Old November 29th, 2008, 08:59   #1
BruceT
BruceT's Avatar
TDI(s): 2003 tdi
Angry 2003 TDI oil pan heater FIRE!
Ladies and Gents,please be aware if you have a factory installed oilpan heater on your TDI that it may cause a fire(it will dead short)....I plugged my car in for the first time on Monday night ,only to get panicked shouts from my neighbors and son that my car was on fire...my next door neighbor heard a loud bang(that's when the refrigerent line melted and blew up) and they ran across the street to find flames coming out from under the Jetta! I was in the back yard raking leaves and did not hear the noise,they finally found the garden hose and put out the fire,and found me in the back yard still raking...hey your car is on fire....so long story short,thanks to good neighbors the Jetta survived,$1800 later I'll get it back on the road next week when the new parts come in.......
SO PLEASE,don't use your pan heater,..
get an inline hose unit if you want to keep the block warm in winter areas
regards,bruce
Flyfishing isn't a way of life,it's much more important than that!
BruceT is offline   Reply With Quote
Old November 29th, 2008, 09:29   #2
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
Sorry for your loss. Could you post some pictures so we can see the extent of the damage. Thanks
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old November 29th, 2008, 09:46   #3
J double R
Fail Train Conductor
J double R's Avatar
Fuel Economy: 45-50 mpg
http://forums.tdiclub.com/showthread.php?t=231965
http://forums.tdiclub.com/showthread.php?t=231966
Originally Posted by meganuke
Trogdor! Burninating the TDI, burninating the peasants...
J double R is offline   Reply With Quote
Old November 29th, 2008, 11:09   #4
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
regards,bruce
Good and hard earned advice. Listen to this fellow and learn!
Thanks Bruce!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old November 30th, 2008, 14:29   #5
Smokerr
Fuel Economy: 43.5/32/28
I can understand the angst, but you cannot condemn the pan heater. Same thing can and does happen with in line heaters. Anytime there is 120 volts involved, and no GFI, you can get an arching fault that will start a fire (I had a friend have her stove do the same thing).
Bet protection is a GFI. That will kill the circuit.
2005 Passat TDI Wagon
Smokerr is offline   Reply With Quote
Old November 30th, 2008, 18:16   #6
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
So you plugged your pan heater to a ungrounded source - is that correct.
Did you use a extension cord, and if so how many feet.
What is the amperage of this OEM heater anyone know.
I have a 180 watt pan heater on my car and although its on a 25ft 16ga wire I can feel no heat in the cord, so it can not be drawing much. A GFI outlet might be a good idea. I wonder if my surge protection would make a difference.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old November 30th, 2008, 19:56   #7
velociT
velociT's Avatar
And this has what to do with fuel economy?
Thanks for posting the same thing in 5 different forums...
TDT for PD Mafia Member #002
Then: 06 Jetta TDI 5M *sold*
Now: 17 Ram 3500 CTD, 87 M35A2C
velociT is offline   Reply With Quote
Old December 6th, 2008, 06:13   #8
PDJetta
PDJetta's Avatar
Wow, glad you got out relatively unscathed! A couple of years ago I read a post on this list where a member's TDI AND his roomate's car were parked in a garage (detached I think) and the operating VW dealer-installed oil pan heater fell off the pan and onto the plastic belly pan and caught the TDI on fire. Both cars and the garage were a total loss.
I thought VW would have stopped marketing this type of heater!
--Nate
Old December 6th, 2008, 15:30   #9
Smokerr
180W heat will draw about 1.4 amps. Not something you could feel in a cord that can carry 15 amps.
Surge protectors are irrelevant to the issue. If you had enough of a surge to fry an oil pan heater connection, your entire house would have burned out the wiring.
GFI not only is a good idea, most places require it for outdoor outlets, kitchen outlets and bathroom outlets. While the intent is to keep electricity from killing you in those hazardous areas, it also reacts to power devices starting to fry themselves.
Old December 6th, 2008, 21:04   #10
shagin'wagen
shagin'wagen's Avatar
TDI(s): Bora
Fuel Economy: 5L/100KM
I'm currently apprenticing as an electrician and by code, you must have GFI plugs outdoors and/or within 1.5 meters of any water source. Like a sink or water faucet.
'99.5 Bora TDI - Many mods.
'71 Tin Top Westfalia
'85 Mercedes 300SD - Highway Cruiser
'85 Jetta Coupe
shagin'wagen is offline   Reply With Quote
Old December 6th, 2008, 21:46   #11
compu_85
Gadget Guy
compu_85's Avatar
Man another one
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old December 6th, 2008, 22:12   #12
LurkerMike
LurkerMike's Avatar
Fuel Economy: -Whitey: 38-40 mpg Hwy @ 80 mph / -Red 46 mpg Hwy @ 80 mph
Bahhh... a GFCI will not stop arcing.
Yes, you need Ground Fault Circuit Interruption to detect and stop any current flow on the "hot" wire that is not returning on the neutral wire.
But arcing between the hot and neutral will not trip a GFCI so long as the load is balanced. Arcing is stopped by an AFCI: http://en.wikipedia.org/wiki/Arc-fau...it_interrupter
AFCI is supposed to be REQUIRED in the 2009 NEC (National Electrical Code).
My complaint is where I have used SquareD brand GFCI circuit breakers in many of the electrical panels I have serviced over the years... now if I do any new work in those panels, I am supposed to trash the GFCI breakers (like $60 each) and replace them with AFCI circuit breakers... OKaaaayyyy... but then I will have to rework each of those circuits to add the GFCI back to the circuit... try that on a ceiling lighting only circuit or a circuit dedicated to one machine that is hardwired in conduit... it sucks...
AFCI C/B's are a great idea! But they should not be required by the NEC until combo GFCI/AFCI circuit breakers become available...
LurkerMike is offline   Reply With Quote
Old December 20th, 2009, 17:24   #13
guymachine
If you were raking leaves and hoses were still working, then what were doing heating the oil pan with a heater? Those things are meant when it is cold outside like winter and below zero 32F or colder!
guymachine is offline   Reply With Quote
Old December 21st, 2009, 09:25   #14
PDJetta
PDJetta's Avatar
regards,bruce
Sorry for your mishap. I read a post on this list a few years ago of someone using the same heater on his TDI and it was parked in a detached garage and the TDI caught fire and burned the garage to the ground, along with his roommate's car that was parked in there too. These things are dangerous.
--Nate
Old December 22nd, 2009, 11:31   #15
Powder Hound
Powder Hound's Avatar
From post #8:
--Nate
And again in #14 above:
--Nate
OK, Nate. I get it. Hopefully everyone else does, too. Thanks. Again.
Page generated in 0.17249 seconds with 9 queries
[Output: 133.50 Kb. compressed to 111.73 Kb. by saving 21.77 Kb. (16.31%)]
