cujet
As some of you have experienced, the EGR cooler develops a leak at the valve shaft. This results in an exhaust leak at times and a boost leak at other times.
Here is the problem, the EGR cooler valve shaft has a "soft" seal on it. The seal is held in place by a spring clip. The shaft is also centered by the seal. Think of it as a coiled piece of rope trapped in a cavity with a shaft in the middle. Not a good design!
So, I made a brass bushing shaped like a "T" that replaces the soft seal and it's retained by the OEM clip. It works like a charm! It will never leak again.
Just an FYI, if anyone here wants to know how to do this, or needs the dimensions of the bushing I produced, feel free to email me.
Chris
Chris
