Old December 4th, 2008, 09:05   #1
DeliveryValve
Default How do you properly jack up a Passat?
I appologize if this might be writen up already, but I can't seem to seach on how to Jack up a Passat properly. The closes I've seen is for a A4 Jetta.
Is there a good write up somewhere?
BTW - I only have a 3 ton floor jack and related jack stands.
- Richard-
2005 Passat TDI GLS Wagon 207,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old December 4th, 2008, 09:12   #2
rydogg
TDI(s): Passat
I just rotated my tires last night and it's still fresh on my mind. There are 4 jack points on the car, each point is 17cm inboard of the wheels (per manual). You're looking for a reinforced rail to jack the car up. Word of caution for you though. The rear jack point isn't as tough as the front one and when I positioned my jack-stand under the rear point, the jack-point buckled a little bit. If you're going to use stands, I would recommend you put a small block of wood between it and the car to spread the load out a bit. Good luck.
Unchained!!
rydogg is offline   Reply With Quote
Old December 4th, 2008, 09:21   #3
DeliveryValve
Originally Posted by rydogg
I just rotated my tires last night and it's still fresh on my mind. There are 4 jack points on the car, each point is 17cm inboard of the wheels (per manual). You're looking for a reinforced rail to jack the car up. ....
So this where I am confused. How do I get my hydraulic floor jack and the jack stands on the same jack point?
- Richard-
Old December 4th, 2008, 09:33   #4
rydogg
TDI(s): Passat
Ahhhhhh, roger that. I cheated a little and put my jack inboard a little bit to make room to put the jack-stands in the proper place. The key to the whole thing is to distribute the load enough so that the car's jack-points don't bend...hence the block(s) of wood.
Unchained!!
Old December 4th, 2008, 09:52   #5
EJS
TDI(s): 2009 Jetta
Here's a few threads on the subject..............
http://www.passatworld.com/forums/sh...hlight=jacking
I use the ProTech jack pads (thanks MoGolf) & use the pinch weld. For the rears I position the stands as shown in the link. Front I use the weld & then put the stands north-south just inside the outer rail.
Seems to work
Of note - I asked the very same question
It's just my opinion & worth exactly what you paid for it.
EJS is offline   Reply With Quote
Old December 4th, 2008, 10:33   #6
BleachedBora
BleachedBora's Avatar
"How do you properly jack up a Passat..."
Full speed into another car works well...
BleachedBora is offline   Reply With Quote
Old December 4th, 2008, 10:51   #7
DeliveryValve
That's so funny, I forgot to laugh!
- Richard-
Old December 4th, 2008, 10:51   #8
DeliveryValve
Seems to work
Thanks for the links.
- Richard-
Old December 4th, 2008, 12:55   #9
Smokerr
Fuel Economy: 43.5/32/28
Keep in mind that there are also indicator points for where the central part of the rail that you jack on is located.
The rear has a small triangle, and the front actually has a little flip out plastic door which allows you to see it better.
Most crucial is that you get the metal rail inside the slot of the jack, not the edge of the plastic trim that wraps down next to the rail. I have not done that, but have started to when I thought it was where it belonged (its a get on your knees operation). I feel to make sure that the jack is on both sides before I start.
2005 Passat TDI Wagon
Smokerr is offline   Reply With Quote
Old December 4th, 2008, 18:45   #10
dewats
Get this lift pad kit from World Impex. They create lift points that are perfect for floor jacks. I installed and used on my Passat before I sold it. If I remember correctly there were 2 covers over the front holes. The rear holes are open and easy to find.
http://www.worldimpex.com/item_detail.html?sku=179345
I used a grooved 2X4 when I had my Jetta. These lift pads are more secure and always there.
2015 Passat SE TDI DSG
2008 BMW 528i Wifes Daily Driver
2001 BMW 740i (smile maker)
2008 Dodge 2500 SLT 4X4 Quad Cab
2004 Passat TDI GLS Wagon RC2 (SOLD)
dewats is offline   Reply With Quote
Page generated in 0.15442 seconds with 9 queries
[Output: 94.47 Kb. compressed to 79.66 Kb. by saving 14.81 Kb. (15.67%)]
