Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old December 30th, 2008, 14:28   #1
gstdi
Default Floor Jacks - any good ones out there??
I'm on what has to be my 9th or 10th floor jack, and am about ready to pull out my hair. They all seem to fail (won't lift) after about 2 years of light-duty use.
I've bought floor jacks from:
- Snap-On (had it when I was a full-time tech)
- Crafstman (had 2 of them)
- Nordic (had 2)
- AC Delco (had at least 2)
- Harbor Freight
My current floor jack, a 4-ton "heavy duty" Craftsman just died on me, and I'm so sick of buying new floor jacks. It's absolutely maddening. Anyone know of a good floor jack that'll last for more than a year or 2?
I'm only lifting small cars (Jetta, Cooper, BMW 3 series), and I only use the floor jacks maybe 4-5 times per year. They don't run low on hydraulic oil - they just quit working... ugh!
gstdi is offline   Reply With Quote
Old December 30th, 2008, 14:46   #2
jobob307
jobob307's Avatar
Fuel Economy: 50/53
I have a low profile from NAPA I have had very good luck with it.
O1 jetta vnt 17/22, pp764's,11mm pump,egr delete, geek race pipe, geek, All custom charge piping, VR6 air box and MAF, 3 bar map, cat delete, RC 6 + special sauce, limited slip diff. 658 fifth gear. geek skid plate, 5 light mod, FK euro lights, that dome light thing,
jobob307 is offline   Reply With Quote
Old December 30th, 2008, 14:54   #3
Honeydew
here is one thread with some suggestions
http://forums.tdiclub.com/showthread.php?t=198872
Honeydew is offline   Reply With Quote
Old December 30th, 2008, 15:06   #4
lawallac
lawallac's Avatar
Fuel Economy: 57 MPG
I agree with you there are some really bad ones. I was looking for one to keep in the car. Really I was looking for something with a case. I looked at Harbor and the only one they had with a case was the 12v scissor jack. I've seen the same one rebranded in Northern Hydrolics and a couple other places.
The part that makes contact with the car is made entirely of plastic. I found this out when I was lifting the car to mount snow tires and it broke in two.
I'm sure there are good ones but they are undoubtedly expensive. Then again SnapOn isn't cheap.
2002 JETTA 5SP -RC 4, PP520S, VNT 17/22, Mufflerectomy, 3 Bar MAP, SBC Stage 3 with 17# FW, Snow Screen Tossed, Bilstein HDS, H&R OE Sport's, Alientech Window Controller, Clear Side Markers, Phatbox, Memphis 12, Oldschool Fosgate 800 a 2, Panzer Plate, TDI Heater, Ariettas, DG Race Pipe, EGR Cooler Delete, , TDIParts OMI, Doniol OLED 30 PSI Boost/EGT w/MCA Probe
lawallac is offline   Reply With Quote
Old December 30th, 2008, 15:32   #5
BrianCT
TDI(s): TDI
The Craftsmen jacks are 100% returnable. Even if Sears states otherwise [note: not a K-Mart], speak to a store manager on the issue. In these economic times no one wants bad press [unhappy customers]. If that doesn't work, find out who the District Mgr is for that area and call or e-mail him your complaint.
I've had a 2 ton floor jack for 10 years and never an issue using it several times a month. At times the jack held up a side of a car for an entire afternoon. It was a cheap unit from Autozone $40.00
When I store the jack, I compress the stand pad bottoming out the pneumatic while tightening the release valve shut. Maybe you're storing the jacks with the release valve open allowing moisture or air to damage the seals or leak oil?
Month or so ago I went to Harbor Freight and bought this unit. I needed some urgent work and needed a second back up jack.
BrianCT is offline   Reply With Quote
Old December 30th, 2008, 15:48   #6
VW Vet
I bought a Sears 2 ton floor jack in 1978. Have used it frequently over the years (as recently as last week) with zero problems. As mentioned above, I store it completely retracted with the valve closed. Perhaps that is the secret.
