Old November 3rd, 2014, 19:40   #61
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
i just spent the whole day doing this... but i tore the dash out and the airbag. i didnt start out that way but i just couldnt get my fat hands in there so i just removed everything in the way. now that i know how it all goes together i think i could do this in 4-6 hours including pulling the dash up... but the dash was impossible for me to put back in with out removing the airbag.
looking for a B3 glovebox to go in airbag hole if anyone has a line on one.
***edit: user steve addy got me a glovebox, fits perfect and came with a key to boot***
unfortunately i needed to button it up and go home and i forgot something... my blower fan control doesnt work. ill have to pull the hvac controls again in the morning and fix it. pretty sure i just left it unplugged.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old November 11th, 2014, 12:18   #62
Redlabel6
Redlabel6's Avatar
Fuel Economy: A3 51mpg, B5.5 38mpg
I have one from an A3 if they are the same....
d
05 Passat GLX TDI Stonehenge Gray
05 Jetta 2.5 Gasser
73 Karmann Ghia Autostick
Redlabel6 is offline   Reply With Quote
Old December 8th, 2014, 11:15   #63
tripl-e
Fuel Economy: 48
First of all a big THANKS! to diesel300dmanual and ToddA1 for pioneering this effort. Like others here, I was putting up with the marginal creature comfort rather than deal with a complete dash removal. But this procedure looked easy enough to manage. I took ToddA1's extra step(s) of removing the airbag, mount bracket and dash distribution plenum. One caveat here is that the top bolts on the air bag mount are not easy access and more than a little patience is called for. The real benefit of this method is the clear access to the repair area. With the distribution plenum out of the way, access to the foamless doors is clear and easy. And is sure is nice to have heat this time of year!
There's never enough time to do it right but there's always enough time to do it twice!
'97 b4 300,000, '01 Ram 2500 5.9 200,000, '84 Saab 900 440,000 RIP , '93 BMW M5 Touring (Clone) 188,000
tripl-e is offline   Reply With Quote
Old December 8th, 2014, 16:16   #64
ToddA1
Fuel Economy: Dismal
Well, I appreciate the props, but I in no way pioneered this method. I may have come up with the extra step to save time and effort, but it's truley a group effort.
Did you lift the dash? If so, the A/B bracket screws should be easy to remove either with a ratcheting box end or 1/4" ratchet and 8mm socket. I think I used the latter.
-Todd
ToddA1 is offline   Reply With Quote
Old December 15th, 2014, 18:43   #65
Bob S.
Thanks to those that developed the procedure.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old December 28th, 2014, 00:13   #66
Col Sanders
Fuel Economy: 51 mpg last time I checked it. Audi no numbers yet.
So the ? is. Is the A3 glove box the same as the B3 ?
Col Sanders is offline   Reply With Quote
Old December 28th, 2014, 00:19   #67
Col Sanders
Going to tackle the blend door problem starting tomorrow. Probably use felt and Hvac tape. I didn't realize B4's came from the factory with heaters.
Old December 28th, 2014, 05:01   #68
ToddA1
No.
-Todd
Old December 31st, 2014, 18:51   #69
lsteimel
TDI(s): 2001 Jetta
Default Blend doors
Will this procedure also work for a 2002 Jetta TDI
lsteimel is offline   Reply With Quote
Old January 1st, 2015, 06:37   #70
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Not likely. The plenum is going to be different.
Tony
Sent from my e-diesel fleet
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old January 1st, 2015, 21:23   #71
TheDguy
Fuel Economy: 53 in Los Angeles traffic
I just tried to do this on my A3 Jetta (97 model year if it matters). The knee bar/crash support has to come out to get the whole box unit out or even the front off to get good access to the doors. Getting the bloody bar off means getting the steering column off.
I was able to do this by getting the dash out alone and working from the top of the HVAC box, I'm "lucky" enough to have small enough hands to get in the hole and was able to use felt tape. The only reason this route worked was cause the tape was tacky enough to stick, but if it no so much that you couldn't peal it a bit if it tried to stick to anything you didn't want.
Also getting the entire door covered on 1 side was nigh impossible. So far I have a hell of a lot better heat than I did before (keeping in mind, I'm in Socal where we are currently "freezing" our asses off at post-50F temps).
Did VW decide to build this cars by starting with a heater core/hvac unit in mind and assemble around it?
TheDguy is offline   Reply With Quote
Old January 2nd, 2015, 05:16   #72
Abacus
That helpful B4 guy
Abacus's Avatar
Yes...yes they did. And I'd love to slap the engineer that came up with that stupid design, among others.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old January 2nd, 2015, 09:07   #73
lisab4
lisab4's Avatar
I think we could start a line for that :/ That and the doorhandles,central locking system,...
1996 Passat B4 1.9TDI 1Z
lisab4 is offline   Reply With Quote
Old January 4th, 2015, 17:54   #74
Steve Addy
TDI(s): 97 Mk3
MB did the same thing with the W140 and that car is a lot more complicated than the Passat or Jetta. Having the evaporator replaced in that chassis is a several thousand dollar event.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old January 10th, 2015, 00:39   #75
Col Sanders
I removed the plenum to get at the doors, clear access to doors, a layer of hvac tape then felt sticky over that. There is a easy way to remove the airbag. take out the bottom Phillips screws on the airbag cover, ( the front that should be a glove box ) then you can raise the cover up and sit in pass seat with a 8mm socket and 8" extension, 3 min job. No need to stand on head and work blind. Airbag will stay out, I used a 3.5 ohm resister in airbag plug, no light ! Thanks to all for the good info, nice to have heat !
Page generated in 0.14889 seconds with 9 queries
[Output: 124.65 Kb. compressed to 103.79 Kb. by saving 20.86 Kb. (16.74%)]
