2footbraker
Anybody out there using TDT on their BRM? I am willing to do anything to avoid the cam/follower failure. This seems to be the "it" oil for the PD now.
Regular oil analysis should be done to catch the problem early if does start to happen.2footbraker said:Anybody out there using TDT on their BRM? I am willing to do anything to avoid the cam/follower failure. This seems to be the "it" oil for the PD now.
That would seem to make the power output to blame if true.2footbraker said:From reading a UK VW forum, I would have to agree. It seems that the pd cam failures across the pond are more common on the pd150s, less so on the pd130s and much less common on the pd100s.
I was just speaking hypothetically based off what 2foot said...GoFaster said:There may be some indirect relationships. Since we are talking about a 4 banger engine, the bangs are bigger with more power output, which increases the pulsations. But if ANYthing is going to be affected by this, it's the timing belt, not the lifter-to-cam-lobe relationship. And that's only if the driver uses the extra power a lot.
The other influencing factor might be that the higher power output puts more soot in the oil, and possibly more fuel dilution, but again, only if the driver uses the extra power a lot.
At some point I should take the valve cover off mine (BRM) and have a look. 216,000 km on it, chipped, 505.01 5w40 is all it has ever seen, and I tow a trailer a lot. If the pulsations or soot theories hold any water, the extra load from trailer towing ought to make mine a worst case. (Knock on wood, but at least from the way it sounds and drives, there's not a hint of trouble!)
OK that's all well and good but when I switch to TDT and my Fe counts start trending down by 80%, what am I supposed to believe?Zero10 said:I thought we had this fight and all agreed that it was either a cam or lifter defect? That is the idea I am running with. If you have a bad cam and/or lifters they will fail early, regardless of what oil you use (505.01 or TDT, not peanut oil), and if you have a good one the opposite is true as well. I have run Elf 507.00 for most of my engine's life (2 OCI on 505.01 1 on 506.01 and 5 on 507.00) and have been posting UOA's with the iron count on the high side every time. Valve cover has not been off and unless it starts leaking, will nto come off. Just some more data for you to cram in your head when you make your decision
I think it's clearly stated...If you use an oil that doesn't meet VW 505.01 in a P-D, expect high camshaft and lifter wear in the long term. MOBIL 1 IS NOT GOOD ENOUGH. These engines have unusually high contact pressures between the camshaft and lifters due to the narrow cam lobes forced by the space taken up by the P-D injector mechanism. It is NOT a safe assumption that an oil suitable for large truck engines which also have unit injectors will work in a VW P-D TDI.
__. True, Brian but a 150HP engine will accelerate from 1000 to 4500 RPM in 2nd gear a lot quicker than a 100HP engine. And acceleration -- the speed at which that "opening ramp" hits the lifter -- is a big player in whether a valve operates properly and how long it lives for. This is just a wild guess on my part but it could be related to "spec and use" differences.GoFaster said:Power output can't be the sole factor. In fact, I don't see how it could be related directly. The engine's crankshaft output power does not get transmitted through the valve train.
Well, do you believe the only source for iron as a wear metal in your engine is from the camshaft?dhdenney said:OK that's all well and good but when I switch to TDT and my Fe counts start trending down by 80%, what am I supposed to believe?
what are you looking for: "best" protection or easiest access2footbraker said:Yeah, but you can buy Mobil TDT at Walmart. Good luck finding any 505.01 oil there!
Also, doesn't higher fueling correspond to more pressure needed to push the fuel through the injectors, which would need more energy transferred from the cam?mrGutWrench said:__. True, Brian but a 150HP engine will accelerate from 1000 to 4500 RPM in 2nd gear a lot quicker than a 100HP engine. And acceleration -- the speed at which that "opening ramp" hits the lifter -- is a big player in whether a valve operates properly and how long it lives for. This is just a wild guess on my part but it could be related to "spec and use" differences.
Sorry oil sheep, mobil 1 TDT or delvac is far superior to any 505.01 oil.hid3 said:A quote from 'What oil should I use' thread:
