mydeathbynapalm
I did a quick search and didn't really find much info on the oil filters for the MKIV ALH...and what the differences (if any) there are. I've never done an oil analysis, nor did I want to dig through the threads on that to see if people had done any analysis with all else (relatively) equal comparing the couple different filters offered.
I was just going through what supplies I had in the garage recently and checked out the 3 different filters I have - Mann, OEM, Mahle.
The Mann and OEM (as described elsewhere) are essentially identical.(though the plastic on the inside is cream - Mann, black - OEM.) Those 2 have ~6 pleats per inch...w/ 49(+1 if you count the 2 ends glued) pleats total at 8 1/4" circumferance.(yes, I counted to make sure ) The Mahle has an ever so slightly different looking inside...I'm sure functionally no different. BUT it has ~8 pleats per inch. 66(+1 if you count the 2 ends glued) pleats total at 8 1/8" circumferance.
For surface area...here's where it gets a little tricky... I picked a random pleat and slide a sheet of paper in and marked the depth.(then picked other random pleats to check consistancy). The Mahle has a depth of 17/32" and the OEW/Mann has an 18/32" depth. 1/32" does add up over time! (I'm counting the width of the folds separately as getting into x/64"s is splitting hairs...but the Mahle's folds are 1/32" and the OEM/Mann are 3/64"s as best as I can measure )
*By just counting the full pleats, here go the calculations*
(Each pleat has 2 faces...why there is a '2' in the calculation )
Mahle - 66x2x(17/32")= 70.125" (+2.063" from the folds if you want to get technical) Long.
Mann/OEM - 49x2x(18/32)= 55.125" (+2.297" from the folds, again........) Long.
And factor in the height - Mahle uses 6" while the OEM/Mann use (as best as I can determine due to glue variations top/bottom...check photos) 5 7/8".(Total height on all 3 - 6 1/8")
SO TOTAL SURFACE AREA:
Mahle - 70.125"x6"= 420.75" square (+12.378 - Folds...)
OEM/Mann - 55.125"x5.875"=323.86" square (+13.495 - Folds...)
Well...
~97"(or ~96" factoring in the folds) square difference is pretty significant, yes!?
But I have no clue about the filter media itself...other than what I see. The Mann/OEM appear to use a thicker media than the Mahle (if looking at the folds and their width means anything...) Remember, this is all just observation.
So to the photos. Discuss if you want. I doubt I'm on to something. I couldn't find this discussed through searching here; so excuse me if this is a dead horse. Cheers.
Well...
