I thought it would be good to bring it into one thread as more and more of these are happening including mine last week at 58096 miles. There are so many to credit with posting so I will limit it to those who have posted pics and also performed the replacement along with the DIY.
Specifically,
Wjdell,Wrenchman30,Crosley,Oilhammer,Txoilburner and Mach1
Symptoms include one, some or all of the following.
1. Scratch or soft grind at cold idle.
2. Rattling noise from transmission area (like pebbles in your tranny) Most everyone has this symptom, for some, you can only hear it when the vehicle is in the air with the skid plate removed, for others like myself it is also noticeable in gear with foot on the brake and when just starting out. This noise can be duplicated at will by keeping foot on the brake and shifting in and out of N to R or N to D. Can also be heard in Park. This noise has also been heard from outside of the vehicle when the DMF is getting close to failure.
3. Clunking or hard shifting into first from second when coming to a stop. Others have also reported clunky/hard shifting in other gears.
4. Excessive engine vibration in gear when stopped. Very noticeable
5. Excessive engine vibration at idle in Park. Very noticeable
6. Excessive vibration while driving. Very noticeable
7. Vibrating noise while shutting down.
8. Rattle sound, like metal lines against each other from under car (this has also been attributed to the fuel line rattle TSB)
Thx to Mach1 who also deals with these, by adding the following, which everyone should keep in mind especially if you are experiencing #4,5&6 above.
When it gets to the point where the engine is shaking, then the DMF is coming apart and its time to pull it apart. The looseness in the flywheel spring/weight assembly gets so loose it is actually moving around and throws the balance off on the engine. Its time!!
Please PM me if you have or had other symptoms directly related to the DMF failing or failure and I will add them here.
Scan of service ticket showing diagnosis and part#'s
Post of updated DMF part# by Wjdell
http://forums.tdiclub.com/showthread.php?t=207818
Pics by Crosley showing a cut open DMF
http://forums.tdiclub.com/showthread.php?t=228901&highlight=dsg+dmf
These are the threads that enabled me to support my diagnosis along with two excellent DIY's by Crosley and Wrenchman30
http://forums.tdiclub.com/showthread.php?t=229258&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=222559&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=230009&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=231266&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=189298
http://forums.tdiclub.com/showthread.php?t=229212&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=229205&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=210032&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=208166&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=187281&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=183035&highlight=dsg+dmf
http://forums.tdiclub.com/showthread.php?t=222559&page=2&highlight=dmf+dsg
Now for my story...
2006.5 Jetta TDi DSG Auto...code=HXU build date=6/22/2006
build date of car 08/2006
I have a 90mile round trip commute 5 days a week and am in my car for a min of 2hrs a day.
All fluids and filters are changed religiously every 10K by myself using VW only products. At every change interval I run the car while it is in the air and perform a full visual and audio inspection from underneath as preventative maintenance.
40K DSG filter and fluid change performed by me at 41,780 miles using the VAS 6262 tool, Vag-Com, VW DSG fluid, filter, replacement o-ring and drain gasket.
Symptom 1. At roughly 57K miles I started noticing what seemed strange to me as an unusually hard downshift from 2nd to 1st. Prior to this the transmission had always shifted smooth as butter. I started paying close attention to it and noticed at first that it only happened when the vehicle was not up to operating temp. After 4 days (400miles) I noticed that it was starting to do this no matter if the car was warm or cold. In the last 300 or so miles it was becoming more and more pronounced, but for me still only affected gears 1 & 2.
Symptom 2. At approx 57300 miles I began to notice an almost imperceptible rattling noise that can best be explained like two pieces of metal rattling against each other. This noise progressively got worse until it morphed into the next symptom/noise.
Symptom 3. At approx 57500 miles I began to notice an almost imperceptible rattling noise coming from the transmission while in gear idling at a stoplight. At 57600 miles I put the car in the air, pulled the skid plate and was able to verify a rattling noise (pebbles clunking around) coming from the transmission area.
Symptom 4. At approx 57600 miles the vehicle began to display a very noticeable vibration at idle. This vibration was even more pronounced when in gear and at a stop. This vibration progressively worsened until the vehicle was taken into the stealership at 58096 miles.
Symptom 5. From 57600-58000miles the rattling (pebbles clunking around) became progressively worse, going from barely audible to being audible from outside the vehicle. This was positively confirmed by my wife who came out into the garage while I was pulling in and said *** is that noise?
Now as Paul Harvey would say...... The rest of the story.
I dropped her off at the stealership 12/5/08 with the aforementioned issues.
They performed a scan of the vehicle.
**The scan came back clean with no fault codes and a clean bill of health.
**The noise was diagnosed as a noise coming from the transmission area but was deemed as a very NORMAL noise and would not affect the vehicle
**The rough/clunky downshifting from 2nd to 1st was also verified and deemed to be within specs and a normal function of the DSG transmission.
When I asked as to why these things only started happening in the last 1K miles and were getting progressively worse, I was told that the vehicle was reaching it's break in point and this was normal for these vehicles
I then showed them all of the documented symptoms along with pics that I had been able to find here on TDI Club, VWVortex and other places on the internet.
I was told by the Service Manager, Service Advisor, the Senior Tech and one other mechanic that the DSG Automatic does NOT have a DMF furthermore, the Senior Tech told me that he had been on the phone with VW tech line and was told that it was a runability issue and to start with replacing the fuel filter He was told that if it did not fix the problem to replace the Fuel Pump and if that did not work then replace the Injector Pumps
The Service Manager told me that they would replace the fuel filter for $100 and that would more than likely fix the problem...grrrrrrrr... I said not to bother, that I would do it myself for the cost of the $16 dollar filter and 10min of my time. I told them I would report back to them the next morning (Sat). They charged $148 for diagnostic fees and sent me on my way.
After replacing the fuel filter, I took it back to them Sat morning with no change in driveability.
The REST REST of the story.........
Sat 12/6/08 when I brought the vehicle back in the mechanic listened to the noise and said that they were full of shi* and told me to have service write it up again and to leave it.
Monday morning 12/8/08... I received an email from him with the following two pics.
And this one showing 1 1/4" movement 32mm (there should be less than 10mm or none)
Hmmmmmmm very interesting....
1.) why is there a picture of a DMF installed on my car that according to them does not have one?
2.) why is there so much play in said non-existent DMF?
Needless to say a new DMF has been overnighted and will be covered under the Powertrain Warranty. ******Shaking Head****** OHHHHH and before I forget, the Service Writer is still saying that our cars do NOT have a DMF. He is saying that it is a flywheel only not a DMF **LMFAO**
Specifically,
Now for my story...
