Old December 6th, 2008, 09:13   #1
Hank Folk
TDI(s): 2004 Jetta
Default Flat towing a 2004 Jetta TDI stick trans?
Can I flat tow my TDI? It is a 2004 manual trans. A dolly would be a real pain to deal with when I am not towing.
Hank Folk is offline   Reply With Quote
Old December 6th, 2008, 09:31   #2
bigwoode
bigwoode's Avatar
Fuel Economy: 32-36 city, 42-51 hwy
Flat tow as in ropes and drive it on the ground? I think for shorter distances its not a problem, you will obviously need someone to turn the wheel though, or do you mean something else?
2001.5 Jetta GLS TDI -- 5 spd, Sold at 311,393km
"Diesel Fried Chicken"
"There's some ridiculous joke about how "gas" doesn't work too well. It's beyond old." - jcrews
bigwoode is offline   Reply With Quote
Old December 6th, 2008, 09:32   #3
GD
GD's Avatar
Beware: Dolly's ruin oil pans.
TDI'ers Do it Better!
2007 Benz ML320 CDI too many toys to list
2011 Jetta TDI (CJAA) Highline DSG Reflex Silver 165,000 kms
2004 Jetta TDI PD (BEW) Platinum Metallic Grey 340,000 kms SOLD
2000 Jetta TDI ALH Black 398,000 kms, TT LCA Bushings, TB changed at Windex GTG SOLD
GD is offline   Reply With Quote
Old December 6th, 2008, 09:43   #4
Hank Folk
TDI(s): 2004 Jetta
My mistake for not being clear. Flat tow as in behind an RV with tow bar kit.
Old December 6th, 2008, 11:49   #5
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
The transaxle input shaft lubricates the gearbox. The user manual states only to tow short distances at slow speed to avoid damage.
I used a car carrier and it worked like a charm - no flat tires to worry about or other hazards associated with dragging a car with any wheels on the ground. My only complaint is that the lower valence got caught on the wheel stops but that didn't seem to tear it up though.
jcrews is offline   Reply With Quote
Old December 6th, 2008, 16:27   #6
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Flat towing
From what I have read NO!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old December 6th, 2008, 19:10   #7
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
You guys are all wrong.
You CAN flat tow a TDI MANUAL transmission car. There are MANY different tow bars available for them. Get the one that goes out the lower side grills instead of through the bumper. Nasty looking and damage. the grill unit has removable arms and you can't really tell its a tow car.
You just need to keep a sign in the car that says "is it in gear?" I did a complete trans and engine replacement for a bus company that left one in 1st......all it took was a few hundred yards.....$11.9K......EVERYTHING was destroyed. I MEAN EVERYTHING.....wiring, radiator, inj pump, turbo, alternator......I still have the remnants.....
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old December 7th, 2008, 09:41   #8
Hank Folk
TDI(s): 2004 Jetta
Jason, Thanks. Local VW service dept. also said OK, out of gear, steering wheel not locked.
Looked at tow bars and mounting plates. Found style you mentioned.
Thanks, Hank
Old December 14th, 2008, 17:45   #9
PAW
Fuel Economy: 42 at first no w up to 53-55 using tips from this web site
guess what i have towed a 2000 NB behind my Rv for 5 years--ranging from 1000 miles to 7500 miles at one time--no problem at all--just one thing --if you make a tight turn in or out of a gas station or something like that --go back and chk to see that your sterring wheel did not relock---other then that--you won't even know its back there!
Jason--you are correct again!
phil
2006 Jetta 5m "Diesel" edition 45K
2000 NB Silver 5m 141+K
RC2e, pp520's, Wing, Front damper
1999 Well now my sons NB 110K
1999 NB 60K traded n for 00
Some people have a better Photographic memory!
Others just forgot to put the film in or now’a days turn the DVR on!
PAW is offline   Reply With Quote
Old December 14th, 2008, 17:49   #10
bakdoor
bakdoor's Avatar
One other thing to note-you can't really back up while flat towing, either. The steering wheel (being unlocked, as it needs to be) will wander around if you try to back up while flat towing. Used to FT my Jeep behind my Ram before I bought a trailer for it.
Good luck!
Save the polar ice caps...they taste great in margaritas!
2014 Jetta TDI-currently in Dieselgate limbo
2014 Harley Davidson Street Glide-fuel sipper #2
2011 Dodge Ram 2500 CTD-crawler hauler
1994 Jeep Wrangler-Rock Crawler
bakdoor is offline   Reply With Quote
Old December 15th, 2008, 00:34   #11
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
phil
__. I bought the tow plate for my Jetta from a guy who had used it to tow his Jetta something like 75K miles. He lives full time in his motorhome (actually a converted bus). His wife wanted a Passat so they pulled the plate, sold it to me, sold the Jetta, and then bought a plate for the Passat. No problems in the 75K miles.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Old June 24th, 2010, 00:00   #12
QuickWrite
I realize this is an old thread. But if you guys are still out there, I'm wondering if you can tell me what tow bar system you are using for your MkIV cars, or which one you would recommend that requires minimal surgery to the car. Thanks!
2005 Jetta GLS TDI wagon, 5-speed
QuickWrite is offline   Reply With Quote
Old June 24th, 2010, 19:22   #13
compignition
Default flat tow with a dsg in neutral?
Since the DSG is not a slush box, can I flat tow in neutral? Been using the jeep, but it was designed for the purpose, and does not count the miles on the odometer.
cup car salsa
Grand Cherokee CRD
E320 Bluetec
Prevost Detroit 60 series
compignition is offline   Reply With Quote
Old June 24th, 2010, 19:33   #14
MayorDJQ
Does the owner's manual comment on it? I suspect flat towing is not a good idea with a DSG.
MayorDJQ is offline   Reply With Quote
Old June 25th, 2010, 06:25   #15
jasonTDI
jasonTDI's Avatar
You cannot flat tow a DSG. You wll kill it.
Page generated in 0.16124 seconds with 9 queries
[Output: 121.57 Kb. compressed to 100.41 Kb. by saving 21.17 Kb. (17.41%)]
