Old December 4th, 2008, 18:07   #1
RES
Default Alternator Confusion
With all the concerns about Alternator pulleys breaking, I decided to replace mine on my 2000 Jetta TDI 118,000 miles. When I went to order a new pulley from 1stVWparts.com they asked for the Alternator Part Number. I told them it is Bosch 120amp Part# 028 903 028E. They told me I needed Pulley #028 903 119J for $131.07 in place of the common Part #022 903 119C at $52. They also said that the #022 903 119C may work. Has anyone else run into this confusion? On every other website I looked at they only list one pulley.
RES is offline   Reply With Quote
Old December 4th, 2008, 18:17   #2
paramedick
paramedick's Avatar
Get the 119C
Old December 4th, 2008, 18:23   #3
whitedog
So Bruce what is the 028E for? Or is the 119C and 028E completely interchangeable?
Winters come, and winters go.,
Summers come, and summers go.
Old December 4th, 2008, 22:07   #4
paramedick
paramedick's Avatar
Tim, the 028 903 028E is the original part number for the alternator. Part number has changed to 038 903 018B. ETKA show it as a 120 amp Bosch alternator.
Based on the part number, ETKA says the correct alternator pulley is a 022 903 119 A or T. A is the only free-wheeling pulley of the two. That part number has been changed to a suffix C for the "improved" part.
Old December 5th, 2008, 05:17   #5
gburner
gburner's Avatar
TDI(s): 2003 jetta
Fuel Economy: 49 hwy
What is the purpose of the clutch type pulley ?
2003 Jetta GLS
5spd 241k+
gburner is offline   Reply With Quote
Old December 5th, 2008, 06:15   #6
RES
GBurner
If you go to the TDI101 forum under "How To", there are two threads on how to replace the Alternator Pulley. There are some discussions on the advantage of the "Free Wheeling" pulley.
Old December 5th, 2008, 06:23   #7
RES
Bruce:
You mention that the correct alternator pulley is 028 903 119A updated to 028 903 119C. Did you mean 022 903 119C.
Old December 5th, 2008, 08:06   #8
paramedick
paramedick's Avatar
Originally Posted by RES
Bruce:
Correct. My bad. Original post edited.
Page generated in 0.13595 seconds with 9 queries
[Output: 79.92 Kb. compressed to 67.95 Kb. by saving 11.98 Kb. (14.98%)]