VW Vet is offline   Reply With Quote
Old December 31st, 2008, 05:25   #7
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
Stop buying junk. Hein-Werner 2 ton-USA made, about 350.00.
If you want a high lift I recommend A/C hydraulics Model DQ13 or DQ20. They range between 700.00 and 1000.00. Made in Denmark with a 2 year warranty.
American forge and Foundry is another good brand.
Be prepared to spend at least 300.00 on a quality jack.
I have owned Craftsman, ATD and a few others. All were crap.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old January 1st, 2009, 23:56   #8
otm646
Fuel Economy: 54/48.5/43
Did you ever open of the reservoir and add more fluid?
I have brought my craftsman back from the dead a few times with just a little more fluid.
76 300d 475k
97 750IL V12 working SLS 187k!
98 Jetta AHU 330k! PD150 intake 2.5 SS straight pipe- Sold to Papa Validius
05 WRX 5 speed wagon 220k + flow mods ~270 HP
81 Lancia Beta Zagato
otm646 is offline   Reply With Quote
Old January 2nd, 2009, 06:27   #9
Variant TDI
Fuel Economy: 36.4min/44average/56.4max. Recently improved commuting from 42mpg to 50mpg with 'new' driving habits and Scangauge.
I've had a $40 craftsman (2.25 or 2.5 ton, I forget) since 1993. I bought it when I went to college, and couldn't bring my dad's craftsman (bought in the early 80s) with me.
He still has that one.
Like others have said... they do need to be topped up with oil every once in a while, but otherwise... they're pretty bulletproof.
--Tim (member: 900 Club... x4, best: 56.4mpg)
2002 Golf Wagon TDI - - 1996 GTI VR6 - - Flickr
Variant TDI is offline   Reply With Quote
Old January 2nd, 2009, 08:49   #10
diesel-dave
diesel-dave's Avatar
Hein-Werner Service Jack – 2-Ton, Model# HW93642
northern tool 319 bucks made in the USA!!!!!
2003 Bora Wagon TDI Bosio R520's,colt cam, VNT 17
q loader. no smoke and so on
2001 Beetle TDI GLS Bosio 764 7 hole's, qloader, VNT 15 and so on
2010 JSW wagon DSG loaded
2003 golf auto PP520's
diesel-dave is offline   Reply With Quote
Old January 2nd, 2009, 17:09   #11
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
I had a Sears jack that lasted me 14 years. When it quit I went to Harbor and got the $50 special. It's junk. wish I would have paid a little more and got something better.
Jetta SS is offline   Reply With Quote
Old January 2nd, 2009, 17:58   #12
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
My Dad (who was a mechanic) had a Lincoln for literally over a generation & a half (45 years). It was literally bullet proof. I actually would have kept it, but I needed an ultra low clearance model to go under a Z06 Corvette. I have had a AC Hydraulics DK 20 since early 2001. I understand it is considered one of the current better hydraulic 2 ton jacks around.
http://www.asedeals.com/hydraulicjacks2.html
I looked at a few web sites for Hein-Werner and they look remarkably like my Dad's old Lincoln, his was fire engine red.
Here is another link for Omega Lift Model 29023
http://www.asedeals.com/service-jacks-omega.html
ruking is offline   Reply With Quote
Old January 2nd, 2009, 18:58   #13
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
a nice one if you live in canada
http://www.canadiantire.ca/include/p...=1230951428619
http://www.canadiantire.ca/browse/pr...08474396672442
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old January 9th, 2009, 16:37   #14
Kiwi_ME
Just two comments regarding my experience with cheap trolley jacks:
-be sure you close the valve after you lower the jack to keep fluid from leaking past the valve stem.
-the check valve sometimes sticks and the jack won't lift. Need to bang it with a hammer to loosen.
Kiwi_ME is offline   Reply With Quote
Old January 9th, 2009, 18:26   #15
BrianCT
TDI(s): TDI
Page generated in 0.17100 seconds with 9 queries
[Output: 124.10 Kb. compressed to 103.03 Kb. by saving 21.07 Kb. (16.98%)]
