Old January 3rd, 2009, 10:42   #1
tg2122460
TDI(s): 2000 1.9
Default code p0380 2000 jetta TDI
Hi folks, hopefully someone can help, I have a P0380 code Glow Plug / Heater 'A' circuit.
The voltage at all 4 flow plugs jumps only microvolts when the ignition switch / glow plug dash light is lit. Both wires on the harness from the hidden connector to each GP socket harness seems good (ohm meter) and each glow plug measures the same resistance (about 1 ohm).
The circuit seems to be dead so I'm thinking there must be a relay (under tha dash?) that controls this circuit, where is it?
Any other ideas?
Can someone point me to a wiring diagram.
Tim.
tg2122460 is offline   Reply With Quote
Old January 3rd, 2009, 11:16   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Depending on if you have 2 or 4 wire harness,it won't tell you which one has a short.
2 wire won't,4 wire will
check this link
http://forums.tdiclub.com/showthread...ight=glowplugs
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old January 3rd, 2009, 19:22   #3
tg2122460
TDI(s): 2000 1.9
An update - it appears the GP circuit may in fact be fine. With the coolent sensor disconnected the glow plug circuit voltage goes to 12.55 volts for approx. 20 seconds at each GP socket. It is a 2 wire harness.
So now I'm wondering why the engine light went on in the first place. I had a shop give me the stored code when it was in for other work, now I need to reset it. I'm in Guelph as well.
Old January 4th, 2009, 16:31   #4
P2B
P2B's Avatar
Often caused by oxidation of the harness contacts at the glow plugs, in which case simply disconnecting and reconnecting the harness to check glow plug resistance may have already fixed it.
I suggest posting a request in the Ontario forum, hopefully you can find a member closer than me (Toronto, DVP & 404) with VAG-COM to reset it for you.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Page generated in 0.12458 seconds with 9 queries
[Output: 59.73 Kb. compressed to 53.12 Kb. by saving 6.61 Kb. (11.07%)]
