
at least i know that following VW's suggested maintenance is useless. they want you to have to replace the tranny ever hundred thousand miles.
January 5th, 2009, 15:12
#13
Hmmm....I put new 01Ms in those all the time. $4700 is sure cheaper than a new car (last I checked). If the car is otherwise in good shape, and you said it is paid for (the best kind of car, IMHO), then I do not see why not...but 200k miles is hardly used up in my book. Heck, mine is over TWICE that
January 5th, 2009, 15:43
#14
i just did the TB/water pump again and new brakes, so i haven't ruled out replacing the tranny. just seems kinda crazy how expensive it is.
do the new 01Ms fail like the tranny I have now? (if i replace it now, will i likely be replacing it again once i hit 300,000 or 350,000 miles)? i guess at least now i know of a reputable VW mechanic and I know to change the ATF.
Do you have an opinion about changing the ATF now? think it'll mess the tranny up even more?
what will happen when the tranny dies? will it just get stuck in a gear and leave me stranded in a parking lot or on the side of the road. ideally i'd like to get another 6 months out of this tranny, but i'm betting that won't happen.
January 5th, 2009, 15:53
#15
Good Ol' Boy
Fuel Economy: see signature
Don't waste your time and money changing the fluid and filter. It isn't going to make the situation any better, and it certainly isn't going to make the transmission last long enough to justify the cost of the fluid and filter change.
I'd look around for a 5-speed conversion for it if the rest of the car is in good shape. 200,000 miles is not that much, especially considering that you just did the timing belt, water pump, and brakes.
Rough times... do what makes economic sense (stay with the car that's paid for).
